Nextcloud version 29.0.0
Operating system and version Debian 12 Proxmox LXC container (w/ NFS enabled)
Apache or nginx version Apache 2.4.59
PHP version 8.2.18
Can’t pass through NFS mounts to docker container. I have everything in FSTAB and it shows up perfectly on host but no matter what I do they do not show up inside Nextcloud
Is this the first time you’ve seen this error? Y
- add volume mounts in docker-compose.yml
- add nextcloud_mount variable - NEXTCLOUD_MOUNT-/mnt
- start nextcloud successfully
- add external storage app
- local storage option does not exist
- login to docker container nextcloud-aio-nextcloud, nothing in /mnt
Error jsresourceloader
Could not find resource firstrunwizard/js/personalsettings.js to load
"May 8, 2024, 4:14:44 PM"
"May 8, 2024, 4:00:41 PM"
Error PHP
Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234
"May 8, 2024, 3:45:38 PM"
Error PHP
Error PHP
Error PHP
Not sure where to find these in docker!
[Wed May 08 15:45:37.923073 2024] [mpm_event:notice] [pid 40:tid 134334311561992] AH00489: Apache/2.4.59 (Unix) configured -- resuming normal operations
[Wed May 08 15:45:37.923635 2024] [core:notice] [pid 40:tid 134334311561992] AH00094: Command line: '/usr/local/apache2/bin/httpd -D FOREGROUND'
{"level":"info","ts":1715208337.9290295,"msg":"using provided configuration","config_file":"/tmp/Caddyfile","config_adapter":""}
{"reqId":"LK8qTPpo6dZwgKG3sM11","level":3,"time":"2024-05-08T04:13:59+00:00","remoteAddr":"","user":"admin","app":"PHP","method":"","url":"--","message":"fopen(/var/www/html/config/config.php): Failed to open stream: No such file or directory at /var/www/html/lib/private/Config.php#225","userAgent":"--","version":"28.0.5.1","data":{"app":"PHP"}}
{"reqId":"gCEW7g3U6snA1z4SS9cU","level":3,"time":"2024-05-08T04:15:55+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 60, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"29.0.0.19","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocvs6m397grj/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":161,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":168,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":100,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":79,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[["prepare"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":57,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":212,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 60, arguments: {\"stage\":\"prepare\"})","exception":{},"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 60, arguments: {\"stage\":\"prepare\"})"}}
{"reqId":"G0Gsj21MyLgd88SApCZn","level":3,"time":"2024-05-08T04:20:49+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 73, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"29.0.0.19","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocvs6m397grj/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":161,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":168,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":100,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":79,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[["prepare"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":57,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":212,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 73, arguments: {\"stage\":\"prepare\"})","exception":{},"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 73, arguments: {\"stage\":\"prepare\"})"}}
{"reqId":"Yj0wKKLIMBotKxX7nrnz","level":3,"time":"2024-05-08T04:25:53+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 74, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"29.0.0.19","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocvs6m397grj/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":161,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":168,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":100,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":79,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[["prepare"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":57,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":212,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 74, arguments: {\"stage\":\"prepare\"})","exception":{},"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 74, arguments: {\"stage\":\"prepare\"})"}}
