Nextcloud custom webroot not affecting POST requests related to /custom_apps
    • NextCloud 32.0.3
    • Debian GNU/Linux 13 (trixie) x86_64
    • 2.5.65
    • nginx 29.4
    • 8.3.29
    • Yes
    • Initial Install
    • docker compose
NextCloud is running at a custom webroot (/nextcloud) behind nginx. I have the apps “Collabora Online - Built-in CODE Server” and “Nextcloud Office” installed. When attempting to edit documents with NextCloud office, the website sends a POST request to URL that does not have the correct webroot which 404s. Specifically, it attempts https://dserver/custom_apps/ instead of https://dserver/nextcloud/custom_apps/. After a few seconds the page says “Document loading failed”
Something similar happens in the Administration Settings > Office page with an iframe
Notable weird things I am doing:
  1. I am not using a TLD, I am only using dserver. This is fine for my use case because I am only running this on my home network.
  2. I am using self signed certs. I had to specify administration settings > office > Use Your Own Server > Disable Certification Verification = True
After I make that change, the radio button jumps back to “built-in Collabora” and it appears working according to according to settings page.
  1. Log into https://dserver/nextcloud/
  2. Attempt to edit “Welcome to Nextcloud Hub.docx”
  3. Observe editor failure
This may not be related, but I am including anyway
{"reqId":"PW9cMMSSVbLTNPoNu7KZ","level":2,"time":"2025-12-30T20:52:03+00:00","remoteAddr":"192.168.100.140","user":"admin","app":"PHP","method":"GET","url":"/nextcloud/index.phpapps/categories","message":"Trying to access array offset on null at /var/www/html/lib/private/App/AppStore/Fetcher/Fetcher.php#177","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0","version":"32.0.3.2","data":{"app":"PHP"},"id":"6954453dcfff4"}
{"reqId":"mrLTe19KJO3KahrvplSH","level":3,"time":"2025-12-29T21:35:34+00:00","remoteAddr":"192.168.100.140","user":"admin","app":"richdocuments","method":"GET","url":"/nextcloud/index.phpdocuments/settings/check","message":"cURL error 28: Connection timed out after 5002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://lool2.friprogramvarusyndikatet.se/hosting/discovery","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0","version":"32.0.3.2","exception":{"Exception":"GuzzleHttp\\Exception\\ConnectException","Message":"cURL error 28: Connection timed out after 5002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://lool2.friprogramvarusyndikatet.se/hosting/discovery","Code":0,"Trace":[{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":205,"function":"createRejection","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","line":157,"function":"finishError","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[{"__class__":"GuzzleHttp\\Handler\\CurlHandler"},"*** sensitive parameters replaced ***",{"__class__":"GuzzleHttp\\Handler\\CurlFactory"}]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlHandler.php","line":47,"function":"finish","class":"GuzzleHttp\\Handler\\CurlFactory","type":"::","args":[{"__class__":"GuzzleHttp\\Handler\\CurlHandler"},"*** sensitive parameters replaced ***",{"__class__":"GuzzleHttp\\Handler\\CurlFactory"}]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":142,"function":"__invoke","class":"GuzzleHttp\\Handler\\CurlHandler","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/DnsPinMiddleware.php","line":101,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/PrepareBodyMiddleware.php","line":35,"function":"OC\\Http\\Client\\{closure}","class":"OC\\Http\\Client\\DnsPinMiddleware","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":31,"function":"__invoke","class":"GuzzleHttp\\PrepareBodyMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/RedirectMiddleware.php","line":71,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Middleware.php","line":66,"function":"__invoke","class":"GuzzleHttp\\RedirectMiddleware","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/HandlerStack.php","line":75,"function":"GuzzleHttp\\{closure}","class":"GuzzleHttp\\Middleware","type":"::","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":333,"function":"__invoke","class":"GuzzleHttp\\HandlerStack","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":169,"function":"transfer","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***"]},{"file":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Client.php","line":189,"function":"requestAsync","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/lib/private/Http/Client/Client.php","line":206,"function":"request","class":"GuzzleHttp\\Client","type":"->","args":["*** sensitive parameters replaced ***","*** sensitive parameters replaced ***",{"verify":"/var/www/html/resources/config/ca-bundle.crt","timeout":5,"nextcloud":{"allow_local_address":true},"headers":{"User-Agent":"Nextcloud