Hello everyone,
I have the following problem, Nextcloud AIO loses Collabora without errors in the protocol, I can no longer access my write.
If I stop the containers in the interface and load them again, it will probably work again until the backup UTC 22:00, after which it won’t work anymore.
My installation: Nextcloud AIO 27.1.2; Nginx proxy manager
Does anyone have an idea which log file I can look in?
I found this one
Ready to accept connections on port 9980.
wsd-00001-00001 2023-09-21 12:36:15.592531 +0000 [ coolwsd ] TRC Have 1 new children.| wsd/COOLWSD.cpp:5901
wsd-00001-00001 2023-09-21 12:36:15.592578 +0000 [ coolwsd ] INF WSD initialization complete: setting log-level to [warning] as configured.| wsd/COOLWSD.cpp:5917
wsd-00001-00001 2023-09-21 12:36:15.593310 +0000 [ coolwsd ] ERR #24: Failed setsockopt TCP_NODELAY: Socket operation on non-socket (ENOTSOCK: Socket operation on non-socket)| net/Socket.hpp:206
wsd-00001-00001 2023-09-21 12:36:15.593413 +0000 [ coolwsd ] WRN Waking up dead poll thread [main], started: false, finished: false| net/Socket.hpp:704
hello@all
The following problem: Nextcloud AIO in the reverse proxy Nginx Proxy Manager (NPM) starts great, everything works fine
Collabora executable after daily backup Collabora no longer works. I found out
that it is not the backup but rather the forced shutdown of the Fritzbox around 3:00 a.m
I created a new public IP that also applies to both DynDns (cloud.xxxxx.tld and collabora.xxxxxx.tld)
to get redirected. Collabora works again when I add the public IP to the Allow list for WOPI requests add.
How can I change this so that the Dyndns take over tld’s? Or it works automatically.
Nextcloud AIO runs on Ubuntu VM 23.04 Docker Container Proxmox Server IP:192.168.xxx.156
Nginx NPM also runs on Ubuntu VM 23.04 Docker Container Proxmox Sever IP:192.168.xxx.168
separate VMs, Fritzbox release https and http
Collabora also runs on the Nginx server and was integrated like this:
docker run -t -d -p 9980:9980 -e “domain=cloud\.xxxxxx\.tld” --name=COLLABORAOFFICE --restart always --cap-add MKNOD collabora/code
####### Nginx Proxy Manager config #######
- Create your new Proxy Host, specify https protocol and the server host/ip and port 9980 (192.168.xxx.168:9980). Also enable Websockets Support.
- On the SSL tab select a new certificate, enable HTTP/2.
- On the Advanced tab, enter:
# static files
location ^~ /loleaflet {
proxy_pass $forward_scheme://$server:$port;
proxy_set_header Host $http_host;
# WOPI discovery URL
location ^~ /hosting/discovery {
# main websocket
location ~ ^/lool/(.*)/ws$ {
proxy_set_header Connection "upgrade";
proxy_http_version 1.1;
proxy_read_timeout 36000s;
# download, presentation and image upload
location ~ ^/lool {
# Admin Console websocket
location ^~ /lool/adminws {
Greetings Werner
