Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 22.1.1.2
Operating system and version (eg, Ubuntu 20.04): YunoHost 4.4.3 (Debian 10.13)
Apache or nginx version (eg, Apache 2.4.25): nginx/1.14.2
PHP version (eg, 7.4): PHP 7.3.31-1~deb10u2
Hello, I am a newbie here trying to maintain his own server. Its storage ( installed on a raspberry pi 3 B+) was reaching full capacity and I tried to empty the trash bin following instructions from here:
Trash bin: AbstractTrash::getSize() must be of the type integer, float returned · Issue #13160 · nextcloud/server · GitHub and here Can't access to the trashbin - #16 by Johannes_Kattnig
After following them I was able to see the trash bin in the nextcloud website, which I couldn’t at the beginning. However I couldn’t delete files there. I tried the command specified in those links: sudo -u www-data php occ trashbin:cleanup --all-users however there was an error message saying the web server had no permissions to write on config. So I dug more and found other links that suggested to run this to give permissions to the web server:
chown -R www-data:www-data /var/www/owncloud/config
I changed owncloud for nextcloud and run it. Then I run again sudo -u www-data php occ trashbin:cleanup --all-users and since then when I tried to reach mydomain/nextcloud it was giving error. I found in the config folder a new file called config.save.php that was not there and I don’t know why on earth I decided to delete it (don’t be to hars, I am still learning, probably there was the main mistake). Since then when I try to reach mydomain/nextcloud there is a white background and the message File not found. I cannot reach it via web and all my devices connected cannot either. I can access the server via ssh or its own yunohost web interface though.
Thank you in advance for your help and your attention, it is highly appreciated.
chown -R www-data:www-data /var/www/owncloud/configsudo -u www-data php occ trashbin:cleanup --all-usersrm config.save.php
'passwordsalt' => 'XXXX',
'secret' => 'XXXX',
0 => 'localhost',
1 => 'mydomain/nextcloud',
'datadirectory' => 'nextcloud/data',
'version' => '22.2.10.2',
'overwrite.cli.url' => 'https://mydomain/nextcloud',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'xxx',
'dbpassword' => 'xxx',
'instanceid' => 'xxx',
'updatechecker' => false,
'integrity.check.disabled' => true,
'hashing_default_password' => true,
'localstorage.allowsymlinks' => true,
'logout_url' => 'https://mydomain/yunohost/sso/?action=logout',
'twofactor_enforced' => 'true',
'loglevel' => 2,
'config_is_read_only' => false,
The output of your Apache/nginx/system log in /var/log/nginx/mydomain-error.log:
2023/01/19 15:34:38 [error] 1128#1128: *4853 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: XXX, server: mydomain, request: "GET /nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:34:38 [error] 1128#1128: *4853 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:35:40 [error] 1128#1128: *4856 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:35:40 [error] 1128#1128: *4856 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:36:42 [error] 1128#1128: *4859 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:36:42 [error] 1128#1128: *4859 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:37:44 [error] 1128#1128: *4863 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:37:44 [error] 1128#1128: *4863 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:38:45 [error] 1128#1128: *4866 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
2023/01/19 15:38:45 [error] 1128#1128: *4866 FastCGI sent in stderr: "Primary script unknown" while reading response header from upstream, client: xxx, server: mydomain, request: "GET /nextcloud/nextcloud/status.php HTTP/1.1", upstream: "fastcgi://unix:/var/run/php/php7.3-fpm-nextcloud.sock:", host: "mydomain"
/var/www/nextcloud/ has no nextcloud.log, is empty.
