Thanks for your reply. I could not find these via “apt search” but i was able to install libsrtp0 and libsrtp0-dev.
But when i execute ./nextcloud (or ./nextcloud --logwindow) i get … ./nextcloud.sh: line 10: 8448 Aborted $pwd/bin/nextcloud $1 … still something not working correctly. You know how to proceed now? F.i. where i can find the log files? Thanks in advance.
You can download new script from github. Also, You can edit nextcloud.sh.
last line “$pwd/bin/nextcloud $1” to “$pwd/bin/nextcloud $@”.
You can create log.
$ ./nextcloud.sh --logfile logfile
i edited the ./nextcloud.sh file (replace 1 by @) and executed ./nextcloud.sh --logfile logfile. Unfortunately i got the error … ./nextcloud.sh: line 10: 1384 Aborted $pwd/bin/nextcloud $@.
The last two lines of the logfile are:
[OCC::WebViewPage::WebViewPage Time for a webview!
[unknown Cannot mix incompatible Qt library (version 0x50701) with this library (version 0x50b03)
I guess this will be the last error to solve :). Is the QT file I downloaded not the right version? i think it’s 5.7.1.
I built qt web engine library based qt 5.7.1.
But, Qt version is 5.11.3 in Debian buster.
I can’t give you the correct script because of not buster.
You can check qt version and informations.
$ qtdiag
I will wait for the good news.
Tried it but no success Package nextcloud-desktop is not available, but is referred to by another package. This may mean that the package is missing, has been obsoleted, or is only available from another source
E: Package ‘nextcloud-desktop’ has no installation candidate
You are using a raspberry pi? ARM-machine 32 bits? I’m using a RPI-3B.
Thanks for your support!
Build took about 40 minutes mostly at 100% CPU
But unfortunately i still get the same error message. Do i need to do something extra? f.i installing the build? Thanks for info.
I am new to the Nextcloud community and recently configured a Raspberry Pi 4/B (with Raspbian Buster) to act as a Nextcloud Server, with the intent of replacing our family’s use of Dropbox to share files. It works quite well across our Windows PCs and iOS devices.
Now I am hoping to configure a second Raspberry Pi 4/B as a Nextcloud client. This thread is eye-opening, but I have trouble following it to clearly understand what will work and what won’t.
Has anyone successfully built and installed a Nextcloud Client on a RPi 4/B and would you kindly share the steps you took to do this? Please note I am a relative novice in Linux.
I got it kind of running on RPI4B-4G with a lot of help from 11137.
Please follow his link(s) above and install Qt5 webengine for buster like explained (sudo dpkg --install qtwebengine-wnote.deb).
Next we need to have his nextcloud-dekstop-client version. The instruction mentioned above (on 20 aug) and copied below are not working for me. I got it running by using version 2.5.3 which i got from 11137 and i used before on RPI3 (i think it was replacing 2.5.2 in the link by 2.5.3). I also needed to install an extra qt5 package (something called widgets). Please share what you encounter. Thanks.
I tried it on Pi 4 with Raspbian 9/2019:
but get this error message:
./bin/nextcloud: error while loading shared libraries: libocsync.so.0: cannot open shared object file: No such file or directory
Hi Franz2,
I didn’t encoutered this one as far as i remember. When i do apt search for libocsync i find stable 0.91 version and none of them are installed at my RPI4 (with owncloud desktop running very smoothly). i wonder which owncloud version you want to install (mine 2.5.3). To solve your problem i suggest to run sudo apt install libocsync0. Good luck.
PS. in nextcloud-desktop-client/lib/arm-linux-gnueabihf/nextcloud I just found de libocsync files … all pointing at libocsync.so.2.5.3
I followed the scripts… Installed qt5-qtwebengine-arm-bin… downloaded the client on istandthon7 client github…
When I launch ./init.sh, I got a reply saying the stable versions of libqt5keychain1/stable libminizip1/stable can’t be found.
When I launch ./nextcloud.sh: ./bin/nextcloud: error while loading shared libraries: libqt5keychain.so.1: cannot open shared object file: No such file or directory
Since the nextcloud https://github.com/nextcloud/client_theming.git is an old thing (version 2.3.3) and trying to build the new https://github.com/nextcloud/desktop.git would end up in a Qt version error (needing version >/=5.12, which is not on the actual raspiban repos) and building Qt 5.12 LTS on a raspy is quite a job… I have been searching for another solution, but I haven’t found anything.
So I decided to post it here, in case someone is having this problem in mid 2020… (sorry if nobody finds this useful and I’m bringing back this thread after 7 months…)
My “solution” was manually installing nextcloud client version 2.5.1-3 (latest debian packages available) using dpkg with the help of apt --fix-broken install to bring the rest of the dependencies. This was done in Raspbian 10 buster armv7l Linux 4.19.118-v7l+ 32 bit system.
I did it by manually downloading and installing these .deb packages for debian armhf (there are also available the equivalent arm64 packages, but I am still in raspberry pi os 32 bit):
If encountered errors in the dpkg installation, which I did for every one of the packages but the second (because it has the same dependencies as the first one), you just let the (sudo) apt --fix-broken install grab the dependencies.
Or, I guess you could install all of them at once using apt, so it does the job automatically, but I did it that way. (If you use apt install just remember to tell it the /path/to/the/debfiles as they are not packages it would get from the official Raspbian repos.
Then just launch the app. It has worked perfectly for me. Cheers!
