Can anyone help me out to get rid of this error?
““Well, this is embarrassing, we cannot connect to your document. Please try again.””
Ubuntu 16.04.1 LTS \n \l
Version
Nextcloud 11.0.1 (daily) Build:2017-02-08T21:01:33+00:00 d8916ddfd82855d36102909279eb04088ba2af19
Docker base machine:
Docker info
Server Version: 1.13.1
Storage Driver: overlay2
Backing Filesystem: extfs
Supports d_type: true
Native Overlay Diff: true
Logging Driver: json-file
Cgroup Driver: cgroupfs
Plugins:
Volume: local
Network: bridge host macvlan null overlay
Swarm: inactive
Runtimes: runc
Default Runtime: runc
Init Binary: docker-init
containerd version: aa8187dbd3b7ad67d8e5e3a15115d3eef43a7ed1
runc version: 9df8b306d01f59d3a8029be411de015b7304dd8f
init version: 949e6fa
Security Options:
apparmor
seccomp
Profile: default
Kernel Version: 4.4.0-53-generic
Operating System: Ubuntu 16.04.1 LTS
OSType: linux
Architecture: x86_64
CPUs: 4
Total Memory: 7.796 GiB
Docker Root Dir: /var/lib/docker
Debug Mode (client): false
Debug Mode (server): false
Registry: https://index.docker.io/v1/
WARNING: No swap limit support
Experimental: false
Insecure Registries:
127.0.0.0/8
Live Restore Enabled: false
Docker logs:
wsd-00026-0028 18:55:28.119483 [ client_req_hdl ] WRN WOPI host did not pass optional access_token_ttl| wsd/FileServer.cpp:255
wsd-00026-0029 18:55:29.540363 [ client_ws_001a ] ERR WOPI::CheckFileInfo is missing JSON payload
wsd-00026-0029 18:55:29.540983 [ client_ws_001a ] ERR Invalid fileinfo for URI [xxxx.net - Tämä WWW-sivu on myynnissä. - xxxx Lähteet ja tiedot.].| wsd/DocumentBroker.cpp:314
wsd-00026-0029 18:55:29.541262 [ client_ws_001a ] ERR Failed to load document with URI [xxxx.net - Tämä WWW-sivu on myynnissä. - xxxx Lähteet ja tiedot.].| wsd/DocumentBroker.cpp:556
wsd-00026-0029 18:55:29.541619 [ client_ws_001a ] ERR Error in client request handler: Failed to load document with URI [xxxx.net - Tämä WWW-sivu on myynnissä. - xxxx Lähteet ja tiedot.].| wsd/LOOLWSD.cpp:1038
wsd-00026-0030 18:55:31.526318 [ client_ws_001b ] ERR WOPI::CheckFileInfo is missing JSON payload
wsd-00026-0030 18:55:31.526916 [ client_ws_001b ] ERR Invalid fileinfo for URI [xxxx.net - Tämä WWW-sivu on myynnissä. - xxxx Lähteet ja tiedot.].| wsd/DocumentBroker.cpp:314
wsd-00026-0030 18:55:31.527009 [ client_ws_001b ] ERR Failed to load document with URI [xxxx.net - Tämä WWW-sivu on myynnissä. - xxxx Lähteet ja tiedot.].| wsd/DocumentBroker.cpp:556
wsd-00026-0030 18:55:31.527247 [ client_ws_001b ] ERR Error in client request handler: Failed to load document with URI [xxxx.net - Tämä WWW-sivu on myynnissä. - xxxx Lähteet ja tiedot.].| wsd/LOOLWSD.cpp:1038
wsd-00026-0028 19:15:56.676070 [ client_req_hdl ] WRN WOPI host did not pass optional access_token_ttl| wsd/FileServer.cpp:255
wsd-00026-0029 19:15:58.618765 [ client_ws_001c ] WRN Poco::Net::DNS::resolveOne(“”) failed: Host not found
wsd-00026-0029 19:15:58.619420 [ client_ws_001c ] ERR Error in client request handler: No acceptable WOPI hosts found matching the target host in config.| wsd/LOOLWSD.cpp:1031
