- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
- Nextcloud AIO v13.2.1
Ubuntu Server 24.04
aio-apache:latest
Caddy:alpine
Yes
today while installing an upgrade
Docker/Nextcloud-AIO
No
Upgrade failed. AIO Interface shows Nextcloud stopped, Containers “Apache & Caddy” as well as “Client Push” as “Starting”. I can’t seem to get out of this. Location for borg backup has not been set yet.
2026-06-10T08:53:53.050912341Z Upgrading Nextcloud from 33.0.3.2 to 33.0.5.1...
2026-06-10T08:53:53.382600926Z Nextcloud or one of the apps require upgrade - only a limited number of commands are available
2026-06-10T08:53:53.382630229Z You may use your browser or the occ upgrade command to do the upgrade
2026-06-10T08:53:53.390266093Z System config value integrity.check.disabled deleted
2026-06-10T08:53:53.636160957Z Setting log level to debug
2026-06-10T08:53:53.637062293Z Turned on maintenance mode
2026-06-10T08:53:53.886811132Z Updating database schema
2026-06-10T08:53:53.894968550Z Updated database
2026-06-10T08:53:56.120161397Z Starting code integrity check...
2026-06-10T08:55:00.748265364Z RedisException: Connection lost
2026-06-10T08:55:00.748289309Z Update failed
2026-06-10T08:55:00.748293395Z Maintenance mode is kept active
2026-06-10T08:55:00.748297092Z Resetting log level
2026-06-10T08:55:00.791988018Z Upgrade failed. Please restore from backup.
2026-06-10T08:55:10.955945862Z Posting notifications to users that are admins...
2026-06-10T08:58:44.092000897Z Done!
The contents of your config.php file from /var/lib/docker/volumes/nextcloud/nextcloud-aio-nextcloud/_data/config/config.php:
'one-click-instance' => true,
'one-click-instance.user-limit' => 100,
'apps_paths' =>
0 =>
'url' => '/apps',
'writable' => false,
1 =>
'url' => '/custom_apps',
'writable' => true,
'check_data_directory_permissions' => false,
'redis' =>
'host' => 'nextcloud-aio-redis',
'password' => '-',
'port' => 6379,
'timeout' => 3.0,
'read_timeout' => 10.0,
'overwritehost' => '-',
'passwordsalt' => '-',
'secret' => '-',
0 => 'localhost',
1 => '-',
'datadirectory' => '/mnt/ncdata',
'dbtype' => 'pgsql',
'version' => '33.0.3.2',
'overwrite.cli.url' => '-',
'dbname' => 'nextcloud_database',
'dbhost' => 'nextcloud-aio-database:5432',
'dbuser' => 'oc_nextcloud',
'dbpassword' => '-',
'instanceid' => '-',
'maintenance' => true,
'updatechecker' => false,
'loglevel' => 2,
'log_type' => 'file',
'logfile' => '/var/www/html/data/nextcloud.log',
'log_rotate_size' => 10485760,
'log.condition' =>
'apps' =>
0 => 'admin_audit',
'preview_max_x' => 2048,
'preview_max_y' => 2048,
'jpeg_quality' => 60,
'enabledPreviewProviders' =>
1 => 'OC\\Preview\\Image',
2 => 'OC\\Preview\\MarkDown',
3 => 'OC\\Preview\\MP3',
4 => 'OC\\Preview\\TXT',
5 => 'OC\\Preview\\OpenDocument',
6 => 'OC\\Preview\\Movie',
7 => 'OC\\Preview\\Krita',
0 => 'OC\\Preview\\Imaginary',
23 => 'OC\\Preview\\ImaginaryPDF',
'enable_previews' => true,
'mail_smtpmode' => 'smtp',
'versions_retention_obligation' => 'auto, 30',
'activity_expire_days' => 30,
'share_folder' => '/Shared',
'one-click-instance.link' => 'https://nextcloud.com/all-in-one/',
'upgrade.cli-upgrade-link' => 'https://github.com/nextcloud/all-in-one/discussions/2726',
'updatedirectory' => '/nc-updater',
'maintenance_window_start' => 100,
'allow_local_remote_servers' => true,
'davstorage.request_timeout' => 3600,
'documentation_url.server_logs' => 'https://github.com/nextcloud/all-in-one/discussions/5425',
'dbpersistent' => false,
'auth.bruteforce.protection.enabled' => true,
'ratelimit.protection.enabled' => true,
'files_external_allow_create_new_local' => false,
'trusted_proxies' =>
0 => '127.0.0.1',
1 => '::1',
10 => '172.19.0.0/16',
'preview_imaginary_url' => 'http://nextcloud-aio-imaginary:9000',
'preview_imaginary_key' => '-',
'mail_from_address' => '-',
'mail_domain' => '-',
'mail_smtpauth' => true,
'mail_smtpname' => '-',
'mail_smtppassword' => '-',
'mail_smtphost' => '-',
'defaultapp' => 'collectives,calendar,polls,spreed,files',
'mail_smtpport' => '993',
'mail_smtpsecure' => 'ssl',
'serverid' => 445,
'log_type_audit' => 'file',
'logfile_audit' => '/var/www/html/data/audit.log',
'update_channel' => 'stable',
I would be grateful for any help regarding the following steps:
- back up the database manually (since no borg backup options are currently visible)
- re-initialize the nextcloud upgrade process
- remove the error and get Nextcloud AIO to working condition again.
I have SSH access to the server.
Thank you in advance!
Kind regards
