My nextcloudpi on raspberry pi 4 has been acting up lately. Nextcloud stops working and reason is that USB drive (8 tb seagate) goes to write only mode (data directory is on the USB drive). It can happen any time, so I just scrapped everything, started with freshly formatted drive and formatted memory card with clean install.
After install I created first user, started to sync (from local to nextcloud) and within minutes it had happened again. Client gives error on every single file, and going to server, the USB drive is in write only.
I’m out of ideas, please help.
Did you check your logfiles? Is there an extra power supply for the disk (direct or via USB hub)?
Is there any solution to this? I tried with direct connection to pi as well as with powered USB hub, but getting the read only after few hours of operations
Also, i am unable to find the mount information in /etc/fstab
It seems similar to what happened to me
Did you try btrfs check to see what errors appear? Another user suggested that on rpi a bad power supply could be the cause
The official RPI4 power supply is a good one.
Make sure that the USB HUB is also a good one and can provide enough power to both disks.
