Nextcloud AIO installation behind Caddy proxy on Synology NAS using portainer - cannot login
example
longer
example
here
Nextcloud version (eg, 29.0.5): latest
Operating system and version (eg, Ubuntu 24.04): Synology NAS using docker/portainer
Apache or nginx version (eg, Apache 2.4.25): 2.4.62
I have installed nextcloud AIO following the readMe on github, instructions for portainer and using behind proxy setup. i have enabled the option to skip domain validation. Was able to setup the initial steps using myIP:8680 (8080) and submitted my domain. I got the passphrase, now after installing all the conntainers, when i click on go to nextcloud button, it opens my domain and shows me error as follows:
  • Bad Request
Your browser sent a request that this server could not understand.
Reason: You’re speaking plain HTTP to an SSL-enabled server port.
Instead use the HTTPS scheme to access this URL, please.*
The caddy configuration for the domain I have used:
mycloud.mydomain.com {
#  proxy / nextcloud-aio {
#    upstream localIP:8680
#  redir http:// {uri} https://
  tls email ID
  reverse_proxy http://localIP:8680
#    transport http {
#      tls
#      tls_insecure_skip_verify
I have even tried with https. but does not work.
my docker compose in portainer:
services:
    init: true
    restart: always
    volumes:
    network_mode: bridge # add to the same network as docker run would do
    ports:
      #- 8580:80 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      - 8680:8080
      #- 8543:8443 # Can be removed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # AIO_DISABLE_BACKUP_SECTION: false # Setting this to true allows to hide the backup section in the AIO interface. See https://github.com/nextcloud/all-in-one#how-to-disable-the-backup-section
      APACHE_PORT: 12000 # Is needed when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else). See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      APACHE_IP_BINDING: 0.0.0.0 # Should be set when running behind a web server or reverse proxy (like Apache, Nginx, Caddy, Cloudflare Tunnel and else) that is running on the same host. See https://github.com/nextcloud/all-in-one/blob/main/reverse-proxy.md
      # BORG_RETENTION_POLICY: --keep-within=7d --keep-weekly=4 --keep-monthly=6 # Allows to adjust borgs retention policy. See https://github.com/nextcloud/all-in-one#how-to-adjust-borgs-retention-policy
      # COLLABORA_SECCOMP_DISABLED: false # Setting this to true allows to disable Collabora's Seccomp feature. See https://github.com/nextcloud/all-in-one#how-to-disable-collaboras-seccomp-feature
      NEXTCLOUD_DATADIR: /volume1/dataDir/ncdata # Allows to set the host directory for Nextcloud's datadir. ⚠️⚠️⚠️ Warning: do not set or adjust this value after the initial Nextcloud installation is done! See https://github.com/nextcloud/all-in-one#how-to-change-the-default-location-of-nextclouds-datadir
      NEXTCLOUD_MOUNT: /volume1/ # Allows the Nextcloud container to access the chosen directory on the host. See https://github.com/nextcloud/all-in-one#how-to-allow-the-nextcloud-container-to-access-directories-on-the-host
      # NEXTCLOUD_UPLOAD_LIMIT: 10G # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-upload-limit-for-nextcloud
      # NEXTCLOUD_MAX_TIME: 3600 # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-max-execution-time-for-nextcloud
      # NEXTCLOUD_MEMORY_LIMIT: 512M # Can be adjusted if you need more. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-php-memory-limit-for-nextcloud
      # NEXTCLOUD_TRUSTED_CACERTS_DIR: /path/to/my/cacerts # CA certificates in this directory will be trusted by the OS of the nexcloud container (Useful e.g. for LDAPS) See See https://github.com/nextcloud/all-in-one#how-to-trust-user-defined-certification-authorities-ca
      # NEXTCLOUD_STARTUP_APPS: deck twofactor_totp tasks calendar contacts notes # Allows to modify the Nextcloud apps that are installed on starting AIO the first time. See https://github.com/nextcloud/all-in-one#how-to-change-the-nextcloud-apps-that-are-installed-on-the-first-startup
      # NEXTCLOUD_ADDITIONAL_APKS: imagemagick # This allows to add additional packages to the Nextcloud container permanently. Default is imagemagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-os-packages-permanently-to-the-nextcloud-container
      # NEXTCLOUD_ADDITIONAL_PHP_EXTENSIONS: imagick # This allows to add additional php extensions to the Nextcloud container permanently. Default is imagick but can be overwritten by modifying this value. See https://github.com/nextcloud/all-in-one#how-to-add-php-extensions-permanently-to-the-nextcloud-container
      # NEXTCLOUD_ENABLE_DRI_DEVICE: true # This allows to enable the /dev/dri device in the Nextcloud container. ⚠️⚠️⚠️ Warning: this only works if the '/dev/dri' device is present on the host! If it should not exist on your host, don't set this to true as otherwise the Nextcloud container will fail to start! See https://github.com/nextcloud/all-in-one#how-to-enable-hardware-transcoding-for-nextcloud
      # NEXTCLOUD_KEEP_DISABLED_APPS: false # Setting this to true will keep Nextcloud apps that are disabled in the AIO interface and not uninstall them if they should be installed. See https://github.com/nextcloud/all-in-one#how-to-keep-disabled-apps
      # TALK_PORT: 3478 # This allows to adjust the port that the talk container is using. See https://github.com/nextcloud/all-in-one#how-to-adjust-the-talk-port
      # WATCHTOWER_DOCKER_SOCKET_PATH: /var/run/docker.sock # Needs to be specified if the docker socket on the host is not located in the default '/var/run/docker.sock'. Otherwise mastercontainer updates will fail. For macos it needs to be '/var/run/docker.sock'
      SKIP_DOMAIN_VALIDATION: true
    # security_opt: ["label:disable"] # Is needed when using SELinux
volumes: # If you want to store the data on a different drive, see https://github.com/nextcloud/all-in-one#how-to-store-the-filesinstallation-on-a-separate-drive
  1. try to login using the submitted domain
PASTE HERE
nextcloud.log is empty
I have tried apache_port and IP binding options as you can see. I have also tried not using these and doing standard installation and routing to 80 port using Caddy, but still i end up with similar issue. I have also tried setting up caddy proxy route to nextcloud-aio-mastercontainer:12000 (apache port) that does not work at all.
All this is new to me. I only managed to setup Caddy with cloudflare DNS on my synology NAS and using it by port forwarding 80 and 443 to http and https ports i configured for caddy. There is no clash in the ports and caddy routing works for other simpler containers I have like adguard and portainer.
I think i must be doing something fundamentally wrong but cannot identify the mistake. Please can you guys help me with the setup ?
This should match the APACHE_PORT. Looks like 12000 in your case.
That was exactly what i did wrong. I changed it to 12000 and now i am able to access the login page without errors !
Thanks a lot for helping me out. Now I can clear out all the mess in my caddyfile that I was trying out :slight_smile:
