I’m trying to install nextcloud:fpm and I can’t realise what I’m doing wrong.
Here’s my setup:
- MariaDB 10.5: external DB (10.11.12.3:3306)
- Local (host) NGINX, non-Dokerized
- NextCloud: nextcloud:fpm installed in
/docker/nextcloud/files, FPM port should be10001
Please note that I don’t want to use Docker Volumes (/docker is on SSD while / is on HDD), so the local NGINX should be physically pointed to NextCloud’s docker files.
The error that I’m receiving is: [error] 7191#7191: 1 FastCGI sent in stderr: “Primary script unknown” while reading response header from upstream, client: 10.11.12.1, server: cloud.hostname.tld, request: “GET / HTTP/2.0”, upstream: “fastcgi://127.0.0.1:10001”, host: "cloud.hostname.tld"
Any help is really appreciated as I’m really stuck with this.
Here’s docker-compose.yml:
version: '2'
services:
app:
image: nextcloud:fpm
restart: unless-stopped
ports:
- "10001:9000"
volumes:
- /docker/nextcloud/files:/var/www/html
Here’s NGINX’s nextcloud.conf:
upstream php-handler {
server 127.0.0.1:10001;
server {
listen 80;
listen [::]:80;
server_name cloud.hostname.tld;
return 301 https://$server_name$request_uri;
server {
listen 443 ssl http2;
ssl_certificate /etc/letsencrypt/live/cloud.hostname.tld/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/cloud.hostname.tld/privkey.pem;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;" always;
client_max_body_size 5G;
fastcgi_buffers 64 4K;
gzip on;
gzip_vary on;
gzip_comp_level 4;
gzip_min_length 256;
gzip_types application/atom+xml application/javascript application/json application/ld+json application/manifest+json application/rss+xml application/vnd.geo+json application/vnd.ms-fontobject application/x-font-ttf application/x-web-app-manifest+json application/xhtml+xml application/xml font/opentype image/bmp image/svg+xml image/x-icon text/cache-manifest text/css text/plain text/vcard text/vnd.rim.location.xloc text/vtt text/x-component text/x-cross-domain-policy;
add_header X-Download-Options "noopen" always;
add_header X-Permitted-Cross-Domain-Policies "none" always;
add_header X-Robots-Tag "none" always;
add_header X-XSS-Protection "1; mode=block" always;
root /docker/nextcloud/files;
index index.php index.html /index.php$request_uri;
location = / {
if ( $http_user_agent ~ ^DavClnt ) {
return 302 /remote.php/webdav/$is_args$args;
location = /robots.txt {
allow all;
log_not_found off;
access_log off;
location ^~ /.well-known {
location = /.well-known/carddav { return 301 /remote.php/dav/; }
location = /.well-known/caldav { return 301 /remote.php/dav/; }
location /.well-known/acme-challenge { try_files $uri $uri/ =404; }
location /.well-known/pki-validation { try_files $uri $uri/ =404; }
return 301 /index.php$request_uri;
location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) { return 404; }
location ~ ^/(?:\.|autotest|occ|issue|indie|db_|console) { return 404; }
location ~ \.php(?:$|/) {
set $path_info $fastcgi_path_info;
include fastcgi_params;
fastcgi_param PATH_INFO $path_info;
fastcgi_param HTTPS on;
fastcgi_param modHeadersAvailable true; # Avoid sending the security headers twice
fastcgi_param front_controller_active true; # Enable pretty urls
fastcgi_pass php-handler;
fastcgi_intercept_errors on;
location ~ \.(?:css|js|svg|gif|png|jpg|ico)$ {
expires 6M; # Cache-Control policy borrowed from `.htaccess`
access_log off; # Optional: Don't log access to assets
location ~ \.woff2?$ {
expires 7d; # Cache-Control policy borrowed from `.htaccess`
location /remote {
return 301 /remote.php$request_uri;
location / {
try_files $uri $uri/ /index.php$request_uri;
Thank you!
