example
longer
example
here
Nextcloud version (eg, 20.0.5): 27.1.0 (docker) + 25.0.12 deb
Operating system and version (eg, Ubuntu 20.04): debian 12
Apache or nginx version (eg, Apache 2.4.25): nginx
PHP version (eg, 7.4): 7.4
Trying to connect onlyoffice docs (installed in a docker) with nextcloud, both services are on same server bit with different public addresses and ssl certificates. Both are working separately, but together only if I’m opening nextcloud from local network and enter local ip address of onlyoffice docs. Public address of onlyoffice is being saved but once you try to open any office file onlyoffice is starting but not opening the file and is showing an error message “Download failed”.
- install nextcloud
- install onlyoffice in a container
- road first public address to nextcloud and get ssl certificate
- road second public address to onyloffice and get ssl certificate
- open nextcloud in local network
- save public address of onlyoffice server in nextcloud settings
- Try to open any office file
This is the last error in the log, others are the same. The time is different from the last time I tried to open an office file.
Error onlyoffice Exception: Error occurred in the document service: Error while downloading the document file to be converted.
/var/www/html/custom_apps/onlyoffice/lib/DocumentService.php - line 95:
OCA\Onlyoffice\DocumentService->ProcessConvServResponceError("-4")
/var/www/html/custom_apps/onlyoffice/lib/Preview.php - line 269:
OCA\Onlyoffice\DocumentService->GetConvertedUri("http://127. ... g", "ods", "jpeg", "1411137661")
/var/www/html/lib/private/Preview/ProviderV1Adapter.php - line 53:
OCA\Onlyoffice\Preview->getThumbnail("Business model canvas.ods", 4096, 4096, false, [ "OC\\Files\\View"])
/var/www/html/lib/private/Preview/GeneratorHelper.php - line 64:
OC\Preview\ProviderV1Adapter->getThumbnail([ "OC\\Files\\Node\\File"], 4096, 4096)
/var/www/html/lib/private/Preview/Generator.php - line 397:
OC\Preview\GeneratorHelper->getThumbnail([ "OC\\Previ ... "], [ "OC\\Files\\Node\\File"], 4096, 4096)
/var/www/html/lib/private/Preview/Generator.php - line 373:
OC\Preview\Generator->generateProviderPreview([ "OC\\Files ... "], [ "OC\\Files\\Node\\File"], 4096, 4096, false, true, "application ... t", "")
/var/www/html/lib/private/Preview/Generator.php - line 166:
OC\Preview\Generator->getMaxPreview([ "OC\\Files ... "], [], [ "OC\\Files\\Node\\File"], "application ... t", "")
/var/www/html/lib/private/Preview/Generator.php - line 116:
OC\Preview\Generator->generatePreviews([ "OC\\Files\\Node\\File"], [ [ 250,250,false,"fill"]], "application ... t")
/var/www/html/lib/private/PreviewManager.php - line 192:
OC\Preview\Generator->getPreview([ "OC\\Files\\Node\\File"], 250, 250, false, "fill", null)
/var/www/html/core/Controller/PreviewController.php - line 144:
OC\PreviewManager->getPreview([ "OC\\Files\\Node\\File"], 250, 250, false, "fill")
/var/www/html/core/Controller/PreviewController.php - line 113:
OC\Core\Controller\PreviewController->fetchPreview([ "OC\\Files\\Node\\File"], 250, 250, true, false, "fill")
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 230:
OC\Core\Controller\PreviewController->getPreviewByFileId(42, 250, 250, true, false, "fill")
/var/www/html/lib/private/AppFramework/Http/Dispatcher.php - line 137:
OC\AppFramework\Http\Dispatcher->executeController([ "OC\\Core\ ... "], "getPreviewByFileId")
/var/www/html/lib/private/AppFramework/App.php - line 183:
OC\AppFramework\Http\Dispatcher->dispatch([ "OC\\Core\ ... "], "getPreviewByFileId")
/var/www/html/lib/private/Route/Router.php - line 315:
OC\AppFramework\App::main("OC\\Core\\C ... r", "getPreviewByFileId", [ "OC\\AppFr ... "], [ "core.Prev ... "])
/var/www/html/lib/base.php - line 1068:
OC\Route\Router->match("/core/preview")
/var/www/html/index.php - line 36:
OC::handleRequest()
'instanceid' => 'ocuic1candoc',
'passwordsalt' => 'XXX'
'secret' => 'XXX'
'allow_local_remote_servers' => true,
0 => 'cloud.XXXnet',
1 => 'office.XXXnet',
2 => 'cloud.ftmh-russia.ru',
'onlyoffice' =>
'verify_peer_off' => true,
'jwt_header' => 'Authorization',
'jwt_secret' => 'XXX',
'datadirectory' => '/media/cloud',
'version' => '25.0.12.0',
'overwrite.cli.url' => 'https://cloud.XXX.net',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'XXX',
'dbpassword' => 'XXX',
'theme' => '',
'loglevel' => 2,
'app_install_overwrite' =>
0 => 'occweb',
1 => 'flow_notifications',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'ssl',
'mail_from_address' => 'info',
'mail_domain' => 'XXX',
'mail_smtpauth' => 1,
'mail_smtphost' => 'XXX',
'mail_smtpport' => '465',
'mail_smtpname' => 'info@XXX',
'mail_smtppassword' => 'XXX',
'updater.secret' => 'XXX'
nothing related
PASTE HERE
PASTE HERE
PASTE HERE
