Nextcloud-aio-mastercontainer stuck in restarting loop?
Nextcloud version (eg, 20.0.5): 25.0.4.1 AIO
Operating system and version (eg, Ubuntu 20.04): Windows 10
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): replace me
I have been running Nextcloud AIO through Docker Desktop on Windows 10 for about 2 months without issue. Upgraded Docker for the 3rd time and did not think anything of it. I noticed on my smartphone that I could no longer backup.
nextcloud-aio-mastercontainer stuck in restarting loop inside Docker Desktop 4.20.1
Is this the first time you’ve seen this error? (Y/N): YES
  1. Updated Docker Desktop to 4.20.1
  2. Restarted Windows 10
  3. Never able to start Nextcloud again
2023-05-19 23:57:55 Trying to fix docker.sock permissions internally...
2023-05-19 23:57:55 Adding internal www-data to group root
2023-05-19 23:57:56 WARNING: No blkio throttle.read_bps_device support
2023-05-19 23:57:56 WARNING: No blkio throttle.write_bps_device support
2023-05-19 23:57:56 WARNING: No blkio throttle.read_iops_device support
2023-05-19 23:57:56 WARNING: No blkio throttle.write_iops_device support
2023-05-19 23:58:00 {"level":"info","ts":1684558680.990622,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
2023-05-19 23:58:00 {"level":"info","ts":1684558680.995948,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
2023-05-19 23:58:01 [20-May-2023 04:58:01] NOTICE: fpm is running, pid 130
2023-05-19 23:58:01 [20-May-2023 04:58:01] NOTICE: ready to handle connections
2023-05-19 23:57:58 Initial startup of Nextcloud All-in-One complete!
2023-05-19 23:57:58 You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2023-05-19 23:57:58 E.g. https://internal.ip.of.this.server:8080
2023-05-19 23:57:58
2023-05-19 23:57:58 If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2023-05-19 23:57:58 https://your-domain-that-points-to-this-server.tld:8443
2023-05-20 23:00:06 Deleted Images:
2023-05-20 23:00:06 untagged: nextcloud/aio-watchtower@sha256:1d625fe4b39832cba7aeb7d8facb9a94cadd2969930a362184a69a947f4920bb
2023-05-20 23:00:06 deleted: sha256:9244b493948affa46e25d04c3d65c0474af62146cd3f140f3830dc781caf0b25
2023-05-20 23:00:06 deleted: sha256:af22caba74f8adeb8de9bf50dc0daa4b1a2cc023d4c369d45b45f59b74c7baf9
2023-05-20 23:00:06 deleted: sha256:47fa70783c4a4d91abfacd9646b7de8618f14c76376ea52d9f6bcf89f7e2618e
2023-05-20 23:00:06 deleted: sha256:b06f99db777c17707e7ad225b8e72557421f85fb673ffbe8c3d214e843eabfb1
2023-05-20 23:00:06 deleted: sha256:6167debc6f7d66e391d7a719448a29507965aeb09bde52d3e16c373d9d4a5d78
2023-05-20 23:00:06
2023-05-20 23:00:06 Total reclaimed space: 15.55MB
2023-05-21 23:00:12 Total reclaimed space: 0B
2023-05-22 23:00:18 Total reclaimed space: 0B
2023-05-23 23:00:25 Total reclaimed space: 0B
2023-05-24 23:00:01 Total reclaimed space: 0B
2023-05-25 23:00:07 Total reclaimed space: 0B
2023-05-26 14:17:47 Initial startup of Nextcloud All-in-One complete!
2023-05-26 14:17:47 You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2023-05-26 14:17:47 E.g. https://internal.ip.of.this.server:8080
2023-05-26 14:17:47
2023-05-26 14:17:47 If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2023-05-26 14:17:47 https://your-domain-that-points-to-this-server.tld:8443
2023-05-26 14:17:45 WARNING: No blkio throttle.read_bps_device support
2023-05-26 14:17:45 WARNING: No blkio throttle.write_bps_device support
2023-05-26 14:17:45 WARNING: No blkio throttle.read_iops_device support
2023-05-26 14:17:45 WARNING: No blkio throttle.write_iops_device support
2023-05-26 14:17:49 {"level":"info","ts":1685128669.9108634,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
2023-05-26 14:17:49 {"level":"info","ts":1685128669.9238334,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
2023-05-26 14:17:49 [26-May-2023 19:17:49] NOTICE: fpm is running, pid 119
2023-05-26 14:17:49 [26-May-2023 19:17:49] NOTICE: ready to handle connections
2023-05-26 23:00:26 Total reclaimed space: 0B
2023-05-27 23:00:01 Total reclaimed space: 0B
2023-05-28 23:00:07 Total reclaimed space: 0B
2023-05-29 23:00:12 Total reclaimed space: 0B
2023-05-30 23:00:18 Total reclaimed space: 0B
2023-05-31 23:00:24 Total reclaimed space: 0B
2023-06-01 23:00:29 Total reclaimed space: 0B
2023-06-02 23:00:17 Total reclaimed space: 0B
2023-06-03 23:00:23 Total reclaimed space: 0B
2023-06-04 23:00:29 Total reclaimed space: 0B
2023-06-05 23:00:05 Total reclaimed space: 0B
2023-06-06 23:00:10 Total reclaimed space: 0B
2023-06-07 23:33:15 WARNING: No blkio throttle.read_bps_device support
2023-06-07 23:33:15 WARNING: No blkio throttle.write_bps_device support
2023-06-07 23:33:15 WARNING: No blkio throttle.read_iops_device support
2023-06-07 23:33:15 WARNING: No blkio throttle.write_iops_device support
2023-06-07 23:33:17 Initial startup of Nextcloud All-in-One complete!
