Nextcloud Docker-Rootless Nginx Proxy Forward Remote IP
I am currently running nextcloud, homeassistant and nginx in an docker container in Docker Rootless.
The nextcloud is located at /nextcloud and home assistant at /
My problem is that I can’t get it to work to forward the real remote IP adress from outside. The brute force protection slows down or fully blocks the login because the logins are all from the 172.16.0.1 gateway IP.
The network adapter is configured in ‘bridge’ mode.
I attached my ‘docker-compose.yml’ and my sites-available file.
I believe I need like a specific network adapter or something like that?
Also I had the idea to install nginx on the host and forward the traffic to the container.
Thank you for your help. I am also open for security improvements.
Docker-Compose
services:
  homeassistant:
    container_name: homeassistant
    image: "ghcr.io/home-assistant/home-assistant:stable"
    cap_add:
      - NET_ADMIN
      - NET_RAW
    volumes:
      - /home/max/docker/homeassistant/config:/config:rw
      - /etc/localtime:/etc/localtime:ro
      - /run/dbus:/run/dbus:ro
    restart: unless-stopped
    security_opt:
      - no-new-privileges:true
    networks:
      - internal_network
  nginx:
    image: nginx:latest
    container_name: nginx
    security_opt:
    #cap_drop:
    #  - ALL
    ports:
      - "8443:8443"
    volumes:
      - /home/max/docker/nginx/nginx.conf:/etc/nginx/nginx.conf:ro
      - /home/max/docker/nginx/html:/usr/share/nginx/html:ro
      - /home/max/docker/nginx/conf.d:/etc/nginx/conf.d:ro
      - /home/max/docker/nginx/certs:/etc/nginx/certs:ro
      - /home/max/docker/nginx/sites-available:/etc/nginx/sites-available:ro
      - /home/max/docker/nginx/sites-available:/etc/nginx/sites-enabled:ro
      - /home/max/docker/nginx/logs:/tmp/logs:rw
    networks:
      - internal_network
  nextclouddb:
    image: mariadb:latest
    container_name: nextclouddb
    restart: always
    volumes:
      - /home/max/docker/mariadb/nextcloud:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=
      - MYSQL_DATABASE=
      - MYSQL_USER=
      - MYSQL_PASSWORD=
      - MYSQL_HOST=
    networks:
      - internal_network
  nextcloud:
    image: nextcloud:latest
    restart: always
    depends_on:
      - nextclouddb
    volumes:
      - /home/max/docker/nextcloud:/var/www/html:rw
    environment:
      - TRUSTED_DOMAINS=
      - OVERWRITEWEBROOT=/nextcloud
      - DB_HOST=
      - MYSQL_HOST=
      - MYSQL_DATABASE=
      - MYSQL_USER=
      - MYSQL_PASSWORD=
      - ADMIN_USER=Admin
      - ADMIN_PASSWORD=
      - TRUSTED_PROXIES=172.18.0.0/16
      - TRUSTED_DOMAINS=
    networks:
      - internal_network
networks:
  internal_network:
    driver: bridge
Sites-available file
server {
    listen 8443 ssl;
    http2 on;
    server_name example;
    # Proxy configuration Docker-Rootless
    set_real_ip_from 172.18.0.0/16;
    real_ip_header proxy_protocol;
    proxy_set_header X-Forwarded-For $remote_addr;
    # SSL configuration
    ssl_certificate /etc/nginx/certs/fullchain.pem;
    ssl_certificate_key /etc/nginx/certs/privkey.pem;
    ssl_dhparam /etc/nginx/certs/dhparams.pem;
    ssl_protocols TLSv1.2 TLSv1.3;
    ssl_prefer_server_ciphers on;
    ssl_ciphers 'TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384';
    ssl_ecdh_curve secp384r1;
    ssl_session_timeout 10m;
    ssl_session_cache shared:SSL:10m;
    ssl_session_tickets off;
    ssl_stapling on;
    ssl_stapling_verify on;
    # Cache settings
    proxy_buffer_size 128k;
    proxy_buffers 4 256k;
    proxy_busy_buffers_size 256k;
    proxy_max_temp_file_size 0;
    # error page request limit
    error_page 503 /rate_limit_error.html;
    location /rate_limit_error.html {
    root /usr/share/nginx/html;
        internal;
# Security settings
    # General Content-Security-Policy
    add_header Content-Security-Policy "default-src 'self'; img-src 'self' http://192.168.178.57; script-src 'self' 'unsafe-inline' 'unsafe-eval'; style-src 'self' 'unsafe-inline'; img-src 'self' data: 192.168.178.57; font-src 'self'; connect-src 'self' wss ws: https: 192.168.178.57; frame-ancestors 'self' https://example.net; form-action 'self'; manifest-src 'self';" always;
    # HTTP header for Cache-Control
    add_header Cache-Control "public, max-age=31536000, immutable" always;
    # X-Frame Options
    # HTTP Only
    add_header Strict-Transport-Security "max-age=31536000; includeSubDomains; preload" always;
    # Other headers
    add_header Referrer-Policy "strict-origin-when-cross-origin";
# Homeassistant configs
    # Config Frontend
    location / {
        limit_req zone=req_limit_per_ip burst=40 nodelay;
        add_header Cache-Control "no-store, no-cache, must-revalidate" always;
        proxy_pass http://homeassistant:8123;
        proxy_set_header Host $host;
        proxy_set_header Connection "upgrade";
        # Deactivate cache for homeassistant
        proxy_cache off;
        proxy_no_cache 1;
        proxy_cache_bypass 1;
    # Config API
    location /api/ {
        limit_req zone=req_limit_per_ip burst=80 nodelay;
        add_header X-Frame-Options "SAMEORIGIN";
        proxy_http_version 1.1;
        # Deactivate cache for homeassistant api
        proxy_cache off;
        proxy_no_cache 1;
# Nextcloud configs
    # Redirect /nextcloud to /nextcloud/
    location = /nextcloud {
       return 301 $scheme://$host/nextcloud/;
    # Nextcloud Frontend
    location /nextcloud/ {
       limit_req zone=req_limit_per_ip burst=200;
       proxy_pass http://nextcloud:80/;
       proxy_set_header X-Forwarded-Proto https;
       # Deactivate cache for Nextcloud
       proxy_cache off;
       proxy_no_cache 1;
       client_max_body_size 100M;
       add_header Cache-Control "no-store, no-cache, must-revalidate, proxy-revalidate" always;
   # Redirects for CalDAV and CardDAV
    location /.well-known/carddav {
       return 301 $scheme://$host/nextcloud/remote.php/dav;
    location /.well-known/caldav {
Please review 101: reverse proxy and follow many threads tagged real-ip
