Hello i installed Nextcloud 28 today, without updating to 29,
then tryed to backup before messing everything.
I have backup failed message, here is the log.
Help please
New Proxmox Ubuntu VM, Recommended AIO install.
Docker Compose :
# https://nextcloud.com/blog/how-to-install-the-nextcloud-all-in-one-on-linux/
# https://github.com/nextcloud/all-in-one/blob/main/compose.yaml
version: '3'
services:
#image: ${C_NXA_IMG_BETA}
image: ${C_NXA_IMG}
init: true
restart: ${C_ALL_RESTART}
container_name: ${C_NXA} # N1 โ ๏ธ
hostname: ${C_NXA_HOST}
#user: "0:0" # ${PUID}:${PGID}
volumes:
- nextcloud_aio_mastercontainer:/mnt/docker-aio-config # N2 โ ๏ธ
- /var/run/docker.sock:/var/run/docker.sock:ro # A1
ports:
#- "${C_NXA_80}:80" # A2
- "${C_NXA_8080}:8080"
#- "${C_NXA_8443}:8443" # A2
#- "${C_NXA_3478}:3478" # talk port
#- "${C_NXA_11000}:11000" # apache port
environment: # I1
#- AIO_DISABLE_BACKUP_SECTION=false # I2
- APACHE_PORT=11000 # A3
- APACHE_IP_BINDING=0.0.0.0 #${C_NXA_IP_WEB} # A4
- SKIP_DOMAIN_VALIDATION=true
- BORG_RETENTION_POLICY=--keep-within=7d --keep-weekly=1 --keep-monthly=1 # A5
# - COLLABORA_SECCOMP_DISABLED=false # A6
- NEXTCLOUD_DATADIR=${REP_X_NEXTCLOUD}/data # A7 โ ๏ธ : /mnt/ncdata
- NEXTCLOUD_MOUNT=${REP_X_NEXTCLOUD}/partage/ # A8 : /mnt/
#- NEXTCLOUD_TRUSTED_CACERTS_DIR=${REP_X_NEXTCLOUD}/certs # A12 : /path/to/my/cacerts
- NEXTCLOUD_UPLOAD_LIMIT=10G # A9
- NEXTCLOUD_MAX_TIME=3600 # A10
- NEXTCLOUD_MEMORY_LIMIT=4096M #1024M #512M # A11
# - NEXTCLOUD_STARTUP_APPS=deck twofactor_totp tasks calendar contacts notes # A13
- NEXTCLOUD_ADDITIONAL_APKS=imagemagick ffmpeg perl # imagemagick # A14
- NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS=imagick # A15
- NEXTCLOUD_ENABLE_DRI_DEVICE=true # A16
# - NEXTCLOUD_KEEP_DISABLED_APPS=false # A17
# - TALK_PORT=3478 # A18
# - WATCHTOWER_DOCKER_SOCKET_PATH=/var/run/docker.sock # A19 โ ๏ธ
#security_opt: ["label:disable"] # A22
#networks:
#nextcloud-aio: # A21
#ipv4_address: ${C_NXA_IP_AIO}
#web:
# ipv4_address: ${C_NXA_IP_WEB}
# caddy: # A23
# image: caddy:alpine
# restart: always
# container_name: caddy
# volumes:
# - ./Caddyfile:/etc/caddy/Caddyfile
# - ./certs:/certs
# - ./config:/config
# - ./data:/data
# - ./sites:/srv
# network_mode: "host"
volumes: # A20
name: nextcloud_aio_mastercontainer # # N2 โ ๏ธ
Backup Log :
Initializing repository...
using builtin fallback logging configuration
33 self tests completed in 0.18 seconds
Initializing repository at "/mnt/borgbackup/borg"
Key in "<Repository /mnt/borgbackup/borg>" created.