{"reqId":"ZecLL1xnyXLDOICqS90h","level":3,"time":"2024-05-08T04:30:53+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 75, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"29.0.0.19","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocvs6m397grj/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":161,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":168,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":100,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":79,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[["prepare"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":57,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":212,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 75, arguments: {\"stage\":\"prepare\"})","exception":{},"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 75, arguments: {\"stage\":\"prepare\"})"}}
{"reqId":"oBqYsXh2HN1JwZDNSxkl","level":3,"time":"2024-05-08T04:35:53+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 76, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"29.0.0.19","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocvs6m397grj/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":161,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":168,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":100,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":79,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[["prepare"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":57,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":212,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 76, arguments: {\"stage\":\"prepare\"})","exception":{},"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 76, arguments: {\"stage\":\"prepare\"})"}}
{"reqId":"hamhCzqlwZccwtoFnWiZ","level":3,"time":"2024-05-08T04:40:53+00:00","remoteAddr":"","user":"--","app":"core","method":"","url":"--","message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 77, arguments: {\"stage\":\"prepare\"})","userAgent":"--","version":"29.0.0.19","exception":{"Exception":"OCP\\Files\\NotFoundException","Message":"/appdata_ocvs6m397grj/theming/global","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/Node/LazyFolder.php","line":161,"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":132,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_ocvs6m397grj/theming/global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":168,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":100,"function":"storeUserIdsToProcess","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[[]]},{"file":"/var/www/html/apps/theming/lib/Jobs/MigrateBackgroundImages.php","line":79,"function":"runPreparation","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[]},{"file":"/var/www/html/lib/public/BackgroundJob/Job.php","line":80,"function":"run","class":"OCA\\Theming\\Jobs\\MigrateBackgroundImages","type":"->","args":[["prepare"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":57,"function":"start","class":"OCP\\BackgroundJob\\Job","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/lib/public/BackgroundJob/QueuedJob.php","line":47,"function":"start","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]},{"file":"/var/www/html/cron.php","line":176,"function":"execute","class":"OCP\\BackgroundJob\\QueuedJob","type":"->","args":[["OC\\BackgroundJob\\JobList"]]}],"File":"/var/www/html/lib/private/Files/Node/Root.php","Line":212,"message":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 77, arguments: {\"stage\":\"prepare\"})","exception":{},"CustomMessage":"Error while running background job OCA\\Theming\\Jobs\\MigrateBackgroundImages (id: 77, arguments: {\"stage\":\"prepare\"})"}}
{"reqId":"SkjSG2OKnazOvYccgBiw","level":3,"time":"2024-05-08T04:41:18+00:00","remoteAddr":"x.x.x.x","user":"--","app":"PHP","method":"GET","url":"/","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"vWKys5uVywvT5I8Mj8KS","level":3,"time":"2024-05-08T04:41:19+00:00","remoteAddr":"x.x.x.x","user":"--","app":"index","method":"GET","url":"/apps/theming/icon?v=b6589fc6","message":"Could not get appdata folder for theming","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","exception":{"Exception":"RuntimeException","Message":"Could not get appdata folder for