Georg
July 28, 2016, 7:19pm
#1
Hi there,
i am new to Nextcloud. I switched from using BitTorrentSync two weeks ago or so. It runs on my Raspberry Pi with apache + mysql and the data stored on a USB Flash Drive. BitTorrentSync worked fine for around a year and Nextcloud worked for a week just fine. But now it disconnects my USB Drive everytime it tries to open a file from it. If i try to access it over SSH it gives the error ‘Transport endpoint is not connected’ after nextcloud tried to access a file. If i don’t issue a Nextcloud file access i can access the USB Drive just fine and read/write files. The USB Stick is formatted as exfat. Another strange thing is, Nextcloud seems to not print out a logfile. There is a ‘owncloud.log’ file in the ‘data’ directory, but it ownly contains four old log entries. I didnt’t change the log directory manually.
Can anyone give an advise? Should i post some other logfiles? Or just reinstall it?
Thx for any help
Rello
July 28, 2016, 7:45pm
#2
Is your data/ on rhe flashdrive ?
Because when diconnecting this would be an issue for the log file
Or did you mount in debian and access it via “local storage”?
Is the drive still mounted?
What about debian syslog?
Is exFAT the issue? I thought exFAT was not that great in Linux…just a thought.
I made my flash drive an EXT4 volume for my Raspberry Pi. Here’s how I did it, see if you can find a spot where you may have done it differently. My setup has been running stable since the day Nextcloud was released
As I said, EXT4 volume on the flash drive
Made a directory with the path /media/www-data/nextcloud_data
Gave www-data user recursive ownership over that directory
Mount my flash drive to /media/www-data/nextcloud_data
When I originally set up Nextcloud, I pointed my data directory to that
My only thing is when I reboot I need to manually mount the device to this directory each time for the www-data user
Georg
July 30, 2016, 11:00am
#4
Oh god how stupid. I didn’t realize that the /data directory where the logfiles should be is the data directory where all the files are stored. *facepalm
Okay thats the cause of the “missing” logfile. I tried to open a file with nextcloud just now, but i forgot to copy the content of the nextcloud logfile befor it. Now the USB drive is disconnected and i am not at home over the weekend so i cannot reconnect it. *another facepalm XD
Running mount doesn’t work. I have to pull out the USB drive and put it back in. Maybe i am just to stupid :D.
But here is my syslog with the error message (after nextcloud access) at the end. Maybe it is a problem with exfat introduced with jessie, because i updated to jessie right before i installed nextcloud, but then why did it work for a week?
Thanks for your help Rello and stratacast.
Jul 29 06:39:01 raspberrypi CRON[28607]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 07:09:01 raspberrypi CRON[29013]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 07:17:01 raspberrypi CRON[29153]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 07:39:01 raspberrypi CRON[29434]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 08:09:01 raspberrypi CRON[29838]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 08:17:01 raspberrypi CRON[29978]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 08:39:01 raspberrypi CRON[30259]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 09:09:01 raspberrypi CRON[30664]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 09:17:01 raspberrypi CRON[30806]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 09:39:01 raspberrypi CRON[31087]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 10:09:01 raspberrypi CRON[31494]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 10:17:01 raspberrypi CRON[31636]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 10:39:01 raspberrypi CRON[31917]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 11:09:01 raspberrypi CRON[32323]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 11:17:01 raspberrypi CRON[32464]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 11:39:01 raspberrypi CRON[32744]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 12:09:01 raspberrypi CRON[699]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 12:17:01 raspberrypi CRON[851]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 12:39:01 raspberrypi CRON[1153]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 13:09:01 raspberrypi