version: Nextcloud Hub 8 (29.0.1)
The File Access control option does not appear in the flow configuration as an option. I only have the default “Write to conversation” flow.
How can I access the file access control functionality?
I guess the file access control app is disabled/ not installed?
No, it is installed and enabled.
I just tested the same thing on another Instance of mine with version 28.0.3 and the same problem.
There I also have the automatic tagging enabled and that option shows up - but not the file access control option.
This one:
I must be doing something wrong… I have just checked and it also does not work in an old nextcloud installation v20.0.11 that I have.
Here is what I do:
As the administrator I go to: (click on account image top right)
I have deactivated all other apps and no matter which flow plugin I install none of them show up.
I have also checked nextcloud.log and there are no errors there.
There are two “Flow” items on the left… (!)
a personal Flow option (no block file access)
a administrative Flow option (block file access) yay!
