version: '3'
services:
nextcloud:
restart: always
volumes:
- ${VOLUME_PATH}/nextcloud_aio_mastercontainer:/mnt/docker-aio-config
- ${VOLUME_PATH}/nextcloud_aio_mastercontainer/Backup:/mnt/backup
ports:
- ${PORT1}:8080 # This port will be used for the installer website
- ${PORT2}:3478 # Needed for Nextcloud Talk
- ${PORT2}:3478/udp
environment:
- APACHE_PORT=${PORT2} # Is needed when running behind a web server or reverse proxy (like Apache, Nginx and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
- APACHE_IP_BINDING=0.0.0.0 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
- NEXTCLOUD_ADDITIONAL_APKS=imagemagick
- NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS=imagick
- NEXTCLOUD_MEMORY_LIMIT=8096M # Check requirements, everything needs 8096!
networks:
- proxied
networks:
proxied:
external: true
# caddyfile
# nc.YOURDOMAIN.com {
# encode gzip
# reverse_proxy YOURHOST_IP:PORT2
issue you are facing:
I cannot create a backup because when it’s running I get this in the logs. Otherwise my Nextcloud is running fine and I don’t understand why it wont let me create a Backup and it shutsdown all the other containers because of it and it won’t let me even start them again, logs for this are the second codeblock.
configuration.json not present. Cannot perform the backup!
/start.sh: line 42: /nextcloud_aio_volumes/nextcloud_aio_mastercontainer/data/backup_archives.list: No such file or directory
chmod: /nextcloud_aio_volumes/nextcloud_aio_mastercontainer/data/backup_archives.list: No such file or directory
Trying to fix docker.sock permissions internally...
Creating docker group internally with id 997
e[0;92mInitial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443e[0m
{"level":"info","ts":1690884349.0497334,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
[Tue Aug 01 10:05:49.089770 2023] [mpm_event:notice] [pid 121:tid 140540735081288] AH00489: Apache/2.4.57 (Unix) OpenSSL/3.1.1 configured -- resuming normal operations
[Tue Aug 01 10:05:49.089854 2023] [core:notice] [pid 121:tid 140540735081288] AH00094: Command line: 'httpd -D FOREGROUND'
[01-Aug-2023 10:05:49] NOTICE: fpm is running, pid 125
[01-Aug-2023 10:05:49] NOTICE: ready to handle connections
NOTICE: PHP message: Slim Application Error
Type: GuzzleHttp\Exception\ServerException
0
Message: Server error: `POST http://localhost/v1.41/containers/nextcloud-aio-apache/start` resulted in a `500 Internal Server Error` response:
{"message":"driver failed programming external connectivity on endpoint nextcloud-aio-apache (134d89b447b5f65b5541349b50 (truncated...)
File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
3
Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
#1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::GuzzleHttp\{closure}(Object(GuzzleHttp\Psr7\Response))
#2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
#3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::GuzzleHttp\Promise\{closure}()
#4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
#5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
#6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
#7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
#8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
#9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(189): GuzzleHttp\Promise\Promise->wait()
#10 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/ClientTrait.php(95): GuzzleHttp\Client->request('POST', 'http://localhos...', Array)
#11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(182): GuzzleHttp\Client->post('http://localhos...')
#12 /var/www/docker-aio/php/src/Controller/DockerController.php(48): AIO\Docker\DockerActionManager->StartContainer(Object(AIO\Container\Container))
#13 /var/www/docker-aio/php/src/Controller/DockerController.php(193): AIO\Controller\DockerController->PerformRecursiveContainerStart('nextcloud-aio-a...', true)
#14 /var/www/docker-aio/php/src/Controller/DockerController.php(173): AIO\Controller\DockerController->startTopContainer(true)
#15 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(38): AIO\Controller\DockerController->StartContainer(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#16 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(358): Slim\Handlers\Strategies\RequestResponse->__invoke(Array, Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#17 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#18 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#19 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(315): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#20 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(68): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
#21 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(476): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#23 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#25 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#27 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#28 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#29 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#30 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#31 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#32 /var/www/docker-aio/php/public/index.php(181): Slim\App->run()
#33 {main}
Tips: To display error details in HTTP response set "displayErrorDetails" to true in the ErrorHandler constructor.
Is this the first time you’ve seen this error? (Y/N): y
