We are facing issue bellow:
FATAL:Remaining connection slots are reserved for non-replication superuser connections
[/details]
Nextcloud version (eg, 20.0.5): Nextcloud Hub 3 (25.0.0)
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.5 LTS
Apache or nginx version (eg, Apache 2.4.25): Apache/2.4.41
PHP version (eg, 7.4): 7.4
Is this the first time you’ve seen this error? (Y/N):Y
The output of your postgres log in :
'passwordsalt' => 'Redacted my Mod RK/JK',
'secret' => 'Redacted my Mod RK/JK',
0 => 'Redacted my Mod RK/JK',
1 => 'Redacted my Mod RK/JK',
2 => 'Redacted my Mod RK/JK',
'datadirectory' => '/mnt/ncdata',
'dbtype' => 'pgsql',
'version' => '25.0.0.18',
'overwrite.cli.url' => 'https://Redacted my Mod RK/JK/',
'dbname' => 'nextcloud_db',
'dbhost' => 'localhost',
'dbuser' => '*************',
'dbpassword' => '********************',
'instanceid' => '************',
'log_type' => 'file',
'loglevel' => 0,
'log_rotate_size' => false,
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'mail_smtpmode' => 'smtp',
'redis' =>
'port' => 0,
'timeout' => 0.5,
'dbindex' => 0,
'password' => '***********************',
'logtimezone' => 'Africa/Tunis',
'ldapIgnoreNamingRules' => false,
'auth.bruteforce.protection.enabled' => 'false',
'theme' => '',
'app_install_overwrite' =>
0 => 'flowupload',
1 => 'rocketchat_nextcloud',
2 => 'impersonate',
'app.mail.verify-tls-peer' => false,
'trusted_proxies' =>
0 => '<zimbra server proxy ip here>',
'forwarded_for_headers' =>
0 => 'HTTP_X_FORWARDED_FOR',
'mail_domain' => 'test.tn',
'mail_smtphost' => 'smtp1.test.com',
'mail_smtpport' => '25',
will be added when the issue will appear again
PASTE HERE