Keep this key safe. Your data will be inaccessible without it.
check_free_space: few segments, not requiring a full free segment
check_free_space: calculated working space for compact as 0 bytes
check_free_space: required bytes 169138, free bytes 15460683923456
security: previous location file /root/.config/borg/security/cb140e94a184c22def047a3542ad9fef4dff8d12c5eeb7881697d1e5a47057e7/location not found
security: manifest timestamp file /root/.config/borg/security/cb140e94a184c22def047a3542ad9fef4dff8d12c5eeb7881697d1e5a47057e7/manifest-timestamp not found
security: determined newest manifest timestamp as
security: remembering previously unknown repository
security: saving state for cb140e94a184c22def047a3542ad9fef4dff8d12c5eeb7881697d1e5a47057e7 to /root/.config/borg/security/cb140e94a184c22def047a3542ad9fef4dff8d12c5eeb7881697d1e5a47057e7
security: current location /mnt/borgbackup/borg
security: key type 5
security: manifest timestamp 2024-04-28T14:47:31.376795
security: repository checks ok, allowing access
Synchronizing chunks cache...
Archives: 0, w/ cached Idx: 0, w/ outdated Idx: 0, w/o cached Idx: 0.
Verified integrity of /mnt/borgbackup/borg/index.1
Done.
By default repositories initialized with this version will produce security
errors if written to with an older version (up to and including Borg 1.0.8).
If you want to use these older versions, you can disable the check by running:
borg upgrade --disable-tam /mnt/borgbackup/borg
See https://borgbackup.readthedocs.io/en/stable/changes.html#pre-1-0-9-manifest-spoofing-vulnerability for details about the security implications.
IMPORTANT: you will need both KEY AND PASSPHRASE to access this repo!
If you used a repokey mode, the key is stored in the repo, but you should back it up separately.
Use "borg key export" to export the key, optionally in printable format.
Write down the passphrase. Store both at safe place(s).
Repository successfully initialized.
Performing backup...
Starting the backup...
Creating archive at "/mnt/borgbackup/borg::20240428_144733-nextcloud-aio"
0 B O 0 B C 0 B D 0 N nextcloud_aio_volumes
zing cache transaction: Reading config
zing cache transaction: Reading chunks
zing cache transaction: Reading files
294 B C 294 B D 1 N nextcloud_aio_volumes/n...o_nextcloud_data/.htaccess
O 1.97 MB C 1.97 MB D 6 N nextcloud_aio_volume...les/Photos/Vineyard.jpg
O 7.60 MB C 7.60 MB D 15 N nextcloud_aio_volum...nts/Nextcloud flyer.pdf
O 9.35 MB C 9.35 MB D 18 N nextcloud_aio_volum...es/Nextcloud Manual.pdf
O 23.19 MB C 23.19 MB D 18 N nextcloud_aio_volu.../Nextcloud Manual.pdf
O 24.96 MB C 24.96 MB D 22 N nextcloud_aio_volu...plates/Photo book.odt
O 28.57 MB C 28.57 MB D 28 N nextcloud_aio_volu.../Templates/Simple.odp
O 33.00 MB C 33.00 MB D 31 N nextcloud_aio_volu...tes/Gotong royong.odp