CRON[1563]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 13:17:01 raspberrypi CRON[1704]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 13:39:01 raspberrypi CRON[1985]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 14:09:01 raspberrypi CRON[2391]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 14:17:01 raspberrypi CRON[2533]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 14:39:01 raspberrypi CRON[2815]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 15:09:01 raspberrypi CRON[3220]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 15:17:01 raspberrypi CRON[3361]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 15:21:59 raspberrypi mount.exfat: invalid cluster number 0 Jul 29 15:39:02 raspberrypi CRON[3648]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 16:09:01 raspberrypi CRON[4059]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 16:17:01 raspberrypi CRON[4203]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 16:39:01 raspberrypi CRON[4486]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 17:09:01 raspberrypi CRON[4893]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 17:17:01 raspberrypi CRON[5036]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 17:39:01 raspberrypi CRON[5316]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 18:05:06 raspberrypi systemd[1]: Starting user-1000.slice. Jul 29 18:05:06 raspberrypi systemd[1]: Created slice user-1000.slice. Jul 29 18:05:06 raspberrypi systemd[1]: Starting Session c5 of user pi. Jul 29 18:05:06 raspberrypi systemd[1]: Started Session c5 of user pi. Jul 29 18:05:06 raspberrypi systemd[1]: Starting User Manager for UID 1000... Jul 29 18:05:07 raspberrypi systemd[5680]: Starting Paths. Jul 29 18:05:07 raspberrypi systemd[5680]: Reached target Paths. Jul 29 18:05:07 raspberrypi systemd[5680]: Starting Timers. Jul 29 18:05:07 raspberrypi systemd[5680]: Reached target Timers. Jul 29 18:05:07 raspberrypi systemd[5680]: Starting Sockets. Jul 29 18:05:07 raspberrypi systemd[5680]: Reached target Sockets. Jul 29 18:05:07 raspberrypi systemd[5680]: Starting Basic System. Jul 29 18:05:07 raspberrypi systemd[5680]: Reached target Basic System. Jul 29 18:05:07 raspberrypi systemd[5680]: Starting Default. Jul 29 18:05:07 raspberrypi systemd[5680]: Reached target Default. Jul 29 18:05:07 raspberrypi systemd[5680]: Startup finished in 96ms. Jul 29 18:05:07 raspberrypi systemd[1]: Started User Manager for UID 1000. Jul 29 18:08:12 raspberrypi systemd[1]: Stopping User Manager for UID 1000... Jul 29 18:08:12 raspberrypi systemd[5680]: Stopping Default. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopped target Default. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopping Basic System. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopped target Basic System. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopping Paths. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopped target Paths. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopping Timers. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopped target Timers. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopping Sockets. Jul 29 18:08:12 raspberrypi systemd[5680]: Stopped target Sockets. Jul 29 18:08:12 raspberrypi systemd[5680]: Starting Shutdown. Jul 29 18:08:12 raspberrypi systemd[5680]: Reached target Shutdown. Jul 29 18:08:12 raspberrypi systemd[5680]: Starting Exit the Session... Jul 29 18:08:12 raspberrypi systemd[5680]: Received SIGRTMIN+24 from PID 5743 (kill). Jul 29 18:08:12 raspberrypi systemd[1]: Stopped User Manager for UID 1000. Jul 29 18:08:13 raspberrypi systemd[1]: Stopping user-1000.slice. Jul 29 18:08:13 raspberrypi systemd[1]: Removed slice user-1000.slice. Jul 29 18:09:01 raspberrypi CRON[5762]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 18:17:01 raspberrypi CRON[5904]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 18:25:17 raspberrypi kernel: [156628.471593] usb 1-1.4: USB disconnect, device number 14 Jul 29 18:25:17 raspberrypi systemd[1]: Unmounting /media/dropbox... Jul 29 18:25:18 raspberrypi systemd[1]: Unmounted /media/dropbox. Jul 29 18:25:20 raspberrypi kernel: [156631.520543] usb 1-1.4: new high-speed USB device number 15 using dwc_otg Jul 29 18:25:20 raspberrypi kernel: [156631.647104] usb 1-1.4: New USB device found, idVendor=0951, idProduct=1665 Jul 29 18:25:20 raspberrypi kernel: [156631.654202] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3 Jul 29 18:25:20 raspberrypi kernel: [156631.661711] usb 1-1.4: Product: DataTraveler 2.0 Jul 29 18:25:20 raspberrypi kernel: [156631.666452] usb 1-1.4: Manufacturer: Kingston Jul 29 18:25:20 raspberrypi kernel: [156631.670983] usb 1-1.4: SerialNumber: XXXXXXXXXXXXXXXXXXXXXXXX Jul 29 18:25:20 raspberrypi kernel: [156631.689408] usb-storage 1-1.4:1.0: USB Mass Storage device detected Jul 29 18:25:20 raspberrypi kernel: [156631.697808] scsi host11: usb-storage 1-1.4:1.0 Jul 29 18:25:21 raspberrypi mtp-probe: checking bus 1, device 15: "/sys/devices/platform/soc/20980000.usb/usb1/1-1/1-1.4" Jul 29 18:25:21 raspberrypi mtp-probe: bus: 1, device: 15 was not an MTP device Jul 29 18:25:22 raspberrypi kernel: [156632.724249] scsi 11:0:0:0: Direct-Access Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 4 Jul 29 18:25:22 raspberrypi kernel: [156632.740444] sd 11:0:0:0: Attached scsi generic sg0 type 0 Jul 29 18:25:24 raspberrypi kernel: [156634.857472] sd 11:0:0:0: [sda] 61457664 512-byte logical blocks: (31.5 GB/29.3 GiB) Jul 29 18:25:24 raspberrypi kernel: [156634.865977] sd 11:0:0:0: [sda] Write Protect is off Jul 29 18:25:24 raspberrypi kernel: [156634.871143] sd 11:0:0:0: [sda] Mode Sense: 23 00 00 00 Jul 29 18:25:24 raspberrypi kernel: [156634.879620] sd 11:0:0:0: [sda] No Caching mode page found Jul 29 18:25:24 raspberrypi kernel: [156634.885283] sd 11:0:0:0: [sda] Assuming drive cache: write through Jul 29 18:25:24 raspberrypi kernel: [156634.926200] sda: sda1 Jul 29 18:25:24 raspberrypi kernel: [156634.943945] sd 11:0:0:0: [sda] Attached SCSI removable disk Jul 29 18:25:26 raspberrypi systemd[1]: Found device DataTraveler_2.0 KINGSTON. Jul 29 18:25:26 raspberrypi systemd[1]: Found device DataTraveler_2.0 KINGSTON. Jul 29 18:25:26 raspberrypi systemd[1]: Found device DataTraveler_2.0 KINGSTON. Jul 29 18:25:26 raspberrypi systemd[1]: Found device DataTraveler_2.0 KINGSTON. Jul 29 18:25:26 raspberrypi systemd[1]: Found device DataTraveler_2.0 KINGSTON. Jul 29 18:25:26 raspberrypi systemd[1]: Mounting /media/dropbox... Jul 29 18:25:27 raspberrypi mount[6034]: FUSE exfat 1.1.0 Jul 29 18:25:27 raspberrypi mount.exfat: volume was not unmounted cleanly Jul 29 18:25:27 raspberrypi systemd[1]: Mounted /media/dropbox. Jul 29 18:25:27 raspberrypi mount[6034]: WARN: volume was not unmounted cleanly. Jul 29 18:39:01 raspberrypi CRON[6204]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 19:09:01 raspberrypi CRON[6612]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 19:17:01 raspberrypi CRON[6754]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 19:39:01 raspberrypi CRON[7034]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 20:09:01 raspberrypi CRON[7441]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 20:17:01 raspberrypi CRON[7584]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 20:39:01 raspberrypi CRON[7866]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 21:09:01 raspberrypi CRON[8272]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 21:17:01 raspberrypi CRON[8414]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 21:39:01 raspberrypi CRON[8696]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 22:09:01 raspberrypi CRON[9102]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 22:17:01 raspberrypi CRON[9244]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 22:39:01 raspberrypi CRON[9526]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 23:09:01 raspberrypi CRON[9933]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 29 23:10:28 raspberrypi systemd[1]: Starting Cleanup of Temporary Directories... Jul 29 23:10:28 raspberrypi systemd[1]: Started Cleanup of Temporary Directories. Jul 29 23:17:01 raspberrypi CRON[10079]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 29 23:39:01 raspberrypi CRON[10359]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 00:09:01 raspberrypi CRON[10768]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 00:17:01 raspberrypi CRON[10911]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 00:39:01 raspberrypi CRON[11191]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 01:09:01 raspberrypi CRON[11598]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 01:17:01 raspberrypi CRON[11740]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 01:39:01 raspberrypi CRON[12021]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 02:09:02 