Nextcloud HTTP 502 - AIO nextcloud-container stays starting
    • last version
    • OMV 7.7.14-1
    • Apache 2.4.65
    • Traefik
    • replace me
    • yes
    • yesterday
    • AIO
    • no
Nextcloud is not reachable with error HTTP 502. In AIO container view the container Apache, Nextcloud and Notify Push remains in status “Starting”, the other container are running.
  1. After Start of AIO Mastercontainer not all container are running.
  2. Restart of AIO Mastercontainer or docker does not help.
2025-08-12T04:13:50.746204632Z Connection to nextcloud-aio-database (172.21.0.3) 5432 port [tcp/postgresql] succeeded!
2025-08-12T04:13:53.071400214Z               now
2025-08-12T04:13:53.071434227Z -------------------------------
2025-08-12T04:13:53.071447916Z  2025-08-12 06:13:53.070963+02
2025-08-12T04:13:53.071454691Z (1 row)
2025-08-12T04:13:53.071461884Z
2025-08-12T04:13:53.137973898Z + '[' -f /dev-dri-group-was-added ']'
2025-08-12T04:13:53.138283089Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2025-08-12T04:13:53.138840011Z + '[' -n '' ']'
2025-08-12T04:13:53.138856284Z + set +x
2025-08-12T04:13:53.147359287Z Enabling Imagick...
2025-08-12T04:14:11.270028772Z WARNING: fetching https://dl-cdn.alpinelinux.org/alpine/v3.22/main: temporary error (try again later)
2025-08-12T04:14:16.271640780Z WARNING: fetching https://dl-cdn.alpinelinux.org/alpine/v3.22/community: temporary error (try again later)
2025-08-12T04:14:16.278481889Z ERROR: unable to select packages:
2025-08-12T04:14:16.278534411Z   .docker-php-ext-enable-deps-20250812.041416:
2025-08-12T04:14:16.278544328Z     masked in: cache
2025-08-12T04:14:16.278551941Z     satisfies: world[.docker-php-ext-enable-deps=20250812.041416]
2025-08-12T04:14:16.278559554Z   binutils (no such package):
2025-08-12T04:14:16.278567795Z     required by: .docker-php-ext-enable-deps-20250812.041416[binutils]
2025-08-12T04:14:16.282362878Z Could not install PHP extension imagick!
2025-08-12T04:14:16.301040208Z Connection to nextcloud-aio-redis (172.21.0.4) 6379 port [tcp/redis] succeeded!
2025-08-12T04:15:02.482644331Z Applying one-click-instance settings...
2025-08-12T04:15:02.747250144Z System config value one-click-instance set to boolean true
2025-08-12T04:15:03.024579662Z System config value one-click-instance.user-limit set to integer 100
2025-08-12T04:15:03.299872513Z System config value one-click-instance.link set to string https://nextcloud.com/all-in-one/
2025-08-12T04:15:03.570252388Z support already enabled
2025-08-12T04:15:03.581506543Z Adjusting log files...
2025-08-12T04:15:03.838173539Z System config value upgrade.cli-upgrade-link set to string https://github.com/nextcloud/all-in-one/discussions/2726
2025-08-12T04:15:04.108784870Z System config value logfile set to string /var/www/html/data/nextcloud.log
2025-08-12T04:15:04.477790880Z Config value were not updated
2025-08-12T04:15:04.746579890Z System config value updatedirectory set to string /nc-updater
2025-08-12T04:15:05.014010749Z System config value maintenance_window_start set to integer 100
2025-08-12T04:15:05.025300594Z Applying network settings...