O 33.11 MB C 33.11 MB D 36 N nextcloud_aio_volu...Templates/Invoice.odt
O 33.85 MB C 33.85 MB D 42 N nextcloud_aio_volu...ates/Mother's day.odt
O 36.46 MB C 36.46 MB D 46 N nextcloud_aio_volu...s/Nextcloud intro.mp4
O 37.33 MB C 37.33 MB D 51 N nextcloud_aio_volu...x1/appstore/apps.json
O 38.04 MB C 38.04 MB D 57 N nextcloud_aio_volu...fonts/Caveat-wght.ttf
O 39.10 MB C 39.10 MB D 63 N nextcloud_aio_volu...s/Montserrat-wght.ttf
O 39.77 MB C 39.77 MB D 69 N nextcloud_aio_volu...s/Oswald-wght.ttf.png
O 39.84 MB C 39.84 MB D 85 N nextcloud_aio_volu...4/49/256-256-crop.jpg
O 39.86 MB C 39.86 MB D 90 N nextcloud_aio_volu...qwtx1/preview/d/6/4/5
O 39.94 MB C 39.94 MB D 94 N nextcloud_aio_volu.../e/37/396-512-max.png
O 40.05 MB C 40.05 MB D 101 N nextcloud_aio_vol...vIcon-settings#0082c9
O 40.10 MB C 40.10 MB D 110 N nextcloud_aio_vol.../admin/avatar.128.png
O 40.23 MB C 40.23 MB D 121 N nextcloud_aio_vol...stercontainer/session
O 40.79 MB C 40.79 MB D 443 N nextcloud_aio_vol...-php/src/CodeArtifact
O 41.00 MB C 41.00 MB D 742 N nextcloud_aio_vol...on/KafkaException.php
O 41.26 MB C 41.26 MB D 1041 N nextcloud_aio_vol...SMContactsClient.php
O 41.67 MB C 41.67 MB D 1301 N nextcloud_aio_vol...01-11/api-2.json.php
O 42.26 MB C 42.26 MB D 1561 N nextcloud_aio_vol...1/waiters-1.json.php
O 42.98 MB C 42.98 MB D 1773 N nextcloud_aio_vol...aginators-1.json.php
O 43.50 MB C 43.50 MB D 1990 N nextcloud_aio_vol...data/mwaa/2020-07-01
O 43.93 MB C 43.93 MB D 2161 N nextcloud_aio_vol...03-01/api-2.json.php
O 44.53 MB C 44.53 MB D 2407 N nextcloud_aio_vol...th/src/BigNumber.php
O 45.05 MB C 45.05 MB D 2724 N nextcloud_aio_vol...andCompatibility.php
O 45.27 MB C 45.27 MB D 3007 N nextcloud_aio_vol...umberMetadata_CD.php
O 45.62 MB C 45.62 MB D 3303 N nextcloud_aio_vol.../psr7/src/Header.php
O 46.18 MB C 46.17 MB D 3643 N nextcloud_aio_vol...zle7-adapter/LICENSE
O 46.97 MB C 46.97 MB D 3934 N nextcloud_aio_vol...rc/data/cs/units.php
O 48.33 MB C 48.05 MB D 4142 N nextcloud_aio_vol...hi/timeZoneNames.php
O 49.75 MB C 49.31 MB D 4365 N nextcloud_aio_vol.../sk/subdivisions.php
B O 50.87 MB C 50.43 MB D 4593 N nextcloud_aio_vo...rgumentException.php
B O 51.46 MB C 51.01 MB D 4956 N nextcloud_aio_vo...ponent/VCalendar.php
B O 51.98 MB C 51.54 MB D 5310 N nextcloud_aio_vo...bstractExtension.php
B O 52.52 MB C 52.07 MB D 5663 N nextcloud_aio_vo...er/MatcherDumper.php
B O 53.03 MB C 52.58 MB D 6029 N nextcloud_aio_vo...Key/SymmetricKey.php
B O 54.98 MB C 54.53 MB D 6174 N nextcloud_aio_vo...ger-YHHKXmsa.mjs.map
B O 55.76 MB C 55.28 MB D 6506 N nextcloud_aio_vo...udit/l10n/es_MX.json
B O 56.80 MB C 56.29 MB D 6842 N nextcloud_aio_vo...circles/l10n/bg.json
B O 57.50 MB C 56.94 MB D 7201 N nextcloud_aio_vo...otFoundException.php
B O 58.02 MB C 57.43 MB D 7565 N nextcloud_aio_vo...s/appinfo/routes.php
