For the record those instructions are from 2015, and version 13 of the appliance. The appliance is now version 16, there are 2 hard drives that are part of the vm appliance.
These would be good updated instructions based on the new appliancesā¦
damobeanrod ⢠a year ago
My Guide
Extend the second Virtual Disk to the desired size
Snapshot your VM prior this worked in my environment but has not been tested beyond that.
after this command, type āFixā at prompt to take advantage
of new space.
parted -l
remove the buffering partition
parted /dev/sbb rm 9
expand partition holding zpool
parted /dev/sbb resizepart 1 100%
Expand the zpool (and, by extension, the filesystem it contains).
zpool online -e ncdata /dev/sdb
Verify the FileSystem has expanded.
zpool list
I canāt speak for Univention as I never tried it, but the VM that I make is years of development. Iād be surprised if you didnāt like it. ![]()
Hello @enoch85 ,
Is it possible to still get a custom sized VM fir virtual box?
Hi @Nav,
Sure, check this out:
Hello all! Iām super excited to get started on my nextcloud project, but I have two quick questions. I will be running this on an old mac mini, and VMware fusion says it is for OSās newer than mine, I have a version of virtualbox that does work, is there a reason it isnāt recommended?
Also, I was drawn to NextCloud because it was free and open source, but it looks like you have to pay? I went to github, but that seems to not be the VM file, but maybe the scripts that are inside it?
Thanks,
Jacob
Short answer: Parallels works but runtime must be changed from Apple to Parallels (tested on mac mini 2012)
prebuilt custom VMs are optionally available, I assume as an alternative to donations, as a convenience
