Hello, I use centos7 x64 bits machine.
I installed nextcloud 14 on it and it’s working nice
i installed collabora on it from binaries (not docker image), and it seems also to be working fine as i can open admin page and i see the xml tags.
Both nextcloud and collabora are with no ssl as i configured them to use http not https as a test.
The problem is after doing the integration.
When i open any document it doesn’t give error but it gives a Grey window of collabora with no way to do anything
After checking logs specially “loolwsd.log” , I found the following:
“WRN WOPI host did not pass optional access_token_ttl| wsd/FileServer.cpp”
But, I have no clue about the cause or how to solve it.
the url that i get is similar to:
http://x.x.x.x/nextcloud/index.php/apps/files/?dir=/&fileid=7
where x.x.x.x is my server real IP.
Please, any suggestions or ideas?
