Nextcloud Hub 3 Upgrade Path
Hi all,
I have installed a fresh VM with Ubuntu 22 and used the intergrated nextcloud install option which has kindly installed Nextcloud Hub 3.
Is there a simple upgrade path to the latest version of Nextcloud Enterprise?
Worth noting we are already an Enterprise customer looking to embark on a migration.
Thanks
hey @LeeUK
as you are on the more or less homeuser-forum you might wanna address to pro-support, first?
I mean you pay for that pro-support already if have a valid pro-license so why not using it?
Though I think there’s no way other than upgrading version by version to NC27.1.3 (which is the lastest offical version so far) as skipping major versions isn’t supported.
Thank you i will reach out to them
