Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can. ![]()
* Nextcloud Server version:
- `Nextcloud 33.0.0`
* Operating system and version: - `#1 SMP PREEMPT Debian 1:6.12.62-1+rpt1~bookworm (2026-01-19)`
* Web server and version: - `Server version: Apache/2.4.66 (Debian)`
* Reverse proxy and version: - `nginx version: openresty/1.27.1.2`
* PHP version: - `PHP 8.4.18 (cli) (built: Feb 24 2026 19:12:53) (NTS)`
* Is this the first time you’ve seen this error? (Yes / No): - `yes`
* When did this problem seem to first start? - `prob direct after installation`
* Installation method _(e.g. AlO, NCP, Bare Metal/Archive, etc.)_ - `OMV Container`
* Are you using CloudfIare, mod_security, or similar? _(Yes / No)_ - `nope`
“system”: {
“instanceid”: “***REMOVED SENSITIVE VALUE***”,
“version”: “33.0.0.16”,
“loglevel”: 3,
“log_rotate_size”: 262144,
“maintenance”: false,
“maintenance_window_start”: 3,
“default_locale”: “DE_CH”,
“default_phone_region”: “CH”,
“datadirectory”: “***REMOVED SENSITIVE VALUE***”,
“memcache.local”: “\\OC\\Memcache\\APCu”,
“memcache.distributed”: “\\OC\\Memcache\\Redis”,
“memcache.locking”: “\\OC\\Memcache\\Redis”,
“redis”: {
“host”: “***REMOVED SENSITIVE VALUE***”,
“password”: “***REMOVED SENSITIVE VALUE***”,
“port”: 6379
“upgrade.disable-web”: true,
“passwordsalt”: “***REMOVED SENSITIVE VALUE***”,
“secret”: “***REMOVED SENSITIVE VALUE***”,
“dbtype”: “mysql”,
“mysql.utf8mb4”: true,
“dbhost”: “***REMOVED SENSITIVE VALUE***”,
“dbport”: “”,
“dbuser”: “***REMOVED SENSITIVE VALUE***”,
“dbname”: “***REMOVED SENSITIVE VALUE***”,
“dbpassword”: “***REMOVED SENSITIVE VALUE***”,
“dbtableprefix”: “oc_”,
“htaccess.RewriteBase”: “\/”,
“trusted_domains”: [
“srv-nas-pi.kingma:8080”,
“office.kingma.ch”,
“office.king.ma”
“overwrite.cli.url”: “https:\/\/office.kingma.ch”,
“overwriteprotocol”: “https”,
“apps_paths”: [
“path”: “\/var\/www\/html\/apps”,
“url”: “\/apps”,
“writable”: false
“path”: “\/var\/www\/html\/custom_apps”,
“url”: “\/custom_apps”,
“writable”: true
“mail_smtpmode”: “smtp”,
“mail_sendmailmode”: “smtp”,
“mail_from_address”: “***REMOVED SENSITIVE VALUE***”,
“mail_domain”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtphost”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtpport”: “465”,
“mail_smpttimeout”: 30,
“installed”: true,
“mail_smtpauth”: true,
“mail_smtpname”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtppassword”: “***REMOVED SENSITIVE VALUE***”,
“mail_smtpsecure”: “ssl”,
“app_install_overwrite”: []
- activity: 6.0.0-dev.0
- admin_audit: 1.23.0
- bookmarks: 16.1.3
- brewmemo: 0.6.0
- bruteforcesettings: 6.0.0-dev.0
- calendar: 6.2.1
- circles: 33.0.0
- cloud_federation_api: 1.17.0
- comments: 1.23.0
- contacts: 8.4.0
- contactsinteraction: 1.14.1
- cookbook: 0.11.6
- dashboard: 7.13.0
- dav: 1.36.0
- encryption: 2.21.0
- end_to_end_encryption: 2.0.0
- federatedfilesharing: 1.23.0
- federation: 1.23.0
- files: 2.5.0
- files_downloadlimit: 5.1.0-dev.0
- files_external: 1.25.1
- files_pdfviewer: 6.0.0-dev.0
- files_reminders: 1.6.0
- files_sharing: 1.25.2
- files_trashbin: 1.23.0
- files_versions: 1.26.0
- firstrunwizard: 6.0.0-dev.0
- fulltextsearch: 33.0.0
- groupfolders: 21.0.6
- logreader: 6.0.0
- lookup_server_connector: 1.21.0
- nextcloud_announcements: 5.0.0
- notes: 4.13.0
- notifications: 6.0.0
- oauth2: 1.21.0
- onlyoffice: 10.0.0
- password_policy: 5.0.0-dev.0
- photos: 6.0.0-dev.0
- privacy: 5.0.0-dev.0
- profile: 1.2.0
- provisioning_api: 1.23.0
- recommendations: 6.0.0-dev.0
- related_resources: 4.0.0-dev.0
- richdocuments: 10.1.0
- serverinfo: 5.0.0-dev.0
- settings: 1.16.0
- sharebymail: 1.23.0
- support: 5.0.0
- survey_client: 5.0.0-dev.0
- suspicious_login: 11.0.0-dev.0
- systemtags: 1.23.0
- text: 7.0.0-dev.3
- theming: 2.8.0
- twofactor_backupcodes: 1.22.0
- twofactor_nextcloud_notification: 7.0.0
- twofactor_totp: 15.0.0-dev.0
- updatenotification: 1.23.0
- user_status: 1.13.0
- viewer: 6.0.0-dev.0
- weather_status: 1.13.0
- webhook_listeners: 1.5.0
- workflowengine: 2.15.0
Disabled:- app_api: 33.0.0 (installed 32.0.0)
- camerarawpreviews: 0.8.8 (installed 0.8.8)
- documentserver_community: 0.2.1 (installed 0.2.1)
- keeweb: 0.6.22 (installed 0.6.22)
- user_ldap: 1.24.0 (installed 1.22.0)
Android auto instant upload of OpenCamera creates files that cannot be sync with linux desktop client
- Setup Instand upload and include OpenCamera as source for uploads
- Take a picture and waits until it is uploaded
This file is available on the webgui and 6GB in size,
OpenCamera creates two files a .dng and a DRO.jpg file. Both are on the server, the Linux client only downloads/syncs the .dng one not the .jpg one.
No errors are logged
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the *Copy raw* option from *Administration se
ttings->Logging* screen or from your `nextcloud.log` located in your data directory). Feel free to use a pastebin/gist service if necessary.
PASTE HERE