B O 58.35 MB C 57.72 MB D 7958 N nextcloud_aio_vo...hboard/l10n/ka_GE.js
B O 59.20 MB C 58.53 MB D 8294 N nextcloud_aio_vo...rdDAV/PhotoCache.php
B O 59.85 MB C 59.12 MB D 8667 N nextcloud_aio_vo...tion/l10n/pt_BR.json
B O 60.45 MB C 59.65 MB D 9048 N nextcloud_aio_vo...eration/l10n/oc.json
B O 61.41 MB C 60.55 MB D 9346 N nextcloud_aio_vo...iles/l10n/pt_PT.json
B O 62.11 MB C 61.21 MB D 9655 N nextcloud_aio_vo...rnal/l10n/es_MX.json
B O 63.76 MB C 62.82 MB D 9899 N nextcloud_aio_vo...d/pdf.sandbox.js.map
B O 66.49 MB C 65.56 MB D 10103 N nextcloud_aio_vo...tton-selectTool.svg
B O 69.25 MB C 68.32 MB D 10269 N nextcloud_aio_vo...fviewer-main.js.map
B O 71.99 MB C 71.06 MB D 10348 N nextcloud_aio_vo...r/package-lock.json
B O 72.90 MB C 71.92 MB D 10632 N nextcloud_aio_vo...ing/l10n/zh_HK.json
B O 73.44 MB C 72.43 MB D 11038 N nextcloud_aio_vo...sions/l10n/es_SV.js
B O 78.98 MB C 77.96 MB D 11203 N nextcloud_aio_vo...nwizard-main.js.map
B O 81.08 MB C 80.04 MB D 11411 N nextcloud_aio_vo...reader-main.mjs.map
B O 81.73 MB C 80.67 MB D 11785 N nextcloud_aio_vo...ments/l10n/es_PY.js
B O 84.24 MB C 83.16 MB D 11911 N nextcloud_aio_vo...ents_-304b96.js.map
B O 86.24 MB C 85.15 MB D 12065 N nextcloud_aio_vo...ations/l10n/oc.json
B O 87.76 MB C 86.64 MB D 12343 N nextcloud_aio_vo...ker-cOp1W5mL_mjs.js
B O 89.90 MB C 88.77 MB D 12544 N nextcloud_aio_vo...y/lists/list-11.php
B O 93.34 MB C 92.20 MB D 12578 N nextcloud_aio_vo...cy/lists/list-8.php
B O 97.00 MB C 95.85 MB D 12597 N nextcloud_aio_vo.../photos-main.js.map
B O 100.23 MB C 99.08 MB D 12626 N nextcloud_aio_v...hotos-public.js.map
B O 102.72 MB C 101.56 MB D 12717 N nextcloud_aio_v.../photos/l10n/el.js
B O 106.30 MB C 105.11 MB D 12986 N nextcloud_aio_v...rivacy-main.js.map
B O 108.29 MB C 107.11 MB D 13096 N nextcloud_aio_v...dminController.php
B O 109.63 MB C 108.42 MB D 13347 N nextcloud_aio_v...tions/package.json
B O 110.44 MB C 109.21 MB D 13627 N nextcloud_aio_v.../package-lock.json
B O 112.21 MB C 110.95 MB D 13928 N nextcloud_aio_v...ettings/l10n/es.js
B O 114.24 MB C 112.91 MB D 14081 N nextcloud_aio_v...eRenderedEvent.php
B O 114.91 MB C 113.53 MB D 14460 N nextcloud_aio_v...support/l10n/sk.js
B O 116.33 MB C 114.90 MB D 14734 N nextcloud_aio_v...ogin/l10n/pt_PT.js
B O 117.11 MB C 115.67 MB D 15102 N nextcloud_aio_v...oSetVisibility.php
B O 117.57 MB C 116.13 MB D 15497 N nextcloud_aio_v...rs/FuzzyCMeans.php
B O 117.96 MB C 116.52 MB D 15896 N nextcloud_aio_v...izers/AdamTest.php
B O 118.43 MB C 116.97 MB D 16280 N nextcloud_aio_v...ring/composer.json
B O 120.58 MB C 119.05 MB D 16576 N nextcloud_aio_v...utohotkey-js-js.js
B O 121.35 MB C 119.82 MB D 16910 N nextcloud_aio_v.../livecodeserver.js
B O 122.09 MB C 120.56 MB D 17174 N nextcloud_aio_v...s/highlight/sqf.js
B O 124.13 MB C 122.60 MB D 17348 N nextcloud_aio_v...ext-editors.js.map
