Hello, I have been trying to install the docker container, the current latest version from the docs. One thing I have done that i believe might be causing the installation to break, is that I am changing the nextcloud datadir to an rclone mount. I have put the flag allow_other as depicted in the docs, and the error does not mention any permission issue. I am at a loss here, I dont know what is going wrong. I have fully reset and restarted this process (from the docs) multiple times, and it always fails with the same erroe. If anyone can give me any advide I will be very grateful. Thanks
This is the error I am getting:
+ '[' -n '' ']'
+ set +x
Enabling Imagick...
WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.19/main: No such file or directory
WARNING: opening from cache https://dl-cdn.alpinelinux.org/alpine/v3.19/community: No such file or directory
Configuring Redis as session handler...
Initializing nextcloud 27.1.5.1 ...
Initializing finished
New Nextcloud instance.
Installing with PostgreSQL database
Starting Nextcloud installation...
Username is invalid because files already exist for this user
Installation of Nextcloud failed!
Connection to nextcloud-aio-database (172.21.0.5) 5432 port [tcp/postgresql] succeeded!
now
2024-02-22 23:29:25.962748-05
(1 row)
+ '[' -n '' ']'
+ set +x
The initial Nextcloud installation failed.
Please reset AIO properly and try again. For further clues what went wrong, check the logs above.
See https://github.com/nextcloud/all-in-one#how-to-properly-reset-the-instance
now
2024-02-22 23:29:28.806762-05
(1 row)
+ '[' -n '' ']'
+ set +x
now
2024-02-22 23:29:31.904729-05
(1 row)
+ '[' -n '' ']'
+ set +x
now
2024-02-22 23:29:35.345125-05
(1 row)
+ '[' -n '' ']'
+ set +x
now
2024-02-22 23:29:39.801215-05
(1 row)
+ '[' -n '' ']'
+ set +x
This is my operating system from inxi, if needed:
System:
Host: nxtcld Kernel: 5.15.0-1051-oracle aarch64 bits: 64 Console: pty pts/1
Distro: Ubuntu 22.04.4 LTS (Jammy Jellyfish)
Machine:
Type: Kvm System: QEMU product: KVM Virtual Machine v: virt-4.2 serial: N/A
Mobo: N/A model: N/A serial: N/A UEFI: EFI Development Kit II / OVMF v: 1.6.6
date: 08/22/2023
CPU:
Info: quad core model: N/A bits: 64 type: MCP
Speed: N/A min/max: N/A cores: No per core speed data found.
Graphics:
Device-1: Red Hat Virtio GPU driver: virtio-pci v: 1
Display: server: No display server data found. Headless machine? tty: 110x28
resolution: 1024x768
Message: GL data unavailable in console for root.
Audio:
Message: No device data found.
Network:
Device-1: Red Hat Virtio network driver: virtio-pci
IF-ID-1: br-7a2db2aab884 state: up speed: 10000 Mbps duplex: unknown mac: 02:42:5f:68:85:08
IF-ID-2: docker0 state: up speed: 10000 Mbps duplex: unknown mac: 02:42:0a:0f:78:87
IF-ID-3: enp0s6 state: up speed: -1 duplex: unknown mac: 00:00:17:01:ce:69
IF-ID-4: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-5: veth17af99b state: up speed: 10000 Mbps duplex: full mac: b6:0e:bf:ec:8a:6c
IF-ID-6: veth2bc522e state: up speed: 10000 Mbps duplex: full mac: 1a:14:f7:92:ab:45
IF-ID-7: veth49d5273 state: up speed: 10000 Mbps duplex: full mac: 62:be:d3:df:be:11
IF-ID-8: veth68fcfbd state: up speed: 10000 Mbps duplex: full mac: 0e:b1:7c:d1:7d:06
IF-ID-9: veth8a9e21a state: up speed: 10000 Mbps duplex: full mac: 92:ff:8a:1c:5e:f6
IF-ID-10: vetha2da568 state: up speed: 10000 Mbps duplex: full mac: 9a:d0:df:73:d7:a5
IF-ID-11: vethb2c1ed4 state: up speed: 10000 Mbps duplex: full mac: 12:7d:df:f8:0a:4c
IF-ID-12: vethb5d2ef5 state: up speed: 10000 Mbps duplex: full mac: 0a:54:11:ee:5f:fe
IF-ID-13: vethe1fe680 state: up speed: 10000 Mbps duplex: full mac: 76:c1:bd:1b:62:f0
Drives:
Local Storage: total: 100 GiB used: 8.32 GiB (8.3%)
ID-1: /dev/sda model: BlockVolume size: 100 GiB
Partition:
ID-1: / size: 96.73 GiB used: 8.31 GiB (8.6%) fs: ext4 dev: /dev/sda1
ID-2: /boot/efi size: 97.5 MiB used: 6.3 MiB (6.4%) fs: vfat dev: /dev/sda15
Swap:
Alert: No swap data was found.
Sensors:
Message: No sensor data found. Is lm-sensors configured?
Info:
Processes: 269 Uptime: 4d 12h 34m Memory: 23.43 GiB used: 1.33 GiB (5.7%) Init: systemd
runlevel: 5 Shell: Bash inxi: 3.3.13
I am using oracle VM.
