I have an external storage that is connected by smb on a Windowsshare. If it is changed externaly (eg with my Scanner that puts there some pdf) it will not be recognized by Nextcloud.
Can you help me to fix that?
- Copy Files with Windows to the Nextcloud Share directly over SMB and not Nextcloud (or E.G. the Scanner sends a File to the smb-Share)
- The Files are not shown in Nextcloud
{"reqId":"JMAFQKR95iWfRHVKyonh","level":3,"time":"2024-05-17T06:42:14+00:00","remoteAddr":"80.131.147.148","user":"471AF5F4-0AD5-40D6-A2DB-BA9120CB7B74","app":"no app in context","method":"POST","url":"/ocs/v2.php/apps/files/api/v1/templates/create","message":"Ungültiger Pfad","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/124.0.0.0 Safari/537.36 Edg/124.0.0.0","version":"28.0.3.2","exception":{"Exception":"OCP\\Files\\GenericFileException","Message":"Ungültiger Pfad","Code":0,"Trace":[{"file":"/var/www/nextcloud/apps/files/lib/Controller/TemplateController.php","line":80,"function":"createFromTemplate","class":"OC\\Files\\Template\\TemplateManager","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":230,"function":"create","class":"OCA\\Files\\Controller\\TemplateController","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php","line":137,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":315,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/ocs/v1.php","line":65,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/ocs/v2.php","line":23,"args":["/var/www/nextcloud/ocs/v1.php"],"function":"require_once"}],"File":"/var/www/nextcloud/lib/private/Files/Template/TemplateManager.php","Line":159,"message":"Ungültiger Pfad","exception":[],"CustomMessage":"Ungültiger Pfad"},"id":"66470372b1209"}
'instanceid' => 'oce8ygchhza0',
'passwordsalt' => 'xxxxxx',
'secret' => 'xxxxxx',
0 => 'nextcloud',
1 => 'xxxx',
2 => 'xxxx',
3 => 'xxxx',
'version' => '28.0.3.2',
'overwrite.cli.url' => 'https://nextcloud',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'xxxxx',
'trusted_proxies' =>
0 => 'nextcloud',
1 => '192.168.168.25',
2 => 'xxxx',
3 => 'xxxx',
4 => '192.168.168.41',
5 => '192.168.168.24',
7 => 'xxxx',
'updater.secret' => 'xxxx'
'mail_smtpmode' => 'smtp',
'loglevel' => 2,
'theme' => '',
'memories.exiftool' => '/var/www/nextcloud/apps/memories/bin-ext/exiftool-amd$'
'memories.vod.path' => '/var/www/nextcloud/apps/memories/bin-ext/go-vod-amd64$'
'memories.index.mode' => '2',
'app_install_overwrite' =>
0 => 'cfg_share_links',
'memcache.local' => '\OC\Memcache\APCu',
The Access or Error?