theming","Code":0,"Trace":[{"file":"/var/www/html/lib/private/Files/AppData/AppData.php","line":147,"function":"getAppDataFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/ImageManager.php","line":367,"function":"newFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["global"]},{"file":"/var/www/html/apps/theming/lib/ImageManager.php","line":101,"function":"getRootFolder","class":"OCA\\Theming\\ImageManager","type":"->","args":[]},{"file":"/var/www/html/apps/theming/lib/Controller/IconController.php","line":176,"function":"getImage","class":"OCA\\Theming\\ImageManager","type":"->","args":["favicon"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":232,"function":"getTouchIcon","class":"OCA\\Theming\\Controller\\IconController","type":"->","args":["core"]},{"file":"/var/www/html/lib/private/AppFramework/Http/Dispatcher.php","line":138,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Theming\\Controller\\IconController"],"getTouchIcon"]},{"file":"/var/www/html/lib/private/AppFramework/App.php","line":184,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->","args":[["OCA\\Theming\\Controller\\IconController"],"getTouchIcon"]},{"file":"/var/www/html/lib/private/Route/Router.php","line":338,"function":"main","class":"OC\\AppFramework\\App","type":"::","args":["OCA\\Theming\\Controller\\IconController","getTouchIcon",["OC\\AppFramework\\DependencyInjection\\DIContainer"],["core","theming.icon.gettouchicon"]]},{"file":"/var/www/html/lib/base.php","line":1050,"function":"match","class":"OC\\Route\\Router","type":"->","args":["/apps/theming/icon"]},{"file":"/var/www/html/index.php","line":49,"function":"handleRequest","class":"OC","type":"::","args":[]}],"File":"/var/www/html/lib/private/Files/AppData/AppData.php","Line":108,"message":"Could not get appdata folder for theming","exception":{},"CustomMessage":"Could not get appdata folder for theming"}}
{"reqId":"blfHEwBnbTQPXfNBeuxq","level":3,"time":"2024-05-08T22:28:26+00:00","remoteAddr":"x.x.x.x","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"--","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"VKYLYHZRqTDGzSG8Z26p","level":3,"time":"2024-05-08T22:35:09+00:00","remoteAddr":"x.x.x.x","user":"--","app":"PHP","method":"GET","url":"/","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"IJ9L4uZlyZsYi20WXqVi","level":3,"time":"2024-05-08T22:35:09+00:00","remoteAddr":"x.x.x.x","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"--","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"4pN1MeW6oK8xv2GKnGlE","level":2,"time":"2024-05-08T22:35:23+00:00","remoteAddr":"x.x.x.x","user":"--","app":"no app in context","method":"POST","url":"/login","message":"Login failed: admin (Remote IP: x.x.x.x)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":[]}
{"reqId":"vL5GKsxfPFVa2lQfDWSc","level":2,"time":"2024-05-08T22:35:34+00:00","remoteAddr":"x.x.x.x","user":"--","app":"no app in context","method":"POST","url":"/login","message":"Login failed: admin (Remote IP: x.x.x.x)","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":[]}
{"reqId":"RIHn8C098VilApthqAd3","level":3,"time":"2024-05-08T22:41:42+00:00","remoteAddr":"x.x.x.x","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"--","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"NaYkLX3uCy1t7i9X3oyy","level":2,"time":"2024-05-08T22:41:44+00:00","remoteAddr":"x.x.x.x","user":"admin","app":"core","method":"GET","url":"/settings/users","message":"Login failed: 'admin' (Remote IP: 'x.x.x.x')","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"core"}}
{"reqId":"NaYkLX3uCy1t7i9X3oyy","level":2,"time":"2024-05-08T22:41:44+00:00","remoteAddr":"x.x.x.x","user":"admin","app":"core","method":"GET","url":"/settings/users","message":"Session token credentials are invalid","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"core","user":"null"}}
{"reqId":"mGURTKltIRCrApZKeUuj","level":3,"time":"2024-05-08T22:45:38+00:00","remoteAddr":"x.x.x.x","user":"--","app":"PHP","method":"GET","url":"/index.php/apps/notify_push/test/version","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"--","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"kJsNf7L4CUuLit1Gu6yi","level":3,"time":"2024-05-08T22:45:38+00:00","remoteAddr":"x.x.x.x","user":"admin","app":"PHP","method":"GET","url":"/settings/admin/externalstorages","message":"Optional parameter $userId declared before required parameter $path is implicitly treated as a required parameter at /var/www/html/custom_apps/deck/lib/Service/ConfigService.php#234","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"PHP"}}
{"reqId":"nTL0Wegx5hVkHy9hhNQc","level":3,"time":"2024-05-08T23:00:41+00:00","remoteAddr":"x.x.x.x","user":"admin","app":"jsresourceloader","method":"GET","url":"/settings/user/sync-clients","message":"Could not find resource firstrunwizard/js/personalsettings.js to load","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"jsresourceloader"}}
{"reqId":"7IVuaN7vzWEBk41ULMYj","level":3,"time":"2024-05-08T23:14:44+00:00","remoteAddr":"x.x.x.x","user":"admin","app":"jsresourceloader","method":"GET","url":"/settings/user/sync-clients","message":"Could not find resource firstrunwizard/js/personalsettings.js to load","userAgent":"Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:125.0) Gecko/20100101 Firefox/125.0","version":"29.0.0.19","data":{"app":"jsresourceloader"}}
