Nextcloud AIO with Caddy TLS and Pihole ISSUES "slim application error or nothing at all"
    • aio-nextcloud:beta and the main channel docker
    • ubuntu 20.04
    • Server version: Apache/2.4.52 (Ubuntu)
      Server built: 2025-08-11T12:10:10
    • caddy 551f793700fe1550845c824470b623fd1aa03d36
    • PHP 8.1.2-1ubuntu2.22
    • yes
    • in the last 2 weeks or sumthin
    • docker
    • no
I installed from the main docker channel AIO using caddy reverse proxy and proceeded to the main page https://192.168.1.11:8080/ started the containers then clicked “open your nextcloud” Nothing showed up. Nuked the whole thing and reinstalled from scratch and got “slim application error” sooo then I installed the beta version and fixed that problem but now I still have my original issue.
2025-11-18T19:44:53.621854012Z Trying to fix docker.sock permissions internally...
2025-11-18T19:44:53.625135535Z Adding internal www-data to group ping
2025-11-18T19:44:57.131112024Z e[0;92mInitial startup of Nextcloud All-in-One complete!
2025-11-18T19:44:57.131174141Z You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2025-11-18T19:44:57.131193124Z E.g. https://internal.ip.of.this.server:8080
2025-11-18T19:44:57.131208987Z ⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
2025-11-18T19:44:57.131225855Z
2025-11-18T19:44:57.131239869Z If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2025-11-18T19:44:57.131255399Z https://your-domain-that-points-to-this-server.tld:8443e[0m
2025-11-18T19:44:57.630202167Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-11-18T19:44:57.630237769Z   import pkg_resources
2025-11-18T19:45:00.229188113Z {"level":"info","ts":1763495100.2286994,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
2025-11-18T19:45:00.229231931Z {"level":"info","ts":1763495100.228897,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":15017213952,"previous":9223372036854775807}
2025-11-18T19:45:00.229241401Z {"level":"info","ts":1763495100.2289753,"msg":"using config from file","file":"/Caddyfile"}
2025-11-18T19:45:00.230447045Z {"level":"info","ts":1763495100.2302947,"msg":"adapted config to JSON","adapter":"caddyfile"}
2025-11-18T19:45:00.232805638Z [18-Nov-2025 19:45:00] NOTICE: fpm is running, pid 173
2025-11-18T19:45:00.232880880Z [18-Nov-2025 19:45:00] NOTICE: ready to handle connections
2025-11-18T19:45:00.233019364Z {"level":"info","ts":1763495100.2326043,"msg":"serving initial configuration"}
2025-11-18T19:45:00.410193372Z [Tue Nov 18 19:45:00.409807 2025] [mpm_event:notice] [pid 167:tid 167] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.4 configured -- resuming normal operations
2025-11-18T19:45:00.410228762Z [Tue Nov 18 19:45:00.409900 2025] [core:notice] [pid 167:tid 167] AH00094: Command line: 'httpd -D FOREGROUND'
2025-11-18T19:48:14.305527769Z [18-Nov-2025 19:48:14] NOTICE: Terminating ...
2025-11-18T19:48:14.305573472Z [18-Nov-2025 19:48:14] NOTICE: exiting, bye-bye!
2025-11-18T19:48:17.356677474Z [Tue Nov 18 19:48:17.356195 2025] [mpm_event:notice] [pid 167:tid 167] AH00491: caught SIGTERM, shutting down
2025-11-18T19:53:15.478431984Z e[0;31mIt seems like you did not give the mastercontainer the correct name? (The 'nextcloud-aio-mastercontainer' container was not found.)
2025-11-18T19:53:15.478451892Z Using a different name is not supported since mastercontainer updates will not work in that case!
2025-11-18T19:53:15.478468091Z If you are on docker swarm and try to run AIO, see https://github.com/nextcloud/all-in-one#can-i-run-this-with-docker-swarme[0m
2025-11-18T19:53:20.256416099Z e[0;92mInitial startup of Nextcloud All-in-One complete!
2025-11-18T19:53:20.256437918Z You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2025-11-18T19:53:20.256442591Z E.g. https://internal.ip.of.this.server:8080
2025-11-18T19:53:20.256457531Z ⚠️ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
2025-11-18T19:53:20.256465294Z
2025-11-18T19:53:20.256479589Z If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2025-11-18T19:53:20.256483771Z https://your-domain-that-points-to-this-server.tld:8443e[0m
2025-11-18T19:53:20.496403020Z /usr/lib/python3.12/site-packages/supervisor/options.py:13: UserWarning: pkg_resources is deprecated as an API. See https://setuptools.pypa.io/en/latest/pkg_resources.html. The pkg_resources package is slated for removal as early as 2025-11-30. Refrain from using this package or pin to Setuptools<81.
