Nextcloud Assistant and Lemonade: how to configure the connection?
Hello
I have changed Ollama to Lemonade, more powerful, quicker than Ollama, and able to make images.
I tried to connect it to Nextcloud assistant. Using the Ollama syntax with the rignt port, I can find models in the choice liste pour text, images, etc. It seems to work. But at the moment I try to generate a text, I have an error, and nothing happens on the AI server. Is there a dedicated tuning to apply? Thank you
