Hi all !
I am having a hard time trying to setup the redirections mentionned in the admin panel :
- /.well-known/webfinger ».
« /.well-known/nodeinfo ».
« /.well-known/caldav »
« /.well-known/carddav »
I know there are other topics but I can’t get to understand or have those alerts removed.
I have done what’s in the doc without success (.htaccess part) General troubleshooting — Nextcloud latest Administration Manual latest documentation
-I am running apache2 on a Debian 12 VPS.
-My nextcloud root is in /usr/share/nextcloud/
-PHP is 8.2
-I have two virtualhosts, nextcloud.conf and nextcloud-ssl.conf
nextcloud.conf :
<VirtualHost *:80>
DocumentRoot /usr/share/nextcloud/
ServerName nextcloud.mydomain.com
Redirect permanent / https://nextcloud.mydomain.com/
<Directory /usr/share/nextcloud/>
Require all granted
Options -Indexes +FollowSymLinks +MultiViews
AllowOverride ALL
<IfModule mod_dav.c>
Dav off
</IfModule>
#Order allow,deny
#Allow from all
</Directory>
</VirtualHost>
-In the doc they say to put Dav off I don’t know what it means. I have tried putting Dav on without success.
nextcloud-ssl.conf :
<IfModule mod_ssl.c>
<VirtualHost *:443>
<IfModule mod_headers.c>
Header always set Strict-Transport-Security "max-age=15552000; includeSubDomains"
</IfModule>
Options FollowSymLinks
AllowOverride ALL
Order allow,deny
Allow from all
</Directory>
ErrorLog ${APACHE_LOG_DIR}/nextcloud.error.log
LogLevel warn
CustomLog ${APACHE_LOG_DIR}/nextcloud.ssl_access.log combined
SSLEngine on
SSLCertificateFile /files_directory/fullchain.pem
SSLCertificateKeyFile /files_directory/privkey.pem
</VirtualHost>
</IfModule>
-The .htaccess which is in the /usr/share/nextcloud :
#### DO NOT CHANGE ANYTHING ABOVE THIS LINE ####
ErrorDocument 403 /index.php/error/403
ErrorDocument 404 /index.php/error/404
-If I write something in there, when I run the occ maintenance:update:htaccess, everything gets erased.
-Mod Rewrite is enabled :
a2query -m gives rewrite (enabled by site administrator)
I have tried adding this in the .htaccess but I think it’s not the way since the file gets erased when doing the occ command :
** RewriteEngine on**
** RewriteRule ^.well-known/carddav /nextcloud/remote.php/dav [R=301,L]**
** RewriteRule ^.well-known/caldav /nextcloud/remote.php/dav [R=301,L]**
** RewriteRule ^.well-known/webfinger /nextcloud/index.php/.well-known/webfinger [R=301,L]**
** RewriteRule ^.well-known/nodeinfo /nextcloud/index.php/.well-known/nodeinfo [R=301,L]**
-i have tried with and without the /nextcloud/ part, or adding /usr/share/ etc but nothing is ok.
-I have tried adding this directly in the nextcloud.conf and/or nextcloud-ssl.conf but nope. When doing that I have added the “/” before "^"
The /usr/share/nextcloud/config/config.php file :
'instanceid' => 'blah',
'passwordsalt' => 'blahblahblah',
'secret' => 'blahblahblah',
0 => 'nextcloud.mydomain.com',
'datadirectory' => '/usr/share/nextcloud/data',
'overwrite.cli.url' => 'https://nextcloud.mydomain.com/',
# 'htaccess.RewriteBase' => '/',
'memcache.local' => '\OC\Memcache\APCu',
'version' => '28.0.4.1',
'dbname' => 'blahblahblah',
'dbhost' => 'localhost',
'dbuser' => 'blahblahblah',
'dbpassword' => 'blahblahblah',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'blahblahblah',
'mail_domain' => 'mydomain.com',
'mail_smtphost' => 'blahblahblah',
'mail_smtpport' => '465',
'mail_smtpauth' => 1,
'mail_smtpname' => 'blahblahblah',
'mail_smtppassword' => 'blahblahblah',
-The htaccess.RewriteBase is commented because it’s also creating display issues by the way. Basically images won’t display. Maybe the same problem ?
Also when I browse this url I get the message showing it is present :
https://example.com/remote.php/dav
This is the WebDAV interface. It can only be accessed by WebDAV clients such as the Nextcloud desktop sync client.
I also have these issues on the admin panel :
- core
- INVALID_HASH
- .htaccess
- FILE_MISSING
- .user.ini
- 3rdparty/aws/aws-crt-php/gen_stub.php
-Maybe it is related ?
Well it is pretty much what I can say. I think I just don’t understand how redirections and .htaccess are working.
HTTPS is working and redirected automatically.
Thanks for your help ![]()