Server Crawler","Accept-Encoding":"gzip"},"synchronous":true}]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/DiscoveryService.php","line":61,"function":"get","class":"OC\\Http\\Client\\Client","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/CachedRequestService.php","line":74,"function":"sendRequest","class":"OCA\\Richdocuments\\Service\\DiscoveryService","type":"->","args":[{"__class__":"OC\\Http\\Client\\Client"}]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Service/ConnectivityService.php","line":28,"function":"fetch","class":"OCA\\Richdocuments\\Service\\CachedRequestService","type":"->","args":[]},{"file":"/var/www/html/custom_apps/richdocuments/lib/Controller/SettingsController.php","line":73,"function":"testDiscovery","class":"OCA\\Richdocuments\\Service\\ConnectivityService","type":"->","args":[{"__class__":"Symfony\\Component\\Console\\Output\\NullOutput"}]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":204,"function":"checkSettings","class":"OCA\\Richdocuments\\Controller\\SettingsController","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Richdocuments\\Controller\\SettingsController"},"checkSettings"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Richdocuments\\Controller\\SettingsController"},"checkSettings"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Richdocuments\\Controller\\SettingsController","checkSettings",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"richdocuments.settings.checksettings"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/richdocuments/settings/check"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/3rdparty/guzzlehttp/guzzle/src/Handler/CurlFactory.php","Line":275,"message":"cURL error 28: Connection timed out after 5002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://lool2.friprogramvarusyndikatet.se/hosting/discovery","exception":[],"CustomMessage":"cURL error 28: Connection timed out after 5002 milliseconds (see https://curl.haxx.se/libcurl/c/libcurl-errors.html) for https://lool2.friprogramvarusyndikatet.se/hosting/discovery"},"id":"6954453dd001e"}
{"reqId":"PW9cMMSSVbLTNPoNu7KZ","level":3,"time":"2025-12-30T20:52:03+00:00","remoteAddr":"192.168.100.140","user":"admin","app":"index","method":"GET","url":"/nextcloud/index.phpapps/categories","message":"array_map(): Argument #2 ($array) must be of type array, null given in file '/var/www/html/apps/settings/lib/Controller/AppSettingsController.php' line 286","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0","version":"32.0.3.2","exception":{"Exception":"Exception","Message":"array_map(): Argument #2 ($array) must be of type array, null given in file '/var/www/html/apps/settings/lib/Controller/AppSettingsController.php' line 286","Code":0,"Trace":[{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"listCategories"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AppSettingsController","listCategories",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"settings.appsettings.listcategories"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/apps/categories"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","Line":150,"Previous":{"Exception":"TypeError","Message":"array_map(): Argument #2 ($array) must be of type array, null given","Code":0,"Trace":[{"file":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","line":286,"function":"array_map","args":[{"__class__":"Closure"},null]},{"file":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","line":279,"function":"getAllCategories","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":204,"function":"listCategories","class":"OCA\\Settings\\Controller\\AppSettingsController","type":"->","args":[]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"listCategories"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[{"__class__":"OCA\\Settings\\Controller\\AppSettingsController"},"listCategories"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Settings\\Controller\\AppSettingsController","listCategories",{"__class__":"OC\\AppFramework\\DependencyInjection\\DIContainer"},{"_route":"settings.appsettings.listcategories"}]},{"file":"/var/www/html/lib/base.php","line":1061,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/settings/apps/categories"]},{"file":"/var/www/html/index.php","line":25,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/apps/settings/lib/Controller/AppSettingsController.php","Line":286},"message":"array_map(): Argument #2 ($array) must be of type array, null given in file '/var/www/html/apps/settings/lib/Controller/AppSettingsController.php' line 286","exception":[],"CustomMessage":"array_map(): Argument #2 ($array) must be of type array, null given in file '/var/www/html/apps/settings/lib/Controller/AppSettingsController.php' line 286"},"id":"6954502b45b9b"}
