Nextcloud hub 3 25.0.1 issue after update
Hello Guys,
after update on Nextcloud Hub 3 i’ve more problem:
  1. no dashboard on web browser yes on nextcloud app
  2. user can’t access on mobile > Access forbidden - State token does not match
Anyone have some issue?
How to resolve?
Thanks
Rocco
I have the same problem, after the update Nextcloud Web portal doesnt show up anymore. The Desktop App doesnt connect also, the only working thing is: Connecting via WebDAV, that works.
edit:// Okay the connecting over WebDAV also doesnt work, my Service is complete down after the Update from 24.0.7.1 to the latest 25 hub Version
edit 2:// My Instance works again i did the following (IM NOT A PROFESSIONAL DO IT ON YOUR OWN RISK AND BACKUP YOUR FILES BEFORE)
  1. I logged in via SSH
  2. I shut down my Webserver in this Case Apache2 (sudo systemctl stop apache2)
  3. I switched to my Nextcloud installation folder (cd /var/www/nextcloud/)
  4. I pasted in the manual upgrade command (sudo -u www-data php occ upgrade)
  5. I started my Apache Webserver again (systemctl start apache2)
After the installation the Upgrade was successful and i can access all my files again over the Web and the Desktop App
