Sorry to hear you’re facing problems ![]()
example
longer
example
here
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can ![]()
Nextcloud version (eg, 20.0.5): 26.
Operating system and version (eg, Ubuntu 20.04): 22.04
PHP version (eg, 7.4): 8.1
Nextcloud Client sync files in folders it is supposed to Ignore according to the General ignore file (the one in general settings that should override the others).
Is this the first time you’ve seen this error? (Y/N): No
- Add
testignore/*to General → Edit Ignored Files → Add - Go to local synced folder
mkdir testignore && cd testignore && touch dontsync.txt- Nextcloud client then sync dontsync.txt which is supposed to be ignored.
Nextcloud client is latest ( 3.10.1 ). I don’t know since when it doesn’t work though, because I had issues with previous version which I thought I kinda fixed (by unchecking the folder in the main setting panel) but it ends up not working.
Edit: Nevermind the error popup in my original text. It is related to syncing an empty file.
Edit2: Seems like using testignorewithout /*works. Are regex supposed to work in ignore settings?
