NextCloud installation issue
Any help would be appreciated, I am trying to get NextCloud running but having trouble getting past by submitting the domain name as I keep running into Port 443 not reachable.
I have added a subdomain and point to my static WAN IP.
I have a Nginx Proxy Manager running on Rp4.
I have Debian running on separate host, docker installed on the host and NC AIO installed by following the official install instructions.
Just to narrow down the issue I have forwarded ports 80,443 and even 8443 from my router to the Debian host directly by passing the proxy manager but still the same issue.
Hi, can you follow https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md#6-how-to-debug-things?
I did, after point 13. It installs all containers but is not accessible once deployed.
Ehat kind of error do you get? Can you post a Screenshot maybe?
When I add --env SKIP_DOMAIN_VALIDATION=true to docker run command, was able to bypass the domain validation page and complete the installation of all containers, but then when trying to open NextCloud. Simply get a ā€œCan’t reach this page errorā€. If I try using the port 8080 then get the below
Can you post the output of sudo docker logs nextcloud-aio-apache here?
Please use https://ip.address.of.this.server:8080 to access the AIO interface instead of https://your-domain:8080
Apache output:
Waiting for Nextcloud to start…
{ā€œlevelā€:ā€œinfoā€,ā€œtsā€:1692009361.6078563,ā€œmsgā€:ā€œusing provided configurationā€,ā€œconfig_fileā€:ā€œ/tmp/Caddyfileā€,ā€œconfig_adapterā€:ā€œā€}
[Mon Aug 14 20:36:01.611290 2023] [mpm_event:notice] [pid 750:tid 140163172514632] AH00489: Apache/2.4.57 (Unix) configured – resuming normal operations
[Mon Aug 14 20:36:01.611777 2023] [core:notice] [pid 750:tid 140163172514632] AH00094: Command line: ā€˜/usr/local/apache2/bin/httpd -D FOREGROUND’
When I use https://ip.address.of.this.server:8080 it redirects to the below
Can you show your NPM config?
Thanks for trying to help me out with this issue. I have spent way too much time on this to no avail and hence decided to look at an alternative option.
Just as an alternative idea, you may have a look at https://github.com/nextcloud/all-in-one/tree/main/manual-install
