I have run
docker exec --user www-data cloud_app php occ fulltextsearch:test
docker exec --user www-data cloud_app php occ fulltextsearch:check
and there seem to be no problem (logs attached at the bottom).
Then
docker exec --user www-data cloud_app php occ fulltextsearch:index
No problem either. Yet after re-index full text search list is partial and missing many PDF and ODS. Strange enough, some time ago that WORKED.
# docker exec --user www-data cloud_app php occ fulltextsearch:test
.Testing your current setup:
Creating mocked content provider. ok
Testing mocked provider: get indexable documents. (2 items) ok
Loading search platform. (Elasticsearch) ok
Testing search platform. ok
Locking process ok
Removing test. ok
Pausing 3 seconds 1 2 3 ok
Initializing index mapping. ok
Indexing generated documents. ok
Retreiving content from a big index (license). (size: 32386) ok
Comparing document with source. ok
Searching basic keywords:
- 'test' (result: 1, expected: ["simple"]) ok
- 'document is a simple test' (result: 2, expected: ["simple","license"]) ok
- '"document is a test"' (result: 0, expected: []) ok
- '"document is a simple test"' (result: 1, expected: ["simple"]) ok
- 'document is a simple -test' (result: 1, expected: ["license"]) ok
- 'document is a simple +test' (result: 1, expected: ["simple"]) ok
- '-document is a simple test' (result: 0, expected: []) ok
- 'document is a simple +test +testing' (result: 1, expected: ["simple"]) ok
- 'document is a simple +test -testing' (result: 0, expected: []) ok
- 'document is a +simple -test -testing' (result: 0, expected: []) ok
- '+document is a simple -test -testing' (result: 1, expected: ["license"]) ok
- 'document is a +simple -license +testing' (result: 1, expected: ["simple"]) ok
Updating documents access. ok
Searching with group access rights:
- 'license' - [] - (result: 0, expected: []) ok
- 'license' - ["group_1"] - (result: 1, expected: ["license"]) ok
- 'license' - ["group_1","group_2"] - (result: 1, expected: ["license"]) ok
- 'license' - ["group_3","group_2"] - (result: 1, expected: ["license"]) ok
- 'license' - ["group_3"] - (result: 0, expected: []) ok
Searching with share rights:
- 'license' - notuser - (result: 0, expected: []) ok
- 'license' - user2 - (result: 1, expected: ["license"]) ok
- 'license' - user3 - (result: 1, expected: ["license"]) ok
Removing test. ok
Unlocking process ok
# docker exec --user www-data cloud_app php occ fulltextsearch:check
Full text search 23.0.0
- Search Platform:
Elasticsearch 23.0.0 (Selected)
"elastic_host": [
"http://elasticsearch:9200"
"elastic_index": "fts_index",
"fields_limit": "10000",
"es_ver_below66": "0",
"analyzer_tokenizer": "standard"
- Content Providers:
Files 23.0.0
"files_local": "1",
"files_external": "0",
"files_group_folders": "1",
"files_encrypted": "0",
"files_federated": "0",
"files_size": "20",
"files_pdf": "1",
"files_office": "1",
"files_image": "0",
"files_audio": "0"