2025-08-12T04:15:05.280869181Z System config value allow_local_remote_servers set to boolean true
2025-08-12T04:15:05.550175582Z System config value davstorage.request_timeout set to integer 3600
2025-08-12T04:15:05.819869257Z System config value trusted_domains => 1 set to string nextcloud.kohlen-online.de
2025-08-12T04:15:06.087051478Z System config value overwrite.cli.url set to string https://nextcloud.kohlen-online.de/
2025-08-12T04:15:06.356827986Z System config value documentation_url.server_logs set to string https://github.com/nextcloud/all-in-one/discussions/5425
2025-08-12T04:15:06.629607078Z System config value htaccess.RewriteBase set to string /
2025-08-12T04:15:08.549955680Z .htaccess has been updated
2025-08-12T04:15:08.820187209Z System config value dbpersistent set to boolean false
2025-08-12T04:15:09.090394085Z System config value auth.bruteforce.protection.enabled set to boolean true
2025-08-12T04:15:09.366078890Z System config value ratelimit.protection.enabled set to boolean true
2025-08-12T04:15:09.633038314Z System config value files_external_allow_create_new_local set to boolean false
2025-08-12T04:15:17.000847791Z notify_push is up-to-date or no updates could be found
2025-08-12T04:15:17.281014437Z System config value trusted_proxies => 0 set to string 127.0.0.1
2025-08-12T04:15:17.548964433Z System config value trusted_proxies => 1 set to string ::1
2025-08-12T04:15:19.233811776Z System config value trusted_proxies => 10 set to string 172.21.0.0/16
2025-08-12T04:15:19.503414796Z Config value were not updated
2025-08-12T04:15:19.514939869Z + echo nextcloud-aio-collabora
2025-08-12T04:15:19.515062372Z + grep -q 'nextcloud-.*-collabora'
2025-08-12T04:15:19.515877360Z + COLLABORA_HOST=nextcloud.kohlen-online.de
2025-08-12T04:15:19.515890211Z + set +x
2025-08-12T04:15:20.072512161Z richdocuments is up-to-date or no updates could be found
2025-08-12T04:15:20.345546736Z Config value were not updated
2025-08-12T04:15:20.926697601Z Config value were not updated
2025-08-12T04:15:20.939146616Z Connection to nextcloud-aio-clamav (172.21.0.5) 3310 port [tcp/*] succeeded!
2025-08-12T04:15:21.493578037Z files_antivirus is up-to-date or no updates could be found
2025-08-12T04:15:21.762864812Z Config value were not updated
2025-08-12T04:15:22.033222826Z Config value were not updated
2025-08-12T04:15:22.303722549Z Config value were not updated
2025-08-12T04:15:22.571039426Z Config value were not updated
2025-08-12T04:15:22.842009815Z Config value were not updated
2025-08-12T04:15:23.109730240Z Config value were not updated
2025-08-12T04:15:23.378426010Z System config value enabledPreviewProviders => 0 set to string OC\Preview\Imaginary
2025-08-12T04:15:23.648763979Z System config value enabledPreviewProviders => 23 set to string OC\Preview\ImaginaryPDF
2025-08-12T04:15:23.915796528Z System config value preview_imaginary_url set to string http://nextcloud-aio-imaginary:9000
2025-08-12T04:15:24.183984057Z System config value preview_imaginary_key set to string f13af85824f6bd7597484e5eb9d0b293cbd2b828b9ed2d9a
2025-08-12T04:15:24.196058439Z nc: service "" unknown
2025-08-12T04:15:24.196163482Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:29.198739522Z nc: service "" unknown
2025-08-12T04:15:29.198892616Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:34.201385474Z nc: service "" unknown
2025-08-12T04:15:34.201461672Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:39.204125922Z nc: service "" unknown
2025-08-12T04:15:39.204198349Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:44.206694908Z nc: service "" unknown
2025-08-12T04:15:44.206792478Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:49.209261310Z nc: service "" unknown
2025-08-12T04:15:49.209299933Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:54.212107150Z nc: service "" unknown
2025-08-12T04:15:54.212231260Z waiting for Fulltextsearch to become available...
2025-08-12T04:15:59.214746048Z nc: service "" unknown
2025-08-12T04:15:59.214800385Z waiting for Fulltextsearch to become available...
2025-08-12T04:16:04.217472737Z nc: service "" unknown
2025-08-12T04:16:04.217658168Z waiting for Fulltextsearch to become available...
