Nextcloud AppStore Login not possible - resolved
I’ve been having login issues with the App Store app, https://apps.nextcloud.com/, for the past two days. I’ve reset my password twice but it still won’t let me log in. This prevents me from deploying an update for one of my apps.
Has anyone else experienced this problem?
Best
I was just not able to successfully log in using GitHub OAuth2. That worked well.
Do you use a dedicated account or OAuth2?
Tried via github login, leading to server error 500. With dedicated accounts it’s still not working.
I tried vpn as well to connect to another appstore server or whatever.
I will reach out to support now.
however the only way to get support for the community version is here… deadend :frowning: I’m just want to extend nextcloud with my app… login/upload was working find before.
Hey, please send me your account details in PM so I can check internally if there’s an error. Other than that, you successfully received the password reset mail?
I‘m not able to find any PM module in this forum. I send my request to contact -at-nextcloud.com. Hope this reaches you as well.
Edit: yes, I received all reset mails and was able to set a new pwd. It was confirmed but immediately after my login (with same password from clipboard) was not possible. Feels like my user got blocked…
I have not yet reached trust level 1 , no pm feature for beginners here
Sorry, will reach out directly
Topic resolved. I accidentally took my mail address as username. I stored it as username in my pwd manager initially. So user fault, just overseeing… while using my username all works fine.
sorry for this unnecessary discussion. Thanks for your support anyhow!
