Iâm currently testing NextCloud. After having applied the first update (AIO 8.0 to AIO 8.1) the Containers
- Apache
- Nextcloud
- Notify Push
donât start anymore,
Docker Socket Proxy remain on status âstartingâ, seeming to infinitely loop wit message âWaiting for Nextcloud to start⌠nc: bad address ânextcloud-aio-nextcloudââ
Before applying the updat nextcloud was up an running.
I can see error messages in the log, but I donât have any clue how to continue:
Trying to fix docker.sock permissions internally...
Adding internal www-data to group ping
WARNING: No cpu cfs quota support
WARNING: No cpu cfs period support
WARNING: No cpu shares support
e[0;92mInitial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
â ď¸ Important: do always use an ip-address if you access this port and not a domain as HSTS might block access to it later!
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443e[0m
[10-Apr-2024 08:29:40] NOTICE: fpm is running, pid 134
[10-Apr-2024 08:29:40] NOTICE: ready to handle connections
[Wed Apr 10 08:29:40.703838 2024] [mpm_event:notice] [pid 125:tid 139627213474568] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured -- resuming normal operations
[Wed Apr 10 08:29:40.704153 2024] [core:notice] [pid 125:tid 139627213474568] AH00094: Command line: 'httpd -D FOREGROUND'
{"level":"info","ts":1712737780.712568,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
NOTICE: PHP message: Slim Application Error
Type: Exception
Code: 0
Message: Could not start container nextcloud-aio-nextcloud: Server error: `POST http://localhost/v1.41/containers/nextcloud-aio-nextcloud/start` resulted in a `500 Internal Server Error` response:
{"message":"path /mnt/nextcloud is mounted on /mnt/nextcloud but it is not a shared mount"}
File: /var/www/docker-aio/php/src/Docker/DockerActionManager.php
The log has some more entries, please let me know if they might be of any help.
AIO is running on Docker on a LXD-Container on a QNAP NAS (TS-364 with 32gig RAM)
/mnt/nextcloud is mounted via QNAPs Container station. mount -l shows
/dev/mapper/cachedev1 on /mnt/nextcloud type ext4 (rw,relatime,stripe=256,data=ordered,data_err=abort,jqfmt=vfsv1,usrjquota=aquota.user)
Any help appreciated.
TIA
Michael
