Hi community,
I hope this message finds you well. I am trying to install Nextcloud using Docker on a system that already has Virtualmin (Apache stack) installed. Could anyone guide me on the steps to achieve this successfully? I don’t know at the moment in which folders I have to put all the files.
When I create a new website for example, it creates always a new folder in the /home directory followed by the username which Virtualmin creates. Thinking like how it works, should I put the files into /home/nextcloud/ directory?
Thank you in advance for your help.
José Dean
