Nextcloud container not starting after server reboot
    • 35.0.0.10
    • replace me
    • 13.7
    • 2.15.1
    • in docker image
    • long ago
    • linuxserver.io docker image
Weird issue with the nextcloud containers (image: latest). When the nextcloud containers are running, they can be accessed normally. But when I do a server reboot, all other docker containers restart automatically, except the nextcloud containers. How can I solve this, help is greatly appreciated.
  1. Log into server with ssh
  2. type “reboot”
  3. Wait a view seconds
  4. Open Web UI
  5. access Nextcloud
docker-compose.yml:
services:
  nextcloud:
    image: linuxserver/nextcloud:latest
    container_name: nextcloud-app
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Europe/Berlin
    volumes:
      - /storage/nextcloud/config:/config
      - /storage/nextcloud/data:/data
    restart: unless-stopped
    depends_on:
      - db
    networks:
      - nextcloud-net
      - proxy-net
  db:
    image: mariadb:11
    container_name: nextcloud-db
    volumes:
      - /storage/nextcloud/db:/var/lib/mysql
    environment:
      - PUID=1000
      - PGID=1000
      - TZ=Europe/Berlin
      - MYSQL_ROOT_PASSWORD=${MYSQL_ROOT_PASSWORD}
      - MYSQL_DATABASE=${MYSQL_DATABASE}
      - MYSQL_USER=${MYSQL_USER}
      - MYSQL_PASSWORD=${MYSQL_PASSWORD}
    networks:
      - nextcloud-net
  redis:
    image: redis:latest
    container_name: nextcloud-redis
    command: redis-server --requirepass ${REDIS_PASSWORD}
    environment:
      - REDIS_PASSWORD=${REDIS_PASSWORD}
    volumes:
      - /storage/nextcloud/redis:/data
    networks:
      - nextcloud-net
networks:
  nextcloud-net:
    driver: bridge
  proxy-net:
    external: true
And I see this message when accessing the web gui after a reboot:
Internal Server Error
The server encountered an internal error and was unable to complete your request.
Please contact the server administrator if this error reappears multiple times, please include the technical details below in your report.
And this are the logs after a reboot:
~$ docker logs nextcloud-app
[migrations] started
[migrations] 01-nginx-site-confs-default: skipped
[migrations] 02-default-location: skipped
[migrations] done
   Brought to you by linuxserver.io
To support LSIO projects visit:
https://www.linuxserver.io/donate/
GID/UID
User UID:    1000
User GID:    1000
Linuxserver.io version: 35.0.0-ls452
Build-date: 2026-09-16T00:49:05+00:00
using keys found in /config/keys
Initializing nextcloud 35.0.0.10 (this can take a while) ...
Setting permissions
Initializing finished
[custom-init] No custom files found, skipping...
[ls.io-init] done.
[migrations] done
usermod: no changes
GID/UID
User UID:    1000
User GID:    1000
After completing the web-based installer, restart the Nextcloud container to apply default memory caching and transactional file locking configurations.
Alternatively, you can apply your own configurations by editing /config/www/nextcloud/config/config.php following the documentation:
https://docs.nextcloud.com/server/latest/admin_manual/configuration_server/caching_configuration.html
https://docs.nextcloud.com/server/latest/admin_manual/configuration_files/files_locking_transactional.html
[ls.io-init] done.
I’m little confused.. as you can see logs containers must have started? what is the output of docker compose ps in the directory? what happens if you run docker compose up? does the app start?
but as you added
already the issue would be more related to docker rather to containers.. linuxserver.io images have some specialities I would recommend you consult linuxserver.io Nextcloud docs and reach out to linuxserver.io Support
Also, the internal server error looks like it’s coming from Nextcloud, which would imply that the Nextcloud container is running. Maybe the issue is with the MariaDB or Redis container. If one of them does not start, that would explain the internal server error.
I’m already in contact with linuxserverio, seems the database is shutting down:
2026-09-21 17:23:01 0 [Note] mariadbd (initiated by: unknown): Normal shutdown
What means “unknown” in this case?
Found it: There was a “restart: unless-stopped” missing in the docker-compose.yml for the db. Now it works, thanks for your help.