raspberrypi CRON[12428]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 02:17:01 raspberrypi CRON[12570]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 02:39:01 raspberrypi CRON[12851]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 03:09:01 raspberrypi CRON[13257]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 03:17:02 raspberrypi CRON[13400]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 03:39:01 raspberrypi CRON[13680]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 04:09:01 raspberrypi CRON[14088]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 04:17:01 raspberrypi CRON[14230]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 04:39:02 raspberrypi CRON[14510]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 05:09:01 raspberrypi CRON[14918]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 05:17:01 raspberrypi CRON[15061]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 05:39:01 raspberrypi CRON[15341]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 06:09:01 raspberrypi CRON[15748]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 06:17:01 raspberrypi CRON[15890]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 06:25:01 raspberrypi CRON[16002]: (root) CMD (test -x /usr/sbin/anacron || ( cd / && run-parts --report /etc/cron.daily )) Jul 30 06:25:09 raspberrypi cracklib: no dictionary update necessary. Jul 30 06:25:13 raspberrypi systemd[1]: Reloading LSB: Apache2 web server. Jul 30 06:25:16 raspberrypi apache2[16140]: Reloading web server: apache2. Jul 30 06:25:16 raspberrypi systemd[1]: Reloaded LSB: Apache2 web server. Jul 30 06:39:01 raspberrypi CRON[16386]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 07:09:01 raspberrypi CRON[16793]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 07:17:01 raspberrypi CRON[16935]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 07:39:01 raspberrypi CRON[17217]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 08:09:01 raspberrypi CRON[17624]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 08:17:01 raspberrypi CRON[17766]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 08:39:01 raspberrypi CRON[18046]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 09:09:01 raspberrypi CRON[18453]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 09:17:01 raspberrypi CRON[18594]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 09:39:01 raspberrypi CRON[18874]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 10:09:01 raspberrypi CRON[19280]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 10:17:01 raspberrypi CRON[19422]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 10:39:01 raspberrypi CRON[19703]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 11:09:01 raspberrypi CRON[20109]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 11:17:01 raspberrypi CRON[20250]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 11:39:01 raspberrypi CRON[20532]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 11:55:31 raspberrypi systemd[1]: Starting user-1000.slice. Jul 30 11:55:31 raspberrypi systemd[1]: Created slice user-1000.slice. Jul 30 11:55:31 raspberrypi systemd[1]: Starting User Manager for UID 1000... Jul 30 11:55:31 raspberrypi systemd[1]: Starting Session c6 of user pi. Jul 30 11:55:32 raspberrypi systemd[1]: Started Session c6 of user pi. Jul 30 11:55:32 raspberrypi systemd[20778]: Starting Paths. Jul 30 11:55:32 raspberrypi systemd[20778]: Reached target Paths. Jul 30 11:55:32 raspberrypi systemd[20778]: Starting Timers. Jul 30 11:55:32 raspberrypi systemd[20778]: Reached target Timers. Jul 30 11:55:32 raspberrypi systemd[20778]: Starting Sockets. Jul 30 11:55:32 raspberrypi systemd[20778]: Reached target Sockets. Jul 30 11:55:32 raspberrypi systemd[20778]: Starting Basic System. Jul 30 11:55:32 raspberrypi systemd[20778]: Reached target Basic System. Jul 30 11:55:32 raspberrypi systemd[20778]: Starting Default. Jul 30 11:55:32 raspberrypi systemd[20778]: Reached target Default. Jul 30 11:55:32 raspberrypi systemd[20778]: Startup finished in 93ms. Jul 30 11:55:32 raspberrypi systemd[1]: Started User Manager for UID 1000. Jul 30 12:09:01 raspberrypi CRON[20990]: (root) CMD ( [ -x /usr/lib/php5/sessionclean ] && /usr/lib/php5/sessionclean) Jul 30 12:17:01 raspberrypi CRON[21139]: (root) CMD ( cd / && run-parts --report /etc/cron.hourly) Jul 30 12:28:34 raspberrypi mount.exfat: invalid cluster number 0
