Hey all,
I would like your help in a Nextcloud server setup!
I have a Windows 10 machine (connected via Wi-Fi), docker desktop and Nextcloud AIO running in the container ( based on this guide: Your Guide to the Nextcloud All-in-One on Windows 10 & 11! - Nextcloud )
I created a domain in Duckdns and the updater is running on the server (duckdsn java updater)
Xiaomi Router AX3200, ports open: 80 TCP, 443 TCP
Static IP set and the server machine added in DHCP Static IP Assignment in the router (if this matters)
Nextcloud runs successfully, but when I open my domain, I can’t access the machine, I get “connection timed out”. I checked the ports in “portchecker.co” and 80,443 are closed for some reason are?!
I’ve attached pictures of the whole thing (sorry I did it with a phone, but I’m writing from a third machine now).
I don’t know if I should open other ports or enable something on the Windows firewall, is there something in docker or duckdns or could there be another problem? If I can help by sharing a log, I will attach it as well.
Thanks in advance for the help! ( really because I almost gave up once…
