Nextcloud AIO suddenly not starting - no logs, no errors?
I updated Proxmox PVE from 8 to 9. That’s the reason, why I had to stop (make the PVE update) and restart my Nextcloud AIO LXC.
I am not sure, if the PVE update from 8 to 9 is relevant, because I found no problems regarding PVE update and Nextcloud AIO, but I don’t want to “not say” this.
    • Nextcloud AIO v12.5.0
    • Proxmox LXC
    • Yes
    • yesterday after nextcloud LXC reboot
    • AIO
When I start my Server/Container, only the Administration interface is available.
Nextcloud, Apache, Notify Push und Docker Socket Proxy container always stay yellow. Each Container is saying “Waiting for Nextcloud to start…” and the Log of Nextcloud is more or less empty:
2026-02-04T13:21:52.737376320Z Connection to nextcloud-aio-database (172.18.0.7) 5432 port [tcp/postgresql] succeeded!
2026-02-04T13:21:54.777505724Z              now
2026-02-04T13:21:54.777576638Z ------------------------------
2026-02-04T13:21:54.777584332Z  2026-02-04 14:21:54.77476+01
2026-02-04T13:21:54.777591065Z (1 row)
2026-02-04T13:21:54.777606825Z
2026-02-04T13:21:54.786392005Z + '[' -f /dev-dri-group-was-added ']'
2026-02-04T13:21:54.786884616Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2026-02-04T13:21:54.787596391Z + '[' -n '' ']'
2026-02-04T13:21:54.787624153Z + set +x
2026-02-05T07:31:03.218685526Z Connection to nextcloud-aio-database (172.18.0.5) 5432 port [tcp/postgresql] succeeded!
2026-02-05T07:31:05.277714832Z               now
2026-02-05T07:31:05.277790676Z -------------------------------
2026-02-05T07:31:05.277799372Z  2026-02-05 08:31:05.270785+01
2026-02-05T07:31:05.277807187Z (1 row)
2026-02-05T07:31:05.277829359Z
2026-02-05T07:31:05.287445680Z + '[' -f /dev-dri-group-was-added ']'
2026-02-05T07:31:05.288311907Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2026-02-05T07:31:05.290029282Z + '[' -n '' ']'
2026-02-05T07:31:05.290062304Z + set +x
When I log in to my terminal, I get this message: “You have new mail.”
root:# cat /var/spool/mail/root
From root@nextcloud-state2-6.localdomain  Thu Feb  5 07:50:03 2026
Return-Path: <root@nextcloud-state2-6.localdomain>
X-Original-To: root
Delivered-To: root@nextcloud-state2-6.localdomain
Received: by nextcloud-state2-6.localdomain (Postfix, from userid 0)
        id 8C37A45663; Thu,  5 Feb 2026 07:50:03 +0000 (UTC)
From: root@nextcloud-state2-6.localdomain (Cron Daemon)
Subject: Cron <root@nextcloud-state2-6> docker ps --format "{{.Names}}" | grep -q "^nextcloud-aio-nextcloud$" && docker exec --user www-data nextcloud-aio-nextcloud php occ preview:pre-generate
MIME-Version: 1.0
Content-Type: text/plain; charset=US-ASCII
Content-Transfer-Encoding: quoted-printable
X-Cron-Env: <SHELL=/bin/sh>
X-Cron-Env: <HOME=/root>
X-Cron-Env: <LOGNAME=root>
Message-Id: <20260205075003.8C37A45663@nextcloud-state2-6.localdomain>
Date: Thu,  5 Feb 2026 07:50:03 +0000 (UTC)
Das Datenverzeichnis ist schreibgesch=C3=BCtzt.
Berechtigungen k=C3=B6nnen zumeist korrigiert werden, indem dem Webserver=
 Schreibzugriff auf das Wurzel-Verzeichnis einger=C3=A4umt wird. Siehe au=
ch https://docs.nextcloud.com/server/31/go.php?to=3Dadmin-dir_permissions=
Exception: Environment not properly prepared. in /var/www/html/lib/privat=
e/Console/Application.php:143
Stack trace:
#0 /var/www/html/console.php(81): OC\Console\Application->loadCommands(Ob=
ject(Symfony\Component\Console\Input\ArgvInput), Object(Symfony\Component=
\Console\Output\ConsoleOutput))
#1 /var/www/html/occ(33): require_once('/var/www/html/c...')
#2 {main}
From root@nextcloud-state2-6.localdomain  Thu Feb  5 08:00:02 2026
X-Original-To: root
        id 83FFE459F2; Thu,  5 Feb 2026 08:00:02 +0000 (UTC)
MIME-Version: 1.0
Message-Id: <20260205080002.83FFE459F2@nextcloud-state2-6.localdomain>
Date: Thu,  5 Feb 2026 08:00:02 +0000 (UTC)
Stack trace:
#2 {main}
But I haven’t changed any file rights.
Where can I check? To be honest: Not long time ago I switched from bare metal to Proxmox and Nextcloud AIO.
Thank you!
okay, this was false flag. it starts, but takes 7 hours https://help.nextcloud.com/t/nextcloud-aio-takes-7-hours-to-start/240097