2023-06-07 23:33:17 You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2023-06-07 23:33:17 E.g. https://internal.ip.of.this.server:8080
2023-06-07 23:33:17
2023-06-07 23:33:17 If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2023-06-07 23:33:19 {"level":"info","ts":1686198799.9373202,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
2023-06-07 23:33:19 {"level":"info","ts":1686198799.951147,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
2023-06-07 23:33:20 [08-Jun-2023 04:33:20] NOTICE: fpm is running, pid 121
2023-06-07 23:33:20 [08-Jun-2023 04:33:20] NOTICE: ready to handle connections
2023-06-18 17:48:37 WARNING: No blkio throttle.read_bps_device support
2023-06-18 17:48:37 WARNING: No blkio throttle.write_bps_device support
2023-06-18 17:48:37 WARNING: No blkio throttle.read_iops_device support
2023-06-07 23:33:17 https://your-domain-that-points-to-this-server.tld:8443
2023-06-08 23:00:26 Total reclaimed space: 0B
2023-06-09 23:00:16 Total reclaimed space: 0B
2023-06-10 23:00:21 Total reclaimed space: 0B
2023-06-11 23:00:26 Total reclaimed space: 0B
2023-06-12 23:00:02 Total reclaimed space: 0B
2023-06-13 23:00:08 Total reclaimed space: 0B
2023-06-14 23:00:14 Total reclaimed space: 0B
2023-06-15 23:00:20 Total reclaimed space: 0B
2023-06-16 23:00:32 Total reclaimed space: 0B
2023-06-17 23:00:08 Total reclaimed space: 0B
2023-06-18 17:48:39 Initial startup of Nextcloud All-in-One complete!
2023-06-18 17:48:37 WARNING: No blkio throttle.write_iops_device support
2023-06-18 17:48:41 {"level":"info","ts":1687128521.9374468,"msg":"using provided configuration","config_file":"/Caddyfile","config_adapter":""}
2023-06-18 17:48:41 {"level":"info","ts":1687128521.965725,"msg":"failed to sufficiently increase receive buffer size (was: 208 kiB, wanted: 2048 kiB, got: 416 kiB). See https://github.com/quic-go/quic-go/wiki/UDP-Receive-Buffer-Size for details."}
2023-06-18 17:48:42 [18-Jun-2023 22:48:42] NOTICE: fpm is running, pid 125
2023-06-18 17:48:42 [18-Jun-2023 22:48:42] NOTICE: ready to handle connections
2023-06-18 17:48:43 [18-Jun-2023 22:48:43] NOTICE: Terminating ...
2023-06-18 17:48:43 [18-Jun-2023 22:48:43] NOTICE: exiting, bye-bye!
2023-06-18 17:48:39 You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
2023-06-18 17:48:39 E.g. https://internal.ip.of.this.server:8080
2023-06-18 17:48:39
2023-06-18 17:48:39 If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
2023-06-18 17:48:39 https://your-domain-that-points-to-this-server.tld:8443
2023-06-18 17:53:07 Cannot connect to the docker socket. Cannot proceed.
2023-06-18 17:53:10 Cannot connect to the docker socket. Cannot proceed.
Is there anyway to correct this error without starting all the way over. My installation has 151 GB of backed up files that thankfully I can still access. I believe I have a backup as well.
Might be this:
AKA:
Which appears to have been fixed in the release from a couple days ago (just after yours) of DD:
Indeed the issue should be fixed with Docker Desktop 4.21.1. See connecting to docker socket inside container with different user than root is broken after updating to 4.19 · Issue #13447 · docker/for-win · GitHub
@jtr and @szaimen Thank you. THIS indeed fixed my issue! It broke on 4.19. I updated to 4.20.1 and it was still broken. Today, I updated to 4.21.1 and the bug is fixed. My smartphones are busy backing up as we speak!
THANK YOU!!!
