Nextcloud does not start after update to 7.12.1
Hi all.
I stopped containers and hit update. i should not have done this bacause containers do not start anymore. (Database and Redis runnung, rest not)
ill paste the log down here.
hot to fix that ?
(backup also fails but errorlog ist empty/nothing displayed)
log:
0
Message: Client error: `POST http://localhost/v1.41/containers/nextcloud-aio-nextcloud/start` resulted in a `400 Bad Request` response:
{"message":"failed to create task for container: failed to create shim task: OCI runtime create failed: runc create fail (truncated...)
File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
3
Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
#1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::GuzzleHttp\{closure}(Object(GuzzleHttp\Psr7\Response))
#2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
#3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::GuzzleHttp\Promise\{closure}()
#4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
#5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
#6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
#7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
#8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
#9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(189): GuzzleHttp\Promise\Promise->wait()
#10 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/ClientTrait.php(95): GuzzleHttp\Client->request('POST', 'http://localhos...', Array)
#11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(189): GuzzleHttp\Client->post('http://localhos...')
#12 /var/www/docker-aio/php/src/Controller/DockerController.php(57): AIO\Docker\DockerActionManager->StartContainer(Object(AIO\Container\Container))
#13 /var/www/docker-aio/php/src/Controller/DockerController.php(33): AIO\Controller\DockerController->PerformRecursiveContainerStart('nextcloud-aio-n...', true)
#14 /var/www/docker-aio/php/src/Controller/DockerController.php(202): AIO\Controller\DockerController->PerformRecursiveContainerStart('nextcloud-aio-a...', true)
#15 /var/www/docker-aio/php/src/Controller/DockerController.php(182): AIO\Controller\DockerController->startTopContainer(true)
#16 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(38): AIO\Controller\DockerController->StartContainer(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(358): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#18 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#19 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#20 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(315): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#21 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(68): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
#22 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#23 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#24 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#25 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#26 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#28 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#29 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#30 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#31 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#32 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#33 /var/www/docker-aio/php/public/index.php(185): Slim\App->run()
#34 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
Hi, I found this: "failed to create shim task: OCI runtime create failed" - Google-haku
i simply hit update and it does not work any longer
im do not speak english very good and i dont even understand that half of the google-results you posted.
i changed form normal nextcloud to the docker-AIO because the updates of the normal nextcloud always led to probelems (new pho version, different syntax…) and now the AIO does the same.
i really do not know what to do now.
This is not caused by AIO but by docker. You might try to restart your server and check if that fixes things.
the docker worked fine before the update
rebootiung the host didnt have anny effect and nextaio restarted fine.
after the update of the AIO it does not work any longer and you really do not think that this was caused by the update ???
anyway, i already did and apt update && apt upgrade on the server and rebootet afterwards.
i also tried to start the containers using potrainer, what didnt work out neither.
In the AIO it still says there are updates for the containers available. is there a way to update them without using the AIO interface ?
FYI
i deleted all containes/images/volumes and all data of course
afterwards i ran docker again and installation run through without any errors. also backups work fine again.
so the problems before were defenetely caused by the AIO update and not by anything else on the host, because nothing changed over there.
this is no complain, this are just facts. maybe it helps for the future.
