Nextcloud version (eg, 12.0.2): 17.0.2
Operating system and version (eg, Ubuntu 17.04): 18.04
Apache or nginx version (eg, Apache 2.4.25): 2.4.29
PHP version (eg, 7.1): 7.2
Is this the first time you’ve seen this error? (Y/N): Yes.
Warning core Login failed: 'c***r@***.com' (Remote IP: '192.168.15.102')
'theme' => '',
'instanceid' => '***',
'passwordsalt' => '***',
'secret' => '***',
0 => 'www.***.com',
'datadirectory' => '/var/www/***/nextcloud/data',
'overwrite.cli.url' => 'https://www.***.com',
'version' => '17.0.2.1',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => '***',
'dbpassword' => '***',
'logtimezone' => 'UTC',
'ldapIgnoreNamingRules' => false,
'appstore.experimental.enabled' => true,
'filelocking.enabled' => false,
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0,
'loglevel' => 2,
'ldapProviderFactory' => '\\OCA\\User_LDAP\\LDAPProviderFactory',
'remember_login_cookie_lifetime' => 1296000,
'session_keepalive' => true,
'session_lifetime' => 86400,
'user_backends' =>
0 =>
'class' => 'OC_User_IMAP',
'arguments' =>
0 => '127.0.0.1',
1 => 143,
2 => '',
3 => 'c***.com',
'updater.secret' => '***',
apache.log:
[https://pastebin.com/jhAXNADf](https://pastebin.com/jhAXNADf)
nextcloud.log shows this, however.
Keep in mind, this is about 5 minutes AFTER a SUCCESSFUL login. Furhter. tcpdump -i lo port 143 shows no activity, at the time of the attempted login. It’s like Nextcloud is not attempting to reach out to the server.
