i have a little Problem with my Nextcloud Instance. If i start a occ files:scan --all or files:scan username the System rootfs Storage runs to 100% (100 GB normally 2% used)
After Storage runs full the Operation stops with error and my DB stops with error (no space to write)
I use Proxmox and the Nextcloud is the Turnkey LXC Container Nextcloud of the Turnkey Repository.
Any idea how i can solve it?
Informations:
“system”: {
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“localhost”,
“cloud.c-lab.one”,
“10.1.0.74”,
“app.c-lab.one”
“datadirectory”: “REMOVED SENSITIVE VALUE”,
“dbtype”: “mysql”,
“version”: “20.0.7.1”,
“overwrite.cli.url”: “http://localhost”,
“dbname”: “REMOVED SENSITIVE VALUE”,
“dbhost”: “REMOVED SENSITIVE VALUE”,
“dbport”: “”,
“dbtableprefix”: “oc_”,
“mysql.utf8mb4”: true,
“dbuser”: “REMOVED SENSITIVE VALUE”,
“dbpassword”: “REMOVED SENSITIVE VALUE”,
“installed”: true,
“cron_log”: true,
“enable_previews”: true,
“enabledPreviewProviders”: [
“OC\Preview\PNG”,
“OC\Preview\JPEG”,
“OC\Preview\GIF”,
“OC\Preview\BMP”,
“OC\Preview\XBitmap”,
“OC\Preview\Movie”,
“OC\Preview\PDF”,
“OC\Preview\MP3”,
“OC\Preview\TXT”,
“OC\Preview\MarkDown”
“preview_max_x”: 1024,
“preview_max_y”: 768,
“preview_max_scale_factor”: 1,
“redis”: {
“host”: “REMOVED SENSITIVE VALUE”,
“port”: 0,
“timeout”: 0
“memcache.local”: “\OC\Memcache\APCu”,
“filelocking.enabled”: true,
“memcache.locking”: “\OC\Memcache\Redis”,
“instanceid”: “REMOVED SENSITIVE VALUE”,
“maintenance”: false,
“theme”: “”,
“trashbin_retention_obligation”: “auto, 7”,
“loglevel”: 2,
“ldapIgnoreNamingRules”: false,
“ldapProviderFactory”: “OCA\User_LDAP\LDAPProviderFactory”,
“app_install_overwrite”: [
“occweb”
“mail_smtpmode”: “smtp”,
“mail_smtpsecure”: “ssl”,
“mail_sendmailmode”: “smtp”,
“mail_from_address”: “REMOVED SENSITIVE VALUE”,
“mail_domain”: “REMOVED SENSITIVE VALUE”,
“mail_smtpauthtype”: “LOGIN”,
“mail_smtpauth”: 1,
“mail_smtphost”: “REMOVED SENSITIVE VALUE”,
“mail_smtpport”: “465”,
“mail_smtpname”: “REMOVED SENSITIVE VALUE”,
“mail_smtppassword”: “REMOVED SENSITIVE VALUE”,
“updater.release.channel”: “stable”
“apps”: {
“accessibility”: {
“enabled”: “yes”,
“installed_version”: “1.6.0”,
“types”: “”
“activity”: {
“enabled”: “yes”,
“installed_version”: “2.13.4”,
“types”: “filesystem”
“admin_audit”: {
“enabled”: “yes”,
“installed_version”: “1.10.0”,
“types”: “logging”
“analytics”: {
“enabled”: “yes”,
“installed_version”: “3.4.1”,
“types”: “”
“apporder”: {
“enabled”: “yes”,
“installed_version”: “0.12.0”,
“order”: “["/index.php/apps/dashboard/","/index.php/apps/activity/","/index.ph
p/apps/files/","/index.php/apps/photos/","/index.php/apps/contacts/","/index.php/apps
/calendar/","/index.php/apps/maps/","/index.php/apps/phonetrack/","/index.php/apps/au
dioplayer/","/index.php/apps/riotchat/","/index.php/apps/occweb/","/index.php/apps/tas
ks/"]”,
“types”: “”
“audioplayer”: {
“enabled”: “yes”,
“installed_version”: “3.1.0”,
“backgroundjob”: {
“lastjob”: “149410”
“breezedark”: {
“enabled”: “yes”,
“installed_version”: “20.0.10”,
“types”: “”
“bruteForce”: {
“whitelist_1”: “10.0.0.0/8”
“bruteforcesettings”: {
“enabled”: “yes”,
“installed_version”: “2.1.0”,
“types”: “”
“calendar”: {
“enabled”: “yes”,
“installed_version”: “2.2.0”,
“types”: “”
“cloud_federation_api”: {
“enabled”: “yes”,
“installed_version”: “1.3.0”,
“comments”: {
“enabled”: “yes”,
“types”: “logging”
“contacts”: {
“enabled”: “yes”,
“installed_version”: “3.5.1”,
“types”: “dav”
“contactsinteraction”: {
“enabled”: “yes”,
“installed_version”: “1.1.0”,
“types”: “dav”
“core”: {
“backgroundjobs_mode”: “cron”,
“enterpriseLogoChecked”: “yes”,
“installedat”: “1588229576.7286”,
“lastcron”: “1618563902”,
“lastupdateResult”: "{"version":"20.0.9.1","versionstring":"Nextcloud 20.0.9","url
“:"https:\/\/download.nextcloud.com\/server\/releases\/nextcloud-20.0.9.zip","web":"https
:\/\/docs.nextcloud.com\/server\/20\/admin_manual\/maintenance\/upgrade.html","changes"
:"https:\/\/updates.nextcloud.com\/changelog_server\/?version=20.0.9","autoupdater":"1","
eol":"0"}”,
“lastupdatedat”: “1618559401”,
“moveavatarsdone”: “yes”,
“oc.integritycheck.checker”: “”,
“previewsCleanedUp”: “1”,
“public_files”: “files_sharing/public.php”,
“public_webdav”: “dav/appinfo/v1/publicwebdav.php”,
“theming.variables”: “8ba0967157c658c8b1b7f0d410301b3b”,
“updater.secret.created”: “1612429927”,
“vendor”: “nextcloud”
“dashboard”: {
“enabled”: “no”,
“installed_version”: “7.0.0”,
“types”: “”
“dav”: {
“buildCalendarReminderIndex”: “yes”,
“buildCalendarSearchIndex”: “yes”,
“chunks_migrated”: “1”,
“enabled”: “yes”,
“installed_version”: “1.16.2”,
“regeneratedBirthdayCalendarsForYearFix”: “yes”,
“drawio”: {
“enabled”: “yes”,
“installed_version”: “1.0.0”,
“external”: {
“enabled”: “yes”,
“installed_version”: “3.7.2”,
“types”: “”
“extract”: {
“enabled”: “yes”,
“installed_version”: “1.3.1”,
“types”: “”
“federatedfilesharing”: {
“enabled”: “yes”,
“installed_version”: “1.10.2”,
“types”: “”
“federation”: {
“autoAddServers”: “1”,
“enabled”: “yes”,
“installed_version”: “1.10.1”,
“types”: “authentication”
“files”: {
“cronjob_scan_files”: “500”,
“default_quota”: “25 GB”,
“enabled”: “yes”,
“installed_version”: “1.15.0”,
“files_automatedtagging”: {
“enabled”: “yes”,
“files_downloadactivity”: {
“enabled”: “yes”,
“installed_version”: “1.9.0”,
“files_external”: {
“allow_user_mounting”: “yes”,
“enabled”: “yes”,
“installed_version”: “1.11.1”,
“types”: “filesystem”,
“user_mounting_backends”: “ftp,dav,owncloud,sftp,amazons3,swift,smb,\OC\Files\Storage\SF
TP_Key,\OC\Files\Storage\SMB_OC”
“files_pdfviewer”: {
“enabled”: “yes”,
“installed_version”: “2.0.1”,
“types”: “”
“files_photospheres”: {
“enabled”: “yes”,
“installed_version”: “1.20.1”,
“types”: “”
“files_rightclick”: {
“enabled”: “yes”,
“installed_version”: “0.17.0”,
“types”: “”
“files_sharing”: {
“enabled”: “yes”,
“installed_version”: “1.12.2”,
“files_trackdownloads”: {
“enabled”: “yes”,
“files_trashbin”: {
“enabled”: “yes”,
“types”: “filesystem,dav”
“files_versions”: {
“enabled”: “yes”,
“installed_version”: “1.13.0”,
“files_videoplayer”: {
“enabled”: “yes”,
“types”: “”
“firstrunwizard”: {
“enabled”: “yes”,
“installed_version”: “2.9.0”,
“types”: “logging”
“health”: {
“enabled”: “no”,
“installed_version”: “0.3.0”,
“types”: “”
“integration_github”: {
“enabled”: “no”,
“installed_version”: “0.0.20”,
“types”: “”
“integration_mastodon”: {
“enabled”: “no”,
“installed_version”: “0.0.13”,
“types”: “”
“integration_reddit”: {
“enabled”: “no”,
“installed_version”: “0.0.11”,
“types”: “”
“integration_twitter”: {
“enabled”: “no”,
“installed_version”: “0.0.10”,
“types”: “”
“logreader”: {
“enabled”: “yes”,
“installed_version”: “2.5.0”,
“types”: “”
“lookup_server_connector”: {
“enabled”: “yes”,
“installed_version”: “1.8.0”,
“maps”: {
“enabled”: “yes”,
“installed_version”: “0.1.8”,
“lastAddressLookup”: “1616317664”,
“nextcloud_announcements”: {
“enabled”: “yes”,
“pub_date”: “Thu, 24 Oct 2019 00:00:00 +0200”,
“types”: “logging”
“notifications”: {
“enabled”: “yes”,
“installed_version”: “2.8.0”,
“types”: “logging”
“oauth2”: {
“enabled”: “yes”,
“occweb”: {
“enabled”: “yes”,
“installed_version”: “0.0.7”,
“types”: “”
“onlyoffice”: {
“DocumentServerInternalUrl”: “”,
“DocumentServerUrl”: “”,
“StorageUrl”: “”,
“demo”: “{"available":false,"enabled":false,"start":{"date":"2021-01-07 12:54:01.73
6869","timezone_type":3,"timezone":"UTC"}}”,
“enabled”: “yes”,
“installed_version”: “6.3.0”,
“jwt_secret”: “”,
“settings_error”: “”,
“verify_peer_off”: “false”
“password_policy”: {
“enabled”: “yes”,
“phonetrack”: {
“enabled”: “yes”,
“installed_version”: “0.6.7”,
“types”: “”
“photos”: {
“enabled”: “yes”,
“installed_version”: “1.2.3”,
“types”: “”
“privacy”: {
“enabled”: “yes”,
“installed_version”: “1.4.0”,
“types”: “”
“provisioning_api”: {
“enabled”: “yes”,
“types”: “prevent_group_restriction”
“recommendations”: {
“enabled”: “yes”,
“installed_version”: “0.8.0”,
“types”: “”
“riotchat”: {
“enabled”: “yes”,
“installed_version”: “0.7.5”,
“types”: “”
“serverinfo”: {
“enabled”: “yes”,
“types”: “”
“settings”: {
“enabled”: “yes”,
“installed_version”: “1.2.0”,
“types”: “”
“sharebymail”: {
“enabled”: “yes”,
“support”: {
“SwitchUpdaterServerHasRun”: “yes”,
“enabled”: “yes”,
“types”: “session”
“survey_client”: {
“enabled”: “yes”,
“types”: “”
“systemtags”: {
“enabled”: “yes”,
“types”: “logging”
“tasks”: {
“enabled”: “yes”,
“installed_version”: “0.13.6”,
“types”: “”
“text”: {
“enabled”: “yes”,
“types”: “dav”
“theming”: {
“backgroundMime”: “image/png”,
“cachebuster”: “13”,
“color”: “#542323”,
“enabled”: “yes”,
“imprintUrl”: “REMOVED SENSITIVE VALUE”,
“installed_version”: “1.11.0”,
“logoMime”: “image/png”,
“logoheaderMime”: “image/png”,
“name”: “C-Lab Cloud 2021”,
“privacyUrl”: “REMOVED SENSITIVE VALUE”,
“slogan”: “REMOVED SENSITIVE VALUE”,
“types”: “logging”,
“url”: “REMOVED SENSITIVE VALUE”
“twofactor_backupcodes”: {
“enabled”: “yes”,
“types”: “”
“twofactor_totp”: {
“enabled”: “yes”,
“installed_version”: “5.0.0”,
“types”: “”
“updatenotification”: {
“analytics”: “3.4.1”,
“apporder”: “0.12.0”,
“breezedark”: “20.0.10”,
“bruteforcesettings”: “2.1.0”,
“calendar”: “2.2.0”,
“contacts”: “3.5.1”,
“core”: “20.0.9.1”,
“drawio”: “1.0.0”,
“enabled”: “yes”,
“external”: “3.7.2”,
“integration_github”: “1.0.0”,
“integration_mastodon”: “1.0.0”,
“integration_reddit”: “0.0.11”,
“integration_twitter”: “1.0.0”,
“onlyoffice”: “6.3.0”,
“phonetrack”: “0.6.7”,
“riotchat”: “0.7.5”,
“types”: “”,
“update_check_errors”: “0”
“user_ldap”: {
“background_sync_interval”: “43200”,
“background_sync_offset”: “0”,
“background_sync_prefix”: “s01”,
“cleanUpJobOffset”: “0”,
“enabled”: “yes”,
“s01_lastChange”: “1618563876”,
“s01has_memberof_filter_support”: “1”,
“s01home_folder_naming_rule”: “”,
“s01last_jpegPhoto_lookup”: “0”,
“s01ldap_agent_password”: “REMOVED SENSITIVE VALUE”,
“s01ldap_attributes_for_group_search”: “”,
“s01ldap_attributes_for_user_search”: “uid\ngivenName\nsn\nemployeeNumber\nmailPrimaryAddres
s”,
“s01ldap_backup_host”: “”,
“s01ldap_backup_port”: “”,
“s01ldap_base”: “dc=c-lab,dc=one”,
“s01ldap_base_groups”: “dc=c-lab,dc=one”,
“s01ldap_base_users”: “dc=c-lab,dc=one”,
“s01ldap_cache_ttl”: “600”,
“s01ldap_configuration_active”: “1”,
“s01ldap_default_ppolicy_dn”: “”,
“s01ldap_display_name”: “displayname”,
“s01ldap_dn”: “uid=ldaplogin,cn=users,dc=c-lab,dc=one”,
“s01ldap_dynamic_group_member_url”: “”,
“s01ldap_email_attr”: “mailPrimaryAddress”,
“s01ldap_experienced_admin”: “1”,
“s01ldap_expert_username_attr”: “uid”,
“s01ldap_expert_uuid_group_attr”: “”,
“s01ldap_expert_uuid_user_attr”: “”,
“s01ldap_ext_storage_home_attribute”: “”,
“s01ldap_gid_number”: “gidNumber”,
“s01ldap_group_display_name”: “cn”,
“s01ldap_group_filter”: “(|(cn=grp-intern-nextcloud)(cn=grp-fam-doll)(cn=grp-fam-intern)(cn=
Testgruppe))”,
“s01ldap_group_filter_mode”: “0”,
“s01ldap_group_member_assoc_attribute”: “uniqueMember”,
“s01ldap_groupfilter_groups”: “grp-intern-nextcloud\ngrp-fam-doll\ngrp-fam-intern\nTestgrupp
e”,
“s01ldap_groupfilter_objectclass”: “”,
“s01ldap_host”: “central.c-lab.one”,
“s01ldap_login_filter”: “(&(|(memberof=cn=grp-intern-nextcloud,cn=groups,dc=c-lab,dc=one))(u
id=%uid))”,
“s01ldap_login_filter_mode”: “0”,
“s01ldap_loginfilter_attributes”: “”,
“s01ldap_loginfilter_email”: “0”,
“s01ldap_loginfilter_username”: “1”,
“s01ldap_matching_rule_in_chain_state”: “unknown”,
“s01ldap_nested_groups”: “0”,
“s01ldap_override_main_server”: “”,
“s01ldap_paging_size”: “500”,
“s01ldap_port”: “7389”,
“s01ldap_quota_attr”: “”,
“s01ldap_quota_def”: “”,
“s01ldap_tls”: “0”,
“s01ldap_turn_off_cert_check”: “0”,
“s01ldap_turn_on_pwd_change”: “0”,
“s01ldap_user_avatar_rule”: “default”,
“s01ldap_user_display_name_2”: “”,
“s01ldap_user_filter_mode”: “0”,
“s01ldap_userfilter_groups”: “grp-intern-nextcloud”,
“s01ldap_userfilter_objectclass”: “”,
“s01ldap_userlist_filter”: “(|(memberof=cn=grp-intern-nextcloud,cn=groups,dc=c-lab,dc=one))”
“s01use_memberof_to_detect_membership”: “1”,
“user_status”: {
“enabled”: “yes”,
“installed_version”: “1.0.1”,
“types”: “”
“viewer”: {
“enabled”: “yes”,
“types”: “”
“weather_status”: {
“enabled”: “yes”,
“types”: “”
“workflowengine”: {
“enabled”: “yes”,
