Nextcloud login problem and all others is one big problem
I simply give up after endless problems when removing errors, and when a person fixes it anyway, it messes with the login. Not!!! 3, not continuously, but for three days I screwed up for the next cloud. I just keep going without the fu…,ng cloud. There is definitely a solution where it can be done without swearing.
Hi @maxxim999, can you provide your issues? ( logs and configuration of your nextcloud to help you, don’t forget to hide personal informations)