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "redis": {
            "port": 6379
        "overwritehost": "nextcloud.xxxx.de",
        "overwriteprotocol": "https",
            "localhost",
            "nextcloud.xxxx.de"
        "dbtype": "pgsql",
        "version": "31.0.7.1",
        "overwrite.cli.url": "https:\/\/nextcloud.xxxx.de\/",
        "dbport": "",
        "loglevel": "2",
        "log_type": "file",
        "log_rotate_size": "10485760",
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": "2048",
        "preview_max_y": "2048",
        "jpeg_quality": "60",
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie",
            "7": "OC\\Preview\\Krita",
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": "30",
        "share_folder": "\/Shared",
        "one-click-instance": true,
        "htaccess.RewriteBase": "\/",
        "default_phone_region": "DE",
        "mail_smtpsecure": "ssl",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "465",
        "mail_smtpauth": 1,
        "dbpersistent": false,
        "appsallowlist": false,
        "data-fingerprint": "52d3b436805ec386c8d8f3b5b49d76f5",
        "updatechecker": false,
        "DOMAIN": "nextcloud.xxxx.de"
  - activity: 4.0.0
  - admin_audit: 1.21.0
  - bruteforcesettings: 4.0.0
  - calendar: 5.3.8
  - circles: 31.0.0
  - comments: 1.21.0
  - contacts: 7.2.4
  - contactsinteraction: 1.12.0
  - dashboard: 7.11.0
  - dav: 1.33.0
  - deck: 1.15.2
  - federation: 1.21.0
  - files: 2.3.1
  - files_antivirus: 6.0.3
  - files_downloadlimit: 4.0.0
  - files_fulltextsearch: 31.0.0
  - files_pdfviewer: 4.0.0
  - files_reminders: 1.4.0
  - files_sharing: 1.23.1
  - files_trashbin: 1.21.0
  - files_versions: 1.24.0
  - firstrunwizard: 4.0.0
  - fulltextsearch: 31.0.0
  - fulltextsearch_elasticsearch: 31.0.0
  - logreader: 4.0.0
  - news: 26.1.0
  - nextcloud-aio: 0.8.0
  - notifications: 4.0.0
  - notify_push: 1.1.1
  - oauth2: 1.19.1
  - password_policy: 3.0.0
  - photos: 4.0.0
  - privacy: 3.0.0
  - profile: 1.0.0
  - provisioning_api: 1.21.0
  - recommendations: 4.0.0
  - related_resources: 2.0.0
  - richdocuments: 8.7.3
  - serverinfo: 3.0.0
  - settings: 1.14.0
  - sharebymail: 1.21.0
  - support: 3.0.0
  - survey_client: 3.0.0
  - systemtags: 1.21.1
  - tasks: 0.16.1
  - text: 5.0.0
  - theming: 2.6.1
  - updatenotification: 1.21.0
  - user_migration: 8.0.0
  - user_status: 1.11.0
  - viewer: 4.0.0
  - weather_status: 1.11.0
  - webhook_listeners: 1.2.0
  - whiteboard: 1.1.2
  - workflowengine: 2.13.0
  - app_api: 5.0.2 (installed 4.0.5)
  - encryption: 2.19.0
  - files_external: 1.23.0
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - suspicious_login: 9.0.1
  - user_ldap: 1.22.0
I “solved” the issue by
  • manually stop all containers with “docker stop nextcloud-aio-xxx”
  • then I deactivate in AIO-Interface the optional container Fulltextsearch
  • restart the AIO-mastercontainer
  • manually start the not running container with “docker start nextcloud-aio-xxx”
After this nextcloud is running again.
Matthias
Hi, we improved this with AIO v11.6.0 Beta to not wait indefinitely if elasticsearch is not starting. Testing and feedback is welcome! See GitHub - nextcloud/all-in-one: 📦 The official Nextcloud installation method. Provides easy deployment and maintenance with most features included in this one Nextcloud instance.
It is good, when nexcloud is running. But why is nexctloud waiting for fulltextsearch, when the fulltextsearch-container is running without error?
Anyway, I don’t use fulltextsearch and so I can live good without it.
Matthias
