example
longer
example
here
Nextcloud version (eg, 20.0.5): 25.0.4
Operating system and version (eg, Ubuntu 20.04): Unraid
Apache or nginx version (eg, Apache 2.4.25): nginx docker
PHP version (eg, 7.4): linuxserver.io docker
- Restart the container. It starts and becomes responsive, but immeadiatly it starts to eat RAM.
[PHP] Error: Error: require_once(/config/www/nextcloud/apps/mail/vendor/composer/autoload_real.php): Failed to open stream: No such file or directory at /config/www/nextcloud/apps/mail/vendor/autoload.php#23 at <<closure>>
0. /config/www/nextcloud/apps/mail/vendor/autoload.php line 23
OC\Log\ErrorHandler::onError()
1. /config/www/nextcloud/apps/mail/vendor/autoload.php line 23
require_once()
2. /config/www/nextcloud/apps/mail/lib/AppInfo/Application.php line 82
include_once("/config/www/nex ... p")
3. /config/www/nextcloud/lib/composer/composer/ClassLoader.php line 571
include("/config/www/nex ... p")
4. /config/www/nextcloud/lib/composer/composer/ClassLoader.php line 428
Composer\Autoload\includeFile()
5. <<closure>>
Composer\Autoload\ClassLoader->loadClass()
6. /config/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php line 126
class_exists()
7. /config/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php line 91
OC\AppFramework\Bootstrap\Coordinator->registerApps()
8. /config/www/nextcloud/lib/base.php line 671
OC\AppFramework\Bootstrap\Coordinator->runInitialRegistration()
9. /config/www/nextcloud/lib/base.php line 1144
OC::init()
10. /config/www/nextcloud/remote.php line 119
require_once("/config/www/nextcloud/lib/base.php")
PROPFIND /remote.php/dav/files/qw3r7yju4n/
from 192.168.1.1 at 2023-04-11T21:06:29+00:00
[mail] Fatal: Error: Failed opening required '/config/www/nextcloud/apps/mail/vendor/composer/autoload_real.php' (include_path='/config/www/nextcloud/3rdparty/pear/archive_tar:/config/www/nextcloud/3rdparty/pear/console_getopt:/config/www/nextcloud/3rdparty/pear/pear-core-minimal/src:/config/www/nextcloud/3rdparty/pear/pear_exception:/config/www/nextcloud/apps') at <<closure>>
0. /config/www/nextcloud/apps/mail/lib/AppInfo/Application.php line 82
include_once()
1. /config/www/nextcloud/lib/composer/composer/ClassLoader.php line 571
2. /config/www/nextcloud/lib/composer/composer/ClassLoader.php line 428
3. <<closure>>
4. /config/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php line 126
class_exists()
5. /config/www/nextcloud/lib/private/AppFramework/Bootstrap/Coordinator.php line 91
6. /config/www/nextcloud/lib/base.php line 671
7. /config/www/nextcloud/lib/base.php line 1144
OC::init()
8. /config/www/nextcloud/remote.php line 119
'datadirectory' => '/data',
'instanceid' => 'ocqwmvidm6vw',
'passwordsalt' => 'REPLACEME',
'secret' => 'REPLACEME',
0 => 'REPLACEME',
1 => 'mydomain.com',
'default_phone_region' => 'US',
'version' => '25.0.4.1',
'overwrite.cli.url' => 'https://mydomain.com',
'overwritehost' => 'mydomain.com',
'overwritprotocol' => 'https',
'dbname' => 'REPLACEME',
'dbhost' => 'REPLACEME',
'dbuser' => 'REPLACEME',
'dbpassword' => 'REPLACEME',
'mail_smtpmode' => 'smtp',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.gmail.com',
'mail_smtpsecure' => 'tls',
'mail_smtpport' => '587',
'mail_from_address' => 'REPLACEME',
'mail_domain' => 'REPLACEME',
'mail_smtpname' => 'REPLACEME',
'mail_smtppassword' => 'REPLACEME',
'loglevel' => 2,
'updater.secret' => 'REPLACEME',
Log is empty```
PASTE HERE
Output errors in nextcloud.log in /var/www/ or as admin user in top right menu, filtering for errorTE HEREs. Use a pastebin service if necessary.
No logs located there in the contatiner