B O 127.81 MB C 126.28 MB D 17357 N nextcloud_aio_v...text-public.js.map
B O 130.92 MB C 129.39 MB D 17366 N nextcloud_aio_v...t-me-01b328.js.map
B O 134.82 MB C 133.29 MB D 17386 N nextcloud_aio_v...extc-dbda74.js.map
B O 137.79 MB C 136.19 MB D 17414 N nextcloud_aio_v...ps/text/l10n/bg.js
B O 157.54 MB C 155.86 MB D 18048 N nextcloud_aio_v...codes/lib/Listener
B O 159.50 MB C 157.80 MB D 18280 N nextcloud_aio_v...platform_check.php
B O 160.85 MB C 158.96 MB D 18553 N nextcloud_aio_v..._ldap/l10n/su.json
B O 162.40 MB C 160.50 MB D 18848 N nextcloud_aio_v...r-filerobot.js.map
B O 166.06 MB C 164.16 MB D 18859 N nextcloud_aio_v...BGB1Rec_mjs.js.map
B O 166.72 MB C 164.78 MB D 19236 N nextcloud_aio_v...ne/l10n/de_DE.json
B O 167.33 MB C 165.36 MB D 19628 N nextcloud_aio_v...core/css/fixes.css
B O 180.21 MB C 178.25 MB D 19988 N nextcloud_aio_v...l_storage/ftp.html
B O 184.38 MB C 182.42 MB D 20168 N nextcloud_aio_v..._images/circle.png
B O 205.34 MB C 200.46 MB D 20429 N nextcloud_aio_v.../NotoSans-Bold.ttf
B O 209.19 MB C 204.32 MB D 20564 N nextcloud_aio_v...aldav/location.png
B O 211.01 MB C 206.13 MB D 20784 N nextcloud_aio_v.../core/l10n/sr.json
B O 247.85 MB C 206.50 MB D 20875 N nextcloud_aio_v...emplates/tags.html
B O 250.96 MB C 209.62 MB D 20927 N nextcloud_aio_v...ist/core-common.js
B O 253.74 MB C 212.39 MB D 20943 N nextcloud_aio_v...gin.js.LICENSE.txt
B O 257.36 MB C 216.02 MB D 20996 N nextcloud_aio_v...les-sidebar.js.map
B O 259.89 MB C 218.55 MB D 21074 N nextcloud_aio_v...sharebymail.js.map
B O 261.55 MB C 220.19 MB D 21295 N nextcloud_aio_v...d/lib/l10n/ta.json
B O 262.25 MB C 220.89 MB D 21674 N nextcloud_aio_v...yOptimizerStep.php
B O 262.91 MB C 221.56 MB D 22063 N nextcloud_aio_v...e/User/Session.php
B O 263.47 MB C 222.12 MB D 22470 N nextcloud_aio_v...e/IObjectStore.php
B O 263.89 MB C 222.54 MB D 22888 N nextcloud_aio_v...b/public/ITags.php
B O 268.62 MB C 227.12 MB D 22945 N nextcloud_aio_v...arch64/notify_push
B O 275.70 MB C 234.21 MB D 22946 N nextcloud_aio_v.../armv7/notify_push
B O 280.62 MB C 239.13 MB D 22947 N nextcloud_aio_v...x86_64/notify_push
B O 284.51 MB C 243.00 MB D 22984 N nextcloud_aio_v...tasks-dashboard.js
B O 287.32 MB C 245.81 MB D 22987 N nextcloud_aio_v...s/js/tasks-main.js
B O 290.09 MB C 248.59 MB D 22990 N nextcloud_aio_v...s/js/tasks-talk.js
B O 292.50 MB C 250.97 MB D 23118 N nextcloud_aio_v...s/tasks/l10n/nl.js
B O 295.40 MB C 253.86 MB D 23204 N nextcloud_aio_v...tes-commons.js.map
B O 298.84 MB C 257.18 MB D 23214 N nextcloud_aio_v...notes/l10n/ar.json
B O 301.02 MB C 259.35 MB D 23481 N nextcloud_aio_v...s/contacts-main.js
B O 303.92 MB C 262.25 MB D 23502 N nextcloud_aio_v...tacts/l10n/ca.json
B O 305.79 MB C 264.08 MB D 23775 N nextcloud_aio_v...ck/js/deck-main.js
