example
longer
example
here
Nextcloud version: 25.0.4
Operating system and version: Debian GNU/Linux 11 (bullseye)
Apache or nginx version: Apache/2.4.54 (Debian)
PHP version (eg, 7.4): PHP 7.4.33
I am using Nextcloud now for nearly a year but after not opening the web page in a while, I realized that it takes really long to even load the login page, frequently with time out and connection errors. That makes the Nextcloud online unusable. The file synch via Nextcloud apps and calDAV and cardDAV seem to work normally.
- try to open Nextcloud in a web browser
Not available since Nextcloud login not reachable
'instanceid' => 'niceid',
'passwordsalt' => 'nicepasswordsalt',
'secret' => 'abcdefghijklmnopqrstuvwxyz',
0 => 'cloud.example.com',
'datadirectory' => '/data/nextcloud',
'version' => '25.0.4.1',
'overwrite.cli.url' => 'https://cloud.example.com/',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'dbpassword',
'default_phone_region' => 'XY',
'default_language' => 'XY',
'default_locale' => 'xy',
'theme' => '',
'loglevel' => 2,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_domain' => 'example.com',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.example.com',
'mail_smtpport' => '123',
'mail_smtpname' => 'user@example.com',
'mail_smtppassword' => 'pa$$word',
