Hello, folks. Latest stable nextcloud apache in docker
installation. Right after installation I found that the
countainer has no connection to the outside world. I can curl
localhost, db, but not any external service. Can’t apt update
as well:
Err:1 http://deb.debian.org/debian bullseye InRelease
Temporary failure resolving 'deb.debian.org'
Err:2 http://deb.debian.org/debian-security bullseye-security InRelease
Err:3 http://deb.debian.org/debian bullseye-updates InRelease
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
All packages are up to date.
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye/InRelease Temporary failure resolving 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian-security/dists/bullseye-security/InRelease Temporary failure resolving 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/bullseye-updates/InRelease Temporary failure resolving 'deb.debian.org'
W: Some index files failed to download. They have been ignored, or old ones used instead.
/etc/resolv.conf of the container:
nameserver 127.0.0.11
options edns0 trust-ad ndots:0
curl -I 192.168.77.30
HTTP/1.1 301 Moved Permanently
Server: openresty
Date: Mon, 10 Oct 2022 17:12:36 GMT
Content-Type: text/html
Content-Length: 166
Connection: keep-alive
Here I curled host machine lan ip (nginx-proxy-manager runs on this port).
Host machine is running debian 11. docker-compose file:
services:
db:
image: mariadb:10.5
container_name: nextcloud-db
hostname: nas
restart: always
volumes:
- /mnt/media/docker/containers/nextcloud-db:/var/lib/mysql
environment:
- MYSQL_ROOT_PASSWORD=
- MYSQL_PASSWORD=
- MYSQL_DATABASE=nextcloud
- MYSQL_USER=nextcloud
app:
image: nextcloud:stable
hostname: nas
restart: always
ports:
- "51005:80"
links:
- db
depends_on:
- db
volumes:
- /mnt/media/docker/containers/nextcloud:/var/www/html
environment:
- MYSQL_PASSWORD=
- MYSQL_HOST=db
- NEXTCLOUD_ADMIN_USER=admin
- NEXTCLOUD_ADMIN_PASSWORD=
dns:
- 1.1.1.1
- 1.0.0.1
- 9.9.9.9
networks:
default:
Tryed to manualy change nameservers in /etc/resolv.conf to
nameserver 1.1.1.1
nameserver 8.8.8.8
Got no effect. In admin pannel on Logging page I see a lot of:
Error: dns_get_record(): A temporary server error occurred. at /var/www/html/lib/private/Http/Client/DnsPinMiddleware.php#83
I have a dozen containers with the same setup and they all work
fine, all have connection and resolves any address without
problems. Any ideas what could go wrong? As I said it’s a fresh
new container without any legacy data.
