example
longer
example
here
Nextcloud version (eg, 20.0.5): 22.1.1
Operating system and version (eg, Ubuntu 20.04): Docker Container on DS920+
Apache or nginx version (eg, Apache 2.4.25): unsure
PHP version (eg, 7.4): unsure
I’m trying to run Nextcloud as a Dropbox replacement on my Synology Diskstation 920+ via a Docker container created in this manner (Synology: How to Install Nextcloud Using Docker – Marius Hosting). For the most part, it’s working exactly as I hoped, with one exception: I can’t access it if I’m not connected to my home WiFi (or behind a VPN). I know it has something to do with opening ports, however I’ve already opened ports 80, 443, and 5001 on my router (see attached). I’m hoping I can figure this out, because I really do love using Nextcloud, and any help would be appreciated.
- Disconnect from home WiFi
- Open Nextcloud
- Attempt to Access file
Error index OCP\Files\NotFoundException: /Chas/files/Music
2021-09-07T21:22:13-0400
2021-09-05T12:20:59-0400
2021-09-05T12:19:28-0400
2021-09-05T12:01:04-0400
2021-09-05T12:00:57-0400
2021-09-05T11:50:33-0400
2021-09-05T11:50:29-0400
Error no app in context OCP\Files\NotFoundException: /Chas/files/Music/Bruce Springsteen
2021-09-05T11:48:40-0400
Error PHP Error: Cannot modify header information - headers already sent by (output started at /var/www/html/3rdparty/sabre/http/lib/Sapi.php:132) at /var/www/html/apps/dav/lib/Connector/Sabre/File.php#693
2021-09-05T11:42:39-0400
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 8824785 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 4138384 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 8263041 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 2470288 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Error no app in context Sabre\DAV\Exception\BadRequest: Expected filesize of 7399603 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 3611312 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side.
Fatal webdav OC\DB\Exceptions\DbalException: An exception occurred while executing a query: SQLSTATE[40001]: Serialization failure: 1213 Deadlock found when trying to get lock; try restarting transaction
2021-09-05T11:22:50-0400
2021-09-05T11:21:49-0400
2021-09-05T11:21:48-0400
2021-09-05T11:21:26-0400
2021-09-05T11:21:23-0400
2021-09-05T11:21:20-0400
2021-09-05T11:21:07-0400
2021-09-05T11:21:02-0400
2021-09-05T11:21:01-0400
Warning core Renewing session token failed
2021-09-04T08:45:41-0400
Warning core Login failed: 'cbelfield' (Remote IP: '172.21.0.1')
2021-09-04T08:25:11-0400
2021-09-04T08:25:06-0400
2021-09-04T08:17:04-0400
2021-09-04T08:17:02-0400
2021-09-04T08:02:33-0400
2021-09-04T08:02:31-0400
Error no app in context Swift_TransportException: Connection could not be established with host 127.0.0.1 :stream_socket_client(): Unable to connect to 127.0.0.1:25 (Connection refused)
2021-09-04T08:01:57-0400
Warning no app in context Could not detect any host in https:///data/htaccesstest.txt
2021-09-04T07:54:15-0400
Warning no app in context Could not detect any host in http:///data/htaccesstest.txt
2021-09-04T07:53:14-0400
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'instanceid' => 'ock0twio2c1l',
'passwordsalt' => 'kUuJ5UUE2m6pfTxuud9jz+92njn9YW',
'secret' => '1akB7AyyHC9/IcEsu4Gdq1c8KzA/wPXQ0fDuHg3uuqIfwyyC',
0 => 'XXX.XXX.X.XX:XXXX',
'version' => '22.1.1.2',
'overwrite.cli.url' => 'http://XXX.XXX.X.XX:XXXX',
'dbname' => 'XXXX',
'dbhost' => 'mariadb',
'dbuser' => 'XXXX',
'dbpassword' => 'XXXX',
I'm afraid I don't understand what this is, or if it even exists in Docker (I'm new to that as well)