B O 309.08 MB C 267.24 MB D 23777 N nextcloud_aio_v...s/deck-main.js.map
B O 312.35 MB C 270.40 MB D 23802 N nextcloud_aio_v...ck/js/deck-talk.js
B O 315.84 MB C 273.77 MB D 23807 N nextcloud_aio_v...e_mo-dee90d.js.map
B O 318.96 MB C 276.77 MB D 23824 N nextcloud_aio_v...index_module_js.js
B O 320.70 MB C 278.36 MB D 24018 N nextcloud_aio_v...ck/l10n/zh_CN.json
B O 323.42 MB C 281.04 MB D 24286 N nextcloud_aio_v...nts-booking.js.map
B O 326.85 MB C 284.47 MB D 24295 N nextcloud_aio_v...ts-overview.js.map
B O 330.04 MB C 287.66 MB D 24304 N nextcloud_aio_v...lendar-main.js.map
B O 333.32 MB C 290.94 MB D 24336 N nextcloud_aio_v...ct_d-732246.js.map
B O 336.57 MB C 294.07 MB D 24348 N nextcloud_aio_v...Dial-e0595f.js.map
B O 338.99 MB C 296.47 MB D 24452 N nextcloud_aio_v...endar/l10n/hu.json
B O 340.00 MB C 297.44 MB D 24816 N nextcloud_aio_v...tivirus/l10n/th.js
B O 345.78 MB C 300.77 MB D 25025 N nextcloud_aio_v...ments-admin.js.map
B O 348.93 MB C 303.92 MB D 25038 N nextcloud_aio_v...ments-reference.js
O 352.22 MB C 307.22 MB D 25045 N nextcloud_aio_vo..._Dial-7228d0.js.map
O 355.40 MB C 310.40 MB D 25048 N nextcloud_aio_vo...ments-viewer.js.map
O 357.07 MB C 312.03 MB D 25342 N nextcloud_aio_vo...search/l10n/an.json
O 361.82 MB C 316.56 MB D 25685 N nextcloud_aio_vo...kgrounds/5_park.jpg
O 368.12 MB C 322.86 MB D 25757 N nextcloud_aio_vo...-collections.js.map
O 371.25 MB C 325.98 MB D 25774 N nextcloud_aio_vo...st_cjs_js-48bdaa.js
O 374.58 MB C 329.32 MB D 25787 N nextcloud_aio_vo...iles-sidebar.js.map
O 377.66 MB C 332.40 MB D 25790 N nextcloud_aio_vo...eed/js/talk-main.js
O 380.76 MB C 335.49 MB D 25791 N nextcloud_aio_vo...js/talk-main.js.map
O 384.49 MB C 339.23 MB D 25799 N nextcloud_aio_vo...auth-sidebar.js.map
O 387.97 MB C 342.60 MB D 25800 N nextcloud_aio_vo...ic-share-sidebar.js
O 392.23 MB C 346.75 MB D 25802 N nextcloud_aio_vo...s/talk-recording.js
O 395.60 MB C 350.00 MB D 25804 N nextcloud_aio_vo...js/tflite-simd.wasm
O 398.18 MB C 352.56 MB D 25908 N nextcloud_aio_vo...spreed/l10n/nb.json
O 399.39 MB C 353.77 MB D 25961 N nextcloud_aio_vo...undJob/Reminder.php
O 399.99 MB C 354.37 MB D 26347 N nextcloud_aio_vo...sponses/DialOut.php
O 400.51 MB C 354.89 MB D 26692 N nextcloud_aio_vo...spreed/package.json
O 401.06 MB C 355.39 MB D 27107 N nextcloud_aio_vo...icsearch/l10n/ca.js
O 401.29 MB C 355.61 MB D 27585 N nextcloud_aio_vo...cce1920a06.asciidoc
O 404.17 MB C 358.48 MB D 27819 N nextcloud_aio_vo...0010000000000000001
O 405.70 MB C 360.01 MB D 27891 N nextcloud_aio_vo...atabase/base/1/1249
O 406.97 MB C 360.83 MB D 28324 N nextcloud_aio_vo...atabase/base/4/3466
O 408.80 MB C 361.36 MB D 28817 N nextcloud_aio_vo...ase/base/16384/2337
O 409.35 MB C 361.91 MB D 28959 N nextcloud_aio_vo...ase/base/16384/1255
O 409.79 MB C 362.35 MB D 29429 N nextcloud_aio_vo...se/base/16384/17163
