I recently switched from nextcloudpi to plain nextcloud. I can access nextcloud instance from localhost, login and access the data.
Problem: I cannot access the instance via reverse proxy.
The configuration of the reverse proxy is almost the same as before. Other instances referred but reverse-proxy are working fine.
Here is the error I see in the logs of reverse-proxy:
2023/03/28 17:30:17 [warn] 23#23: *138 a client request body is buffered to a temporary file /var/cache/nginx/client_temp/0000000015, client: 79.244.33.204, server: *censored*.de, request: "POST /index.php/apps/phonetrack/logPostMultiple/ae8a077fdec82cf9d59e8473ba75ab96/Pixel2 HTTP/1.1", host: "censored.de"
2023/03/28 17:30:17 [error] 23#23: *138 connect() failed (111: Connection refused) while connecting to upstream, client: 79.244.33.204, server: censored.de, request: "POST /index.php/apps/phonetrack/logPostMultiple/ae8a077fdec82cf9d59e8473ba75ab96/Pixel2 HTTP/1.1", upstream: "https://172.18.0.6:443/index.php/apps/phonetrack/logPostMultiple/ae8a077fdec82cf9d59e8473ba75ab96/Pixel2", host: "censored"
The config of nextcloud is a bit different as before:
'passwordsalt' => '*censored*',
'secret' => '*censored*',
0 => 'localhost',
5 => 'nextcloudpi.local',
7 => 'nextcloudpi',
8 => 'nextcloudpi.lan',
1 => '172.18.0.6',
6 => '192.168.103.44',
20 => *censored*',
12 => '*censored*',
21 => '*censored*',
22 => '192.168.103.44',
11 => '79.244.33.204',
3 => 'dbe5e509ecaf',
14 => 'dbe5e509ecaf',
'' => '01f946771284',
15 => '79.244.33.204',
'version' => '25.0.3.2',
'overwrite.cli.url' => 'https://dbe5e509ecaf/',
'dbname' => 'nextcloud',
'dbhost' => 'nc_mariadb',
'dbuser' => '*censored*',
'dbpassword' => '*censored*',
'instanceid' => 'oc7g2bq3dse1',
'trusted_proxies' =>
0 => '192.168.103.44',
2 => '127.0.0.1',
1 => 'localhost',
11 => '127.0.0.1',
12 => '::1',
13 => 'dbe5e509ecaf',
14 => '172.18.0.6',
15 =>'79.244.33.204',
