- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
When updating to v15.1.1 the volume paths were changed by the update routine and broke them. this is after in docker:
I can no longer start nextcloud - is there any way to fix this. Sorry I am newish to this and still finding my feet - so be gentle please
- 35.0.3.2
docker
yes
After update using nextcloud AIO
AIO
After the update this error appears:
error while creating mount source path ‘/host_mnt/Volumes/cloud’: mkdir /host_mnt/Volumes/cloud: permission denied
There are no folders it changed it from the predefined paths
last logs are before the update - when it worked
cant run
