Nextcloud AIO with Caddy and LetsEncrypt
    • Ubuntu 24.04 LTS
    • Apache 2.4.58
    • Caddy 2.10.0
    • 8.3.6
    • Yes
    • When trying to switch between internal TLS to LetsEncrypt
    • AIO
    • No, Caddy and port forwarding
I followed a tutorial online to create a Nextcloud instance at my datacentre which appeared to work but it had me set my docker compose file with “TLS Internal” in the Caddyfile section. This gives a workable instance of Nextcloud BUT with self-signed certs which are no use when I want to use LetsEncrypt certs to properly sign the traffic.
I was suggested to use Cloudflare, but I don’t want to use this for other reasons. I just want Caddy to do its (apparently default) thing of giving me properly signed certs.
I’ve looked extensively and can’t seem to find any definitive answer to what syntax do I need to replace “internal” with in order to get a proper certificate? Do i need to sign up separately with LetsEncrypt (or does that happen automagically)? I’ve forwarded ports 443 and 80 to the AIO instance in preparation.
  1. Follow this video: https://www.youtube.com/watch?v=ewarxugZH3Q