ception
Traceback (most recent call last):
File "/usr/lib/python3.11/site-packages/borg/archiver.py", line 5343, in main
exit_code = archiver.run(args)
File "/usr/lib/python3.11/site-packages/borg/archiver.py", line 5263, in run
return set_ec(func(args))
File "/usr/lib/python3.11/site-packages/borg/archiver.py", line 189, in wrapper
return method(self, args, repository=repository, **kwargs)
File "/usr/lib/python3.11/site-packages/borg/archiver.py", line 672, in do_create
create_inner(archive, cache, fso)
File "/usr/lib/python3.11/site-packages/borg/archiver.py", line 626, in create_inner
archive.save(comment=args.comment, timestamp=args.timestamp)
File "/usr/lib/python3.11/site-packages/borg/archive.py", line 666, in save
self.manifest.write()
File "/usr/lib/python3.11/site-packages/borg/helpers/manifest.py", line 265, in write
self.repository.put(self.MANIFEST_ID, self.key.encrypt(data))
File "/usr/lib/python3.11/site-packages/borg/repository.py", line 1235, in put
self._delete(id, segment, offset)
File "/usr/lib/python3.11/site-packages/borg/repository.py", line 1270, in _delete
segment, size = self.io.write_delete(id)
File "/usr/lib/python3.11/site-packages/borg/repository.py", line 1689, in write_delete
fd = self.get_write_fd(want_new=(id == Manifest.MANIFEST_ID), raise_full=raise_full)
File "/usr/lib/python3.11/site-packages/borg/repository.py", line 1437, in get_write_fd
self.close_segment()
File "/usr/lib/python3.11/site-packages/borg/repository.py", line 1493, in close_segment
fd.close()
File "/usr/lib/python3.11/site-packages/borg/platform/base.py", line 194, in close
self.sync()
File "/usr/lib/python3.11/site-packages/borg/platform/base.py", line 183, in sync
platform.fdatasync(self.fd)
ConnectionResetError: [Errno 104] Connection reset by peer
Platform: Linux f7c94a24b25d 5.15.0-105-generic #115-Ubuntu SMP Mon Apr 15 09:52:04 UTC 2024 x86_64
Linux: Unknown Linux
Borg: 1.2.7 Python: CPython 3.11.9 msgpack: 1.0.6 fuse: llfuse 1.5.0 [pyfuse3,llfuse]
PID: 43 CWD: /
sys.argv: ['/usr/bin/borg', 'create', '-v', '--stats', '--compression', 'auto,zstd', '--exclude-caches', '--progress', '--exclude', '/nextcloud_aio_volumes/nextcloud_aio_nextcloud/data/nextcloud.log*', '--exclude', '/nextcloud_aio_volumes/nextcloud_aio_nextcloud/data/audit.log', '/mnt/borgbackup/borg::20240428_144733-nextcloud-aio', '/nextcloud_aio_volumes/']
SSH_ORIGINAL_COMMAND: None
Deleting the failed backup archive...
Archive 20240428_144733-nextcloud-aio not found (1/1).
Original size Compressed size Deduplicated size
Deleted data: 0 B 0 B 0 B
All archives: 0 B 0 B 0 B
Unique chunks Total chunks
Chunk index: 0 0
Backup failed!
You might want to check the backup integrity via the AIO interface.
Deleting borg.config file so that you can choose a different location for the backup.