[getWopiUrl] https://dserver/nextcloud/index.php/apps/richdocuments/wopi/files/68_oc6n0a43q7vr url.js:28:10
POST
https://dserver/custom_apps/richdocumentscode/proxy.php?req=/browser/a246f9ab3c/cool.html?WOPISrc=https://dserver/nextcloud/index.php/apps/richdocuments/wopi/files/68_oc6n0a43q7vr&lang=en&closebutton=1&revisionhistory=1
[HTTP/1.1 404 Not Found 7ms]
Document loading failed due to timeout: Please check for failing network requests Office.vue:346:1
Ran this command right after refreshing the editor page in Firefox docker compose logs nginx | grep -i -e "next" -e "app" -e "404" | tail -n 50
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:26 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1068 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:29 +0000] "GET /nextcloud/apps/logreader/api/poll?lastReqId=zzVZZeIqp6lWDb6XeLrT HTTP/1.1" 200 22 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:29 +0000] "GET /nextcloud/apps/files/files/68?dir=/Documents&editing=false&openfile=true HTTP/1.1" 200 12563 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/apps/text/js/text-init.mjs?v=89e9d472-4 HTTP/1.1" 499 0 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/index.php/apps/files/preview-service-worker.js HTTP/1.1" 200 5271 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "REPORT /nextcloud/remote.php/dav/files/admin/ HTTP/1.1" 207 156 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/ocs/v2.php/apps/files/api/v1/folder-tree?path=%2F&depth=1 HTTP/1.1" 200 94 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "PROPFIND /nextcloud/remote.php/dav/files/admin/Documents/ HTTP/1.1" 207 1104 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/ocs/v2.php/apps/guests/api/v1/groups HTTP/1.1" 200 144 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/apps/viewer/js/previewUtils-DGR5aPfN.chunk.mjs.map HTTP/1.1" 200 821157 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/dist/files_sharing-files_sharing_tab.js.map?v=7b9139fb03fa6792e1a7 HTTP/1.1" 200 9600 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/ocs/v2.php/apps/recommendations/api/v1/recommendations HTTP/1.1" 200 398 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/dist/files-main.js.map?v=b1d0246571b3a07799ea HTTP/1.1" 200 1021025 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:30 +0000] "GET /nextcloud/dist/files-sidebar.js.map?v=921645b12f3be37b5bbe HTTP/1.1" 200 828168 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/apps/theming/icon/files?v=3d1daabe HTTP/1.1" 499 0 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/ocs/v2.php/apps/user_status/api/v1/user_status HTTP/1.1" 200 149 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "PUT /nextcloud/ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.1" 200 149 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/cron.php HTTP/1.1" 200 20 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/index.php/apps/files/preview-service-worker.js HTTP/1.1" 200 5271 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/dist/7883-7883.js.map?v=d2536c175df70a100c19 HTTP/1.1" 200 167243 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/ocs/v2.php/apps/notifications/api/v2/notifications HTTP/1.1" 200 81 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/apps/notifications/js/NotificationsApp-0V1-3XAR.chunk.mjs.map HTTP/1.1" 200 117935 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/apps/files/api/v1/views HTTP/1.1" 200 46 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/ocs/v2.php/apps/text/workspace?path=%2FDocuments HTTP/1.1" 200 163 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "PROPFIND /nextcloud/remote.php/dav/files/admin/Documents/Welcome%20to%20Nextcloud%20Hub.docx HTTP/1.1" 207 704 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/apps/viewer/js/viewer-main.mjs.map HTTP/1.1" 200 21003 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "PUT /nextcloud/apps/text/session/67/create HTTP/1.1" 200 424 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/custom_apps/richdocumentscode/proxy.php?status HTTP/1.1" 200 15 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "POST /nextcloud/apps/text/attachments HTTP/1.1" 200 22 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "PROPFIND /nextcloud/remote.php/dav/files/admin/Documents/Readme.md HTTP/1.1" 207 639 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "PROPFIND /nextcloud/remote.php/dav/files/admin/Documents/Welcome%20to%20Nextcloud%20Hub.docx/ HTTP/1.1" 207 700 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "POST /nextcloud/apps/richdocuments/token HTTP/1.1" 200 327 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 2098 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "POST /custom_apps/richdocumentscode/proxy.php?req=/browser/a246f9ab3c/cool.html?WOPISrc=https%3A%2F%2Fdserver%2Fnextcloud%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F68_oc6n0a43q7vr&lang=en&closebutton=1&revisionhistory=1 HTTP/1.1" 404 1167 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /api/config/custom.css HTTP/1.1" 200 0 "https://dserver/custom_apps/richdocumentscode/proxy.php?req=/browser/a246f9ab3c/cool.html?WOPISrc=https%3A%2F%2Fdserver%2Fnextcloud%2Findex.php%2Fapps%2Frichdocuments%2Fwopi%2Ffiles%2F68_oc6n0a43q7vr&lang=en&closebutton=1&revisionhistory=1" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/custom_apps/richdocuments/js/richdocuments-src_view_Viewer_vue.js.map?v=37ccf50bff71a24c7fc7 HTTP/1.1" 200 43414 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "GET /nextcloud/custom_apps/richdocuments/js/richdocuments-viewer.js.map?v=b27015f3fb6e1488400b HTTP/1.1" 200 607216 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:31 +0000] "POST /nextcloud/apps/text/session/67/push HTTP/1.1" 200 368 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:32 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1084 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:32 +0000] "GET /nextcloud/index.php/apps/files/preview-service-worker.js HTTP/1.1" 200 5271 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:33 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1084 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:34 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1084 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:36 +0000] "PUT /nextcloud/ocs/v2.php/apps/user_status/api/v1/heartbeat?format=json HTTP/1.1" 200 149 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:36 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1084 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:39 +0000] "GET /nextcloud/apps/logreader/api/poll?lastReqId=zzVZZeIqp6lWDb6XeLrT HTTP/1.1" 200 22 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:41 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1084 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx  | 192.168.100.140 - - [30/Dec/2025:22:06:47 +0000] "POST /nextcloud/apps/text/session/67/sync HTTP/1.1" 200 1084 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
nginx.conf
worker_processes 1;
events {
        worker_connections 1024;
http {
        server {
                listen 80;
                server_name dserver;
                return 301 https://dserver/;
        server {
                listen 443 ssl;
                include subfolders-enabled/*.conf;
                ssl_certificate     /etc/letsencrypt/server.crt;
                ssl_certificate_key /etc/letsencrypt/server.key;
                ssl_protocols TLSv1.2 TLSv1.3;
                ssl_ciphers HIGH:!aNULL:!MD5;
nextcloud.conf (nginx)
#location ^~ / {
#    return 302 $scheme://$host/jellyfin/;
location ^~ /nextcloud {
    return 302 $scheme://$host/nextcloud/;
location ^~ /nextcloud/ {
    # Proxy main traffic
    proxy_pass http://nextcloud:80/;
    proxy_set_header Host $host;
    # Security headers
    #add_header X-XSS-Protection "1; mode=block";
    #add_header X-Robots-Tag none;
    #add_header X-Download-Options noopen;
    add_header Referrer-Policy no-referrer;
    #add_header X-Frame-Options SAMEORIGIN;
    # Timeout settings for large file uploads
    proxy_read_timeout 3600s;
    proxy_send_timeout 3600s;
    proxy_connect_timeout 3600s;
    # HSTS (optional - uncomment if you're using HTTPS)
    add_header Strict-Transport-Security "max-age=31536000; includeSubDomains" always;
    # Increase max upload size (adjust as needed)
    client_max_body_size 10G;
# location ~ ^/nextcloud/(.*\.php)$ {
#    include fastcgi_params;
#    fastcgi_pass your_fastcgi_backend;  # Replace with your PHP-FPM backend
#    fastcgi_index index.php;
#    fastcgi_param SCRIPT_FILENAME $document_root$fastcgi_script_name;
# Deny access to sensitive files
#location ~ ^/(?:build|tests|config|lib|3rdparty|templates|data)(?:$|/) {
#    deny all;
docker-compose.xml (partial)
# NextCloud
#  redis:
#    image: redis:alpine
#    restart: always
#    networks:
#      - "ncnet"
  db:
    image: mariadb:lts
    container_name: nextcloud-compose-db
    restart: always
    command: --transaction-isolation=READ-COMMITTED
    volumes:
      - /srv/nextcoud/:/var/lib/mysql
    environment:
      - MYSQL_ROOT_PASSWORD=${DB_ROOT_PW}
      - MYSQL_PASSWORD=${DB_PW}
      - MYSQL_DATABASE=nextcloud
      - MYSQL_USER=${DB_USER}
    networks:
      - "ncnet"
  nextcloud:
    image: nextcloud
    restart: always
    depends_on:
 #     - redis
      - db
    volumes:
      - /etc/docker/nextcloud/:/var/www/html
    environment:
      - MYSQL_HOST=db
      - NEXTCLOUD_DEFAULT_PHONE_REGION=US
    networks:
      - "ncnet"
      - "net"
The output of occ config:list system
My understanding is that url in apps_pathsget appended to the value of overwritewebroot. Adding the webroot /nextcloudto htaccess.RewriteBase does not seem to have an impact.
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "upgrade.disable-web": true,
        "overwritewebroot": "\/nextcloud",
        "htaccess.RewriteBase": "\/",
        "htaccess.IgnoreFrontController": true,
            "dserver"
        "dbtype": "mysql",
        "version": "32.0.3.2",
        "overwrite.cli.url": "https:\/\/dserver\/nextcloud",
        "overwriteprotocol": "https",
        "mysql.utf8mb4": true,
        "config_preset": 2,
        "app_install_overwrite": [
            "breezedark"
        "defaultapp": "files",
        "check_for_working_wellknown_setup": false
The output of occ app:list
  - breezedark: 29.0.0
  - circles: 32.0.0
  - dav: 1.34.2
  - files: 2.4.0
  - files_external: 1.24.0
  - files_reminders: 1.5.0
  - files_sharing: 1.24.1
  - files_trashbin: 1.22.0
  - files_versions: 1.25.0
  - firstrunwizard: 5.0.0-dev.0
  - guests: 4.6.0
  - logreader: 5.0.0-dev.0
  - notifications: 5.0.0-dev.0
  - oauth2: 1.20.0
  - photos: 5.0.0-dev.1
  - privacy: 4.0.0-dev.0
  - profile: 1.1.0
  - provisioning_api: 1.22.0
  - richdocuments: 9.0.2
  - richdocumentscode: 25.4.702
  - serverinfo: 4.0.0-dev.0
  - settings: 1.15.1
  - sharebymail: 1.22.0
  - support: 4.0.0-dev.0
  - systemtags: 1.22.0
  - text: 6.0.1
  - theming: 2.7.0
  - updatenotification: 1.22.0
  - user_status: 1.12.0
  - viewer: 5.0.0-dev.0
  - webhook_listeners: 1.3.0
  - workflowengine: 2.14.0
  - activity: 5.0.0-dev.0 (installed 5.0.0-dev.0)
  - admin_audit: 1.22.0
  - app_api: 32.0.0 (installed 32.0.0)
  - comments: 1.22.0 (installed 1.22.0)
  - contactsinteraction: 1.13.1 (installed 1.13.1)
  - dashboard: 7.12.0 (installed 7.12.0)
  - encryption: 2.20.0
  - federation: 1.22.0 (installed 1.22.0)
  - google_synchronization: 4.1.0 (installed 4.1.0)
  - integration_google: 4.3.0 (installed 4.3.0)
  - nextcloud_announcements: 4.0.0-dev.0 (installed 4.0.0-dev.0)
  - survey_client: 4.0.0-dev.0 (installed 4.0.0-dev.0)
  - twofactor_totp: 14.0.0
  - user_ldap: 1.23.0
  - weather_status: 1.12.0 (installed 1.12.0)
Check the output of occ config:list richdocuments. I suspect public_wopi_url is where that’s coming from.
Here is the result of docker exec -it nextcloud-compose ./occ config:list richdocuments
    "apps": {
        "richdocuments": {
            "canonical_webroot": "\/nextcloud",
            "disable_certificate_verification": "yes",
            "doc_format": "ooxml",
            "enabled": "yes",
            "external_apps": "",
            "installed_version": "9.0.2",
            "public_wopi_url": "https:\/\/dserver",
            "types": "filesystem,prevent_group_restriction",
            "wopi_allowlist": "0.0.0.0\/0",
            "wopi_url": "https:\/\/dserver\/nextcloud\/custom_apps\/richdocumentscode\/proxy.php?req="
I updated the config with the command docker exec -it nextcloud-compose ./occ config:app:set richdocuments public_wopi_url --value https://dserver/nextcloud and reran the previous command to verify it was updated.
    "apps": {
        "richdocuments": {
            "enabled": "yes",
            "public_wopi_url": "https:\/\/dserver\/nextcloud",
            "wopi_callback_url": "",
I restarted the nextcloud docker container and tried again, but I am still getting the same 404 POST errors.
