Nextcloud AIO, upgrade to NC 35 not working
    • 34.0.4
    • Raspberry Pi OS
I get the following error when trying to upgrade:
[ ] Check for expected files … K;41m[✘] Check for expected files failed;49m
;41mUnknown files detected within the installation folder. This can be fixed by manually removing (or moving) these files. The following extra files have been found:;49m
;41m core.7;49m
;41mUpdate failed. To resume or retry just execute the updater again.;49m
Nextcloud 34.0.4
  1. Just upgrade to NC35 in the web ui of NC AIO
Hi, you would need to remove that file from your nextcloud folder. You can likely do so by execing into the container and then removing the file with the rm command.
  1. First create a backup via the AIO-interface
  2. Start the containers again
  3. After all of them are running, run via CLI:
    sudo docker exec -it nextcloud-aio-nextcloud bash
  4. List all files and folders in the current dir via ls -la
  5. Remove the unexpected file via rm core.7
  6. Log out of the container via exit
  7. Try to run the update again via the AIO-interface
I hope it helps!
OK, I will try that out. But I never created this file so the problem seems to be a bit deeper.
Your instruction worked. Note, that I had to use sudo docker exec -it nextcloud-aio-nextcloud bash
Thank you.
What is this “core.7” file? I found a copy in my NextCloud AIO container and it’s owned by root. Thanks
The name sounds like a Linux core dump file.
What is the output of file core.7? It may at least confirm the process that crashed. A deeper dive would be necessary to gather further details.
Sorry, I already deleted it to get it working. I’ll gather details if I see it again.