2025-11-18T19:53:20.714890031Z   import pkg_resources
2025-11-18T19:53:21.779289194Z [Tue Nov 18 19:53:21.778918 2025] [mpm_event:notice] [pid 171:tid 171] AH00489: Apache/2.4.65 (Unix) OpenSSL/3.5.4 configured -- resuming normal operations
2025-11-18T19:53:21.779364646Z [Tue Nov 18 19:53:21.778962 2025] [core:notice] [pid 171:tid 171] AH00094: Command line: 'httpd -D FOREGROUND'
2025-11-18T19:53:21.782932705Z [18-Nov-2025 19:53:21] NOTICE: fpm is running, pid 180
2025-11-18T19:53:21.782947796Z [18-Nov-2025 19:53:21] NOTICE: ready to handle connections
2025-11-18T19:53:21.790027882Z {"level":"info","ts":1763495601.7898226,"msg":"maxprocs: Leaving GOMAXPROCS=8: CPU quota undefined"}
2025-11-18T19:53:21.790133725Z {"level":"info","ts":1763495601.7900147,"msg":"GOMEMLIMIT is updated","package":"github.com/KimMachineGun/automemlimit/memlimit","GOMEMLIMIT":15017213952,"previous":9223372036854775807}
2025-11-18T19:53:21.790238842Z {"level":"info","ts":1763495601.7900732,"msg":"using config from file","file":"/Caddyfile"}
2025-11-18T19:53:21.791350524Z {"level":"info","ts":1763495601.7912366,"msg":"adapted config to JSON","adapter":"caddyfile"}
2025-11-18T19:53:21.792859233Z {"level":"info","ts":1763495601.7927127,"msg":"serving initial configuration"}
2025-11-18T19:55:44.557012114Z NOTICE: PHP message: Skipping domain validation
2025-11-18T20:13:56.051013070Z NOTICE: PHP message: 404 Not Found
2025-11-18T20:13:56.080377837Z Type: Slim\Exception\HttpNotFoundException
2025-11-18T20:13:56.080397007Z Code: 404
2025-11-18T20:13:56.080401171Z Message: Not found.
2025-11-18T20:13:56.080404665Z File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
2025-11-18T20:13:56.080408196Z Line: 76
2025-11-18T20:13:56.080422480Z Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080426717Z #1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080429632Z #2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
2025-11-18T20:13:56.080434616Z #3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080437666Z #4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-11-18T20:13:56.080440672Z #5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(53): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080443506Z #6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-11-18T20:13:56.080446434Z #7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080449212Z #8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-11-18T20:13:56.080452155Z #9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080457530Z #10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080460391Z #11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-18T20:13:56.080463036Z #12 /var/www/docker-aio/php/public/index.php(199): Slim\App->run()
2025-11-18T20:13:56.080465449Z #13 {main}
2025-11-18T20:13:56.080467671Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2025-11-19T04:00:25.633589459Z nextcloud-aio-domaincheck
2025-11-19T04:00:25.653186555Z Total reclaimed space: 0B
2025-11-19T04:50:23.140796378Z Deleting duplicate sessions
2025-11-19T04:51:25.275157714Z Deleting duplicate sessions
2025-11-19T04:54:59.447373164Z NOTICE: PHP message: 404 Not Found
2025-11-19T04:54:59.447425945Z Type: Slim\Exception\HttpNotFoundException
2025-11-19T04:54:59.447454296Z Code: 404
2025-11-19T04:54:59.447461374Z Message: Not found.
2025-11-19T04:54:59.447467396Z File: /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/RoutingMiddleware.php
2025-11-19T04:54:59.447473432Z Line: 76
2025-11-19T04:54:59.447478851Z Trace: #0 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(62): Slim\Middleware\RoutingMiddleware->performRouting(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447485907Z #1 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447492507Z #2 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(178): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
2025-11-19T04:54:59.447501126Z #3 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(117): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447508368Z #4 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-11-19T04:54:59.447515579Z #5 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(53): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447522161Z #6 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(283): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-11-19T04:54:59.447529177Z #7 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(77): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447535717Z #8 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(129): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
2025-11-19T04:54:59.447542587Z #9 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(73): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447551034Z #10 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(209): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447557882Z #11 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(193): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
2025-11-19T04:54:59.447564153Z #12 /var/www/docker-aio/php/public/index.php(199): Slim\App->run()
2025-11-19T04:54:59.447569854Z #13 {main}
2025-11-19T04:54:59.447575012Z Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
2025-11-19T05:16:05.277174575Z Deleting duplicate sessions
PASTE
PASTE HEREservices:
    image: ghcr.io/nextcloud-releases/all-in-one:beta
    init: true
    restart: always
    volumes:
    network_mode: bridge
    ports:
      - 8080:8080
    environment:
      APACHE_PORT: 11000
      APACHE_IP_BINDING: 127.0.0.1
      SKIP_DOMAIN_VALIDATION: true
  caddy:
    image: caddy:alpine
    restart: always
    container_name: caddy
    volumes:
      - caddy_certs:/certs
      - caddy_config:/config
      - caddy_data:/data
      - caddy_sites:/srv
    network_mode: "host"
    configs:
      - source: Caddyfile
        target: /etc/caddy/Caddyfile
configs:
  Caddyfile:
    content: |
     https://andy.nextcloud:443 {
      tls internal
      reverse_proxy localhost:11000
volumes:
  caddy_certs:
  caddy_config:
  caddy_data:
  caddy_sites:
